Swaybar
Discussion in 'Bay Area Metal Fabrication' started by bjmoose, May 11, 2012.
  1. May 11, 2012 at 10:19 AM
    bjmoose
    bjmoose [OP] Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I'll just leave this here. No reason. :spy:
  2. May 11, 2012 at 10:21 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    No, I must know more!!! :eek:
  3. May 11, 2012 at 10:25 AM
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    Fascinating, moose. Utterly fascinating.
  4. May 11, 2012 at 10:31 AM
    Pugga
    Massachusetts
    Wait... shouldn't this thread be "BJMoose builds a swaybar quick disconnect" :confused:
  5. May 11, 2012 at 10:47 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
  6. May 11, 2012 at 10:56 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I don't weld. But I'm a demon with copy/paste. ;)
  7. May 11, 2012 at 11:09 AM
    Pugga
    Massachusetts
    BJMoose Presses Ctrl+C & Ctrl+V :p
  8. May 11, 2012 at 1:38 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    I do believe Mr. Bullwinkle is attempting to inspire our local fabricator.
  9. May 11, 2012 at 1:55 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Inspired :spy:
  10. May 11, 2012 at 1:59 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I just texted you some additional inspiration. :spy:
  11. Oct 3, 2012 at 6:37 AM
    GP3
    California
    4X4 TRD Off Road
    Yes please.
  12. Oct 3, 2012 at 7:15 AM
    JLee
    Jerry
    Benicia, CA
    No time for the R&D :(
  13. Oct 3, 2012 at 1:54 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    i would be down for one depending on price. prob willing to pay in the 400 to maybe 500 dollar rang. if it’s less than that, thats even better.
  14. Oct 5, 2012 at 4:34 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    :confused:
  15. Oct 5, 2012 at 8:52 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
  16. Oct 5, 2012 at 8:58 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Jerry's not exactly local anymore since I left the bay area.
    As for the axle, I was trolling my old build. That's not my axle. The truss is for a linked 4runner, not my truck, built by Infamous Metal Works in Santa Clara.
  17. Oct 5, 2012 at 11:56 PM
    sytfu510
    sytfu510 Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    What swaybar? on my DD and I do drive it like a race car. lol
  18. Nov 4, 2012 at 2:00 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Here's some info I posted in another thread on this topic.
    CMScheid likes this.
  19. Nov 23, 2012 at 7:15 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I did a little more research today.
    The "link end" is 5.5" center to center, and both ends are a 12mm bolt.
    The link replacement clearly has two "rod ends" and I'm guessing these are M12x1.75 link ends available from McMaster Carr as part number 59935K85 for about 12 bucks apiece. Those have a range-of-motion of 27 degrees, while the factory link ends seem to have a range-of-motion of 35 degrees. I'm guessing that 27 proves to be sufficient. Those things have a capacity of 5800lbs static load - they're probably strong enough.
    I'm not sure how the two disconnectable pieces that the rod ends thread into are fabbed up. Clearly they're drilled and tapped so that the rod end can thread into them. Then on one side there's an additional nut on the rod end so that it can be tightened after it's adjusted to exactly the correct length and angle orientation.
    It's not possible to buy steel tubing in any "off the shelf" size where the inside diameter of one is a sufficiently close "interference fit" to the other to fab up that link end.
    Finally, the two bolt disconnect bar end itself is interesting. The factory bar has a mild curve to it there. So building a disconnect fitting there has some art to it. Also, there's only an inch - perhaps a little less - from my 285/70R17 tires to the bar at that disconnect point when the wheel's turned to full lock. So unlike in this pic - I think the best attachment bolt option probably has the bolts vertical instead of horizontal and cutting into that limited tire space.
    When I started looking at it - I though I'd be able to make some detailed drawings with measurements so that pieces could be cut and formed based on the measurements.
    Now I think it's just going to be a matter of cut-bend-recut until a master piece is made right, and then use that to make a jig.
    That's not a skill I posses.
    Next time I'm up there, I'll give you the extra swaybar I got off of MJ - if you want it as a potential prototype part. But I conclude I don't really have the skillz to go any further with this.
  20. Nov 24, 2012 at 7:20 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    And now you guys know as much as I do:
