Swaybar relocation?
Discussion in 'Suspension' started by dylandercole, Sep 22, 2009.
  1. Sep 22, 2009 at 9:00 PM
    dylandercole
    dylandercole [OP] Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    So my new coilovers come in a week and a half. does anyone know if i have to relocate my swaybar? Ive heard a lot of good things about just removing it completely but i do commute and need my truck to perform just as well on road as off. any input?
  2. Sep 22, 2009 at 9:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    What CO's are you getting?
  3. Sep 22, 2009 at 9:41 PM
    dylandercole
    Dylan
    I got Sway-A-way 2.0's (4 wheel parts gave me them for 600$ for messing up a previous order)
  4. Sep 22, 2009 at 9:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont think you need them for the 2.0's
  5. Sep 22, 2009 at 9:42 PM
    Trdman98
    Trdman98 Member
    98 tacoma 4x4 6"
    3" body, Toytec Coilovers, Dakars, Bilsteins, 33"BFGs, Intake, Exhaust
  6. Sep 22, 2009 at 9:43 PM
    dylandercole
    Dylan
    beautiful. makes my life easier. thanks chris.
  7. Sep 22, 2009 at 9:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  8. Sep 22, 2009 at 10:09 PM
    cjimenRR
    cjimenRR Be Good or Be Good At It
    North Hollywood, Ca
    12' Sport DC,LB, 4x4
    My sway aways 2.5 came with relocator brackets but i still had to grind some metal of my sway bar to stop it from rubbing against the coilover
  9. Sep 22, 2009 at 10:11 PM
    dylandercole
    Dylan
    well i really hope i wont have to do that
  10. Sep 22, 2009 at 10:17 PM
    cjimenRR
    North Hollywood, Ca
    the 2.0's aren't as wide so as long as you dont crank them you should be ok
  11. Sep 23, 2009 at 12:16 AM
    dylandercole
    Dylan
    crank them? like preload them a bunch? because i was hoping to get the most lift out of them i could because i have close to 4 in in the rear
  12. Sep 23, 2009 at 12:41 AM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    For less then 3" of lift,yes..you'll need the sway bar spacer.:)
  13. Sep 23, 2009 at 6:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Guys....He has a first gen. He should be fine.
  14. Sep 23, 2009 at 8:57 AM
    aww1970
    aww1970 Well-Known Member
    2009 Tacoma TRD Long Box
    Do you need this relocation with the 5100's set @2.5"?
  15. Sep 23, 2009 at 10:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    no.
  16. Sep 23, 2009 at 11:02 AM
    aww1970
    So on the aftermarket C/O's they have springs with greater outside diameters?
  17. Sep 23, 2009 at 11:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Some do. The "2..0" dictates the shock diameter. Larger diameter shocks have larger diameter springs.
  18. Sep 23, 2009 at 11:11 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    and new shocks wont have anything to do with changing the stock coil width..
  19. Sep 23, 2009 at 11:25 AM
    aww1970
    I ask because I am putting eibach springs on the 5100's (same coil as toytec I believe)
    My reasoning is they reccomend them with the toytec CO, so I should need them with the direction I am going.
    With my factory coil I have maybe 3/8" clearance to the sway bar.
  20. Sep 24, 2009 at 7:22 PM
    comajoe
    comajoe Well-Known Member
    rougemont, NC
    06 tacoma sr5
    are you refering to the tacoma 1.6" lift springs on eibachs site?
