swaybar disconnect idea?
Discussion in 'Suspension' started by wolfman00, Aug 28, 2020.
  1. Aug 28, 2020 at 12:34 PM
    wolfman00
    wolfman00 [OP] Well-Known Member
    matt
    Gambrills/Crofton MD
    '16 dclb
    sortof stock. 6112/5160, pro wheels and a tune.
    ideas have swirled around forever on disconnects, and obviously endlink disconnects are not a good idea for our trucks if you like your CV boots. (ask me how i know). Ive been looking at lots of different ideas on how people do this and got this idea. if its dumb, tell me haha.
    cut the swaybar in half (between the two frame mounts). take a 8" (or whatever you think is needed, im not an engineer) of steel tube, sleeve if over the area, and weld up one side (the other side will rotate inside) then drill a hole through it for a pin or a bolt.
    would that work?
  2. Aug 28, 2020 at 12:41 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    In theory, but it would be very tough realigning that hole to repin it after you are done
  3. Aug 28, 2020 at 12:50 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Swaybar disconnects have been discussed on here for years. Most people that want one eventually will just pull the sway bar and leave it off.
    Island Cruiser likes this.
  4. Aug 28, 2020 at 12:52 PM
    wolfman00
    matt
    '16 dclb
    yeah that part i have no idea haha. i guess you would have to reconnect it somewhere super flat and have a buddy shake the truck so you could pop the pin/bolt in.
  5. Aug 28, 2020 at 12:54 PM
    wolfman00
    matt
    '16 dclb
    right, my 2nd gen single cab had no sway bar, i threw it in the trash. I also had 620lb coils so i didnt really need it. it was pretty stiff.
  6. Aug 31, 2020 at 1:56 PM
    Checkers10160
    Checkers10160 Well-Known Member
    Chess
    Westchester/Fairfield
    05 Access Cab Long Bed
    OME 885s Bilstein 5100 Deaver AAL AP Sliders SOS Skids Rear diff breather relocation
    Yep, looked into disconnects, no one had done it, and I'm not savvy enough to design my own. Sway bar is now sitting in a pile of parts somewhere. Don't miss it
