Sweet Deal for Me, but Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Evans381, Apr 10, 2010.
  1. Apr 10, 2010 at 4:32 PM
    Evans381
    Evans381 [OP] Well-Known Member
    Ty
    Rome, Georgia
    06 PreRunner
    Toytec ultimate coilovers. 5% Window tint. 40% windshield. Kenwood DDX372BT Monitor. JL Audio 12w0v3 subwoofer set in ported Q-Bomb box. 20" Gear Alloy Recoil wheels wrapped in Cooper Zeon LTZ tires
    So a buddy of mine has a white TRD Sport and wants MY black handles and mirrors. So we gonna do a swap and I'll get his color matched ones! SWEET! I kno right. So anyway about that. Im pretty sure its just one bolt under the mirrors to get them out. But the handles... are they just as easy? Little advice please
  2. Apr 10, 2010 at 5:07 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
  3. Apr 11, 2010 at 4:06 PM
    Evans381
    Ty
    Rome, Georgia
    06 PreRunner
    Anyone know if I was right on the mirrors? And it says I need to remove the rear door panels to get the rear handle out. Is this true?
  4. Apr 11, 2010 at 4:23 PM
    white91formula
    white91formula Well-Known Member
    Boston, MA
    05 6speed TRD OR
    you need to remove the door panels to get the mirror off, there is 3 bolts that hold it on and you need to unplug the electrical connector. the 1 bolt that is on the bottom of the mirror will not take it off of the truck.
    as for the handles i have never done it myself but you will most likely have to take off the doro panels, every vehicle i have ever had was 2 nuts on each handle that you get to from the inside, and you will also have to disconnect any of the actuator rods that are connected to the handle.
  5. Apr 11, 2010 at 5:37 PM
    Evans381
    Ty
    Rome, Georgia
    06 PreRunner
    Last bit of help guys... Everything is done except the rear handles. I got the panels off and one screw but the handle wwont come loose. IDK if you just to need to use force or what but someone please inform me.
  6. Apr 11, 2010 at 6:21 PM
    Evans381
    Ty
    Rome, Georgia
    06 PreRunner
    Bump come on guys, nobody knows this?
  7. Apr 11, 2010 at 6:55 PM
    barlowrs
    barlowrs Well-Known Member
    Robert
    So Cal
    06 Toyota Tacoma Sport 4x4
    Build Thread: http://www.tacomaworld.com/forum/builds/74926-barlowrs-06-taco-expo-build-thread.html OME Lift, FJ SE Wheels, 255/85 KM2, Allpro Plate Bumper, 8K Winch, Synthetic Line, Yaesu FT-8800R, Custom Sliders Sockmonkey bedside decals, BHLM, base model grille, TRD offroad (black) trim
  8. Apr 11, 2010 at 6:56 PM
    barlowrs
    Robert
    So Cal
    Sorry I had access cab, but I believe the link I posted was for a double cab.
  9. Apr 11, 2010 at 6:57 PM
    Evans381
    Ty
    Rome, Georgia
    06 PreRunner
    Thankyou SO MUCH buddy. Im in the process right now and the only thing i gotta do it the back door handles. Everything else is done.
  10. Apr 11, 2010 at 6:59 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Yes, you need to remove the rear door panels in order to change the rear door handles.
    Here are the instructions on how to do so.
    EDIT: Beaten by barlowrs!
  11. Apr 11, 2010 at 7:18 PM
    Gorilla_97
    Gorilla_97 Once a gorilla always a gorilla
    Thomas
    Fort Worth, TX
    08 FJC Black Diamond
    damn, that's alot of steps to just change out the door handles!
  12. Apr 11, 2010 at 7:29 PM
    KPT
    09 Prerunner
    It was worth it. Love my white door handles!
  13. Apr 11, 2010 at 7:38 PM
    Evans381
    Ty
    Rome, Georgia
    06 PreRunner
    Yes I already did that BUT how do you get the handle out??? I have a DCab. Force?
  14. Apr 11, 2010 at 7:41 PM
    Evans381
    Ty
    Rome, Georgia
    06 PreRunner
    Ok I see now by your PDF KPT. So I have to remove not only the panel but all the metal and everything?
  15. Apr 12, 2010 at 12:09 AM
    KPT
    09 Prerunner
    no once you remove the panel you should see a torx screw. unscrew that, then it should all just pop out.
  16. Apr 13, 2010 at 8:33 PM
    Evans381
    Ty
    Rome, Georgia
    06 PreRunner
    Ok man so let me get it straight. On the REAR handles I took the panel off. Pulled the plastic back and found 1 screw. I took it all the way out. I could find any other screws and i cant really see back into it so let me know if Im missing something cause I took the 1 screw out and gave the handle a little force but no dice.
  17. Apr 14, 2010 at 5:41 AM
    KPT
    09 Prerunner
    So you took the one torx screw out...and then pulled the smaller part of the handle straight out (the part that has the key hole on the front doors)?
    Once you do that, you can slide the handle towards the back of the truck, then rotate out to remove, similar to on the front doors.
  18. Apr 14, 2010 at 6:13 AM
    Evans381
    Ty
    Rome, Georgia
    06 PreRunner
    No, from what I saw when I did it I dont think I can get back in there to see it. The metal panel hole I too small, Unless I didn't take something off. All I could see was where the handle part is. There is a black plastic piece that looks like its holding the handle on and I took the only screw I saw in it all the way out. The metal is blocking me from seeing the back part of the small piece. Are we talking about the same torx screw? The one I took out was in the middle of the lever part of the handle. And when I tried to remove any part of the handle, it still wouldn't budge. I'll prolly just have to take a pic cause you prolly don't understand this. lol
  19. Apr 14, 2010 at 7:30 AM
    KPT
    09 Prerunner
    Yeah man a pic would help. It's been 6-7 months since I did this.
  20. Apr 14, 2010 at 6:22 PM
    Evans381
    Ty
    Rome, Georgia
    06 PreRunner
    Bump... anyone else have some input? Im doing it tomorrow.
