Swaybar
Discussion in 'Bay Area Metal Fabrication' started by bjmoose, May 11, 2012.
  1. Jan 12, 2013 at 10:14 PM
    #41
    bjmoose
    bjmoose [OP] Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    The risk is the same as if you completely removed the end link:
    The disconnected sway bar end is "out of sync" with the disconnected spindle and there's now the possibility the sway bar end can contact and tear the CV boot.
  2. Jan 12, 2013 at 10:19 PM
    #42
    DoorDing
    DoorDing Intentionally obtuse
    Bodie, CA
    2017 RC Off-Road 3.5WD
    yes
    If it was a telescoping arrangement, one end would be fixed to the knuckle and would move within the other end when a pin was pulled, which would keep its movement controlled. Think about a 7/8" OD rod sliding within a 1" ID pipe.
    I don't think that mechanism would be cheap or easy to construct, but it might work.
  3. Jan 12, 2013 at 11:24 PM
    #43
    rmarqu2
    rmarqu2 YES... i am a murse....
    Roger
    Baton Rouge
    09 Black 4x4
    FOX 2.5 coilovers, FOX 14" rears, AP expos, AP front plate bumper and skid, lightforce 240 blitz, warn m8000, 3/8 amsteel, BAMF sliders, cheap Chinese rock lights, ARB lockers all around
    I think it would be more practical and cheaper to just develope an easier and quicker way to just remove the whole sway system for offroading and then reassemble before getting back on the road. I guess it's relatively simple already, but I want FASTER!!!
  4. Jan 12, 2013 at 11:51 PM
    #44
    DoorDing
    Bodie, CA
    yes
    Even that could still be a PITA. Aftermarket bumper, winch, skid plate, all possibly in the way. You'd still need to store it somewhere when dismounted, too.
  5. Jan 13, 2013 at 12:17 AM
    #45
    rmarqu2
    Roger
    Baton Rouge
    09 Black 4x4
    That's what they make friends with 4runners for!
  6. Jan 13, 2013 at 9:16 AM
    #46
    DoorDing
    Bodie, CA
    yes
    True. If they get KDSS, the least they can do is carry our loose parts.
  7. May 1, 2013 at 4:15 PM
    #47
    Slesse
    Slesse Tacoma level 27
    Kyle
    Port Coquitlam
    08 Tacoma
    Pro Comp Rims;32" Duratrack Tires; OME heavy duty lift in rear; 2" spacer lift in front; custom raised bed in box; Lear canopy; grillcraft grill; Rosen Head unit; Trail gear sliders; Tinted windows all around; Intermittent Wipers; White LED dash; Deactivated seat belt buzzer; Blue Sea Fuse panel; BAMF light bar running 4 Lightforce 170's (2 HID); FX-R retro HID's 4300k, with amber halo's, BHLM with black reflector bowl; stealth mode; Fenix Hide-a-way flashers as DTRL's; VIAIR OBA kit with 2.5 gal tank; 14" Magnaflow stainless steel cat back exhaust; de-badged; Hybrid badge applied; seasonal 4wheel camper "Fleet"
    Can't you just call it an "off road" only type device and "not for highway use"
  8. Jul 6, 2013 at 11:02 PM
    #48
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
  9. Jul 7, 2013 at 6:04 AM
    #49
    DoorDing
    Bodie, CA
    yes
    Good luck!
