Swimming Pool
Discussion in 'Garage / Workshop' started by PROseur, Dec 15, 2016.
  1. Dec 16, 2016 at 12:00 PM
    #101
    PROseur
    PROseur [OP] Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Update from owner:
    Owner called. Said this is how we feed our families, so please think of us. Additionally said, the "$22" charges last month and this month were "mistakes" and will credit us the amount.
  2. Dec 16, 2016 at 12:10 PM
    #102
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Even know you may not want to be a Certified Pool operator as I have been for several years now. You may want to check here to see if they have classes in your area...Pools can and will be a pain in the ASS is you don't understand water chemistry things can go wrong in a hurry. Green water,cloudy water,Hard water,black algae,green algae,mustard algae, cyanuric acid issues etc: If you have a marcite pool having jacked up chemicals it will suck the calcium right out then you have to re-plaster pool...
    Fuck pools!
    https://www.nspf.org/course-locations
    linkgoesnowhere and PROseur[OP] like this.
  3. Dec 16, 2016 at 12:14 PM
    #103
    PROseur
    Pussy
    Appreciate that!
  4. Dec 16, 2016 at 12:17 PM
    #104
    IPNPULZ
    going to be fun!
    Contact (Click Name for Details) Date Range[​IMG] Contact Website Type City Online & 1-Day Course [​IMG] Spanish Materials [​IMG]
    Charlie Neidlinger
    12/22/2016 and 12/23/2016
    Website English Oakland Yes Yes
    Charlie Neidlinger
    01/23/2017 and 01/24/2017
    Charlie Neidlinger
    02/22/2017 and 02/23/2017
    Tim Auerhahn
    03/16/2017 and 03/17/2017
    Website English Chula Vista Yes Yes
    Charlie Neidlinger
    03/21/2017 and 03/22/2017
    Steve Donohoe
    03/23/2017 and 03/24/2017
    Website English Santa Clarita Yes Yes
    Steve Donohoe
    Website English Santa Clarita, Yes Yes
    Heather Patricia Pierce-Sifrit 04/02/2017 Website Playa Del Ray Yes
    Heather Patricia Pierce-Sifrit 04/09/2017 Website Playa Del Ray Yes
    Heather Patricia Pierce-Sifrit 04/30/2017 Website Playa Del Ray Yes
    Heather Patricia Pierce-Sifrit 05/07/2017 Website Playa Del Ray Yes
    Heather Patricia Pierce-Sifrit 05/16/2017 Website English Playa Del Ray Yes
    Armando Esparza
    05/17/2017 and 05/18/2017
    Website English South Lake Tahoe Yes Yes
    Steve Donohoe
    07/20/2017 and 07/21/2017
    Welcome to the NSPF F
  5. Dec 16, 2016 at 12:22 PM
    #105
    PROseur
    Pussy
    Yeah I can do the one in march in Santa Clarita
  6. Dec 16, 2016 at 12:45 PM
    #106
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Really, the only time you need to pull that thing apart and clean off the filter grids is if you are having water quality issues or if the pressure doesn't drop considerably after backwashing. Is there any kind of mark on the pressure gauge that shows when it's too high and needs to be backwashed? We always did that so that no matter who the tech was that showed up, it would be obvious if the filter needed service.
  7. Dec 16, 2016 at 12:45 PM
    #107
    PROseur
    Pussy
    No marks
    Pressure is indixated at 15psi
  8. Dec 16, 2016 at 12:49 PM
    #108
    Maticuno
    2011 Suburban 2500
    Do you know the last time it was backwashed? If it's been a while, I'd backwash it and then use a Sharpie to mark the normal pressure level and if it gets too high from there you know it needs it again.
  9. Dec 16, 2016 at 12:54 PM
    #109
    PROseur
    Pussy
    I am not sure what back wash means
    The filter was opened and cleaned out in august
  10. Dec 16, 2016 at 1:02 PM
    #110
    Maticuno
    2011 Suburban 2500
    The way your filter works, is the "leaf" shaped grids hold onto diatomaceous earth (DE), which is a very fine filter material with lots of internal surface area that trap fine particles flowing through the filter. After a while, the DE gets fully saturated with crud and reduces system performance by restricting flow. Backwashing essentially flows the water in the opposite direction and blows the dirt out the open pipe coming from the bottom of your filter.
    PROseur[OP] likes this.
  11. Dec 16, 2016 at 1:03 PM
    #111
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Backwash means you turn a valve then turn the pump back on and it washes the DE out and down a drain. Have water filling the pool at same time. do not let the water level get lower than the skimmers.
  12. Dec 16, 2016 at 1:05 PM
    #112
    PROseur
    Pussy
    Where would this valve be ?
  13. Dec 16, 2016 at 1:05 PM
    #113
    PROseur
    Pussy
    Thank you
    linkgoesnowhere likes this.
  14. Dec 16, 2016 at 1:06 PM
    #114
    PROseur
    Pussy
    Yeah the pool company owner in august took out all the leaves and washed each individually in front of me in August
  15. Dec 16, 2016 at 1:07 PM
    #115
    Maticuno
    2011 Suburban 2500
    I believe on your particular filter, it is a stainless steel or chrome handle sticking out of the bottom of the filter, underneath where the stand is. Push it fully one way to open and the other way to close. Similar to this:
    PROseur[QUOTED][OP] likes this.
  16. Dec 16, 2016 at 1:08 PM
    #116
    PROseur
    Pussy
    I will go out and check it out
  17. Dec 16, 2016 at 1:09 PM
    #117
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Usually I just take mine out and rinse it down with a hose attached to a low pressure nozzle. Works for me.
  18. Dec 16, 2016 at 1:10 PM
    #118
    Maticuno
    2011 Suburban 2500
    Come out of the bottom of your filter should be a total of three pipes:
    1) one coming into from the pump
    2) one coming out of it and returning to the pool, likely attached to pipes sticking out of the ground
    3) the backwash line which is a dead end, open line that likely has a hose clamp on the end of it
  19. Dec 16, 2016 at 1:10 PM
    #119
    PROseur
    Pussy
    So you don't backwash
    Just take the leave like things out of filters and wash it out ?
    That is what I saw the owner of the pool company do it
  20. Dec 16, 2016 at 1:14 PM
    #120
    Maticuno
    2011 Suburban 2500
    Taking them out and cleaning is an unnecessary step if everything is working properly. If a simple backwash gets the pressure down and your water is otherwise crystal clear, don't mess with taking the filter apart.
    When you backwash, a ton of nasty brown water is going to come out of that open pipe I mentioned. If the pool equipment is in an area where the water will easily drain away without causing issues, then you can just let it fly right there. Otherwise, you need to hook up a hose to the end of that pipe and run it to a good drainage location before starting the backwash.
