swaying
Discussion in 'Suspension' started by Nailer28, Jun 30, 2009.
  1. Jun 30, 2009 at 2:19 PM
    Nailer28
    Nailer28 [OP] Well-Known Member
    New Hampshire
    05 tacoma
    Billet Grill Dual flowmaster K/n
    hi guys just got done lifting my 05 with a 3'' lift one ?? when i drive it it seems to sway back and forth a little i have not gotten it aligned yet will getting it aligned help or is the swaying normal please help makes you feel ill to drive it but it looks awesome
  2. Jun 30, 2009 at 2:27 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah,chances are,caster and camber are out some, and that will make it sway. get a good alignment,and you should be good to go.
  3. Jun 30, 2009 at 2:29 PM
    GotLift37
    GotLift37 Bangers Runner
    North East AL
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion WMW roof rack
    dont drive to long without getting an alighnment. depending how much the alighnment is off, it could eat your tires away much faster than normal wear
  4. Jun 30, 2009 at 2:29 PM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    I couldnt get my alignment to spec without throwing on new UCA's. Hopefully you wont have the same problem.
  5. Jun 30, 2009 at 2:36 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    After my lift my truck was pretty close to stock alignment. I suppose it was off from the factory and my lift evened it ou.
