Swisha Loop 2018
Discussion in 'Ontario, Canada' started by tacoma16, Sep 24, 2017.
  1. Mar 15, 2018 at 10:39 AM
    #241
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Pretty much what I got except for the spring mount. I take my mount on and off if there is low roofs. On the trail the antennae flexes. Also I didn’t check but make sure your antennae is adjustable with a screw and not cutting it.
    llamasmurf[QUOTED] likes this.
  2. Mar 15, 2018 at 10:40 AM
    #242
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    2015 Matte Black TRD ACOR
    FJ t-case with twin sticks and some other things :D
    Yes it is the screw tip one, no cutting.
    I do not want a 4' antenna, but I want the best reception possible. I figured a 3' with a spring is what would get me the height I am after.
  3. Mar 15, 2018 at 10:56 AM
    #243
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    When I was doing my research for my cb setup I found alot of people complaining that the firestick would break because of its weight. Some people even had issues with a spring. I looked at quick connect connectors but they don't seem to hold the best. All it takes is one time failure and say goodbye to your antenna. Get marine rated cable, makes a difference. Better shielding and better connectors. I have a swr meter you can use to set up the antenna if you want. I used it once and it's just sat in the garage ever since. MPD Digital RG8x-W-PL259 cable seems to be the best. You can also get connectors with a removable outer thread so it makes it easier to run the cable. Pl259 connectors are fucking large.
    llamasmurf likes this.
  4. Mar 15, 2018 at 11:00 AM
    #244
    llamasmurf
    Wes
    Northern Ontario
    I was hoping the 3' one would not have the issues with weight.
    Yea I was going to look at cable once I figure out the 1st mounting location. The removable outer thread is for sure what I want to run it easier.
    Thyces[QUOTED] likes this.
  5. Mar 15, 2018 at 11:06 AM
    #245
    Thyces
    Ontario
    2009 DCLB TRD Sport
    From what I read it's the RG8x rating that's important. When I switched mine out to the better one I got rid of alot of interference. Where are you planning on placing? I believe it's best on an area where the antenna has direct "view" front and back (roof would be best but really impractical) if your thinking at the end of the bed I can make you a bracket.
  6. Mar 15, 2018 at 11:12 AM
    #246
    llamasmurf
    Wes
    Northern Ontario
    That's the problem, I duno yet.
    For my tent, it can not be a sticking out of the bed anywhere, as my tent drapes over the entire outside of the bed. I was getting that mount to hopefully put it on the hood line. I might be able to use the CBI ditch brackets I am buying from Eugene but that will not be until later on in the summer. I want it working, not 'maybe working :cookiemonster:. I can always move it around later on.
  7. Mar 15, 2018 at 5:41 PM
    #247
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    @Kemosabe don't u have a firestick for sale?
    Kemosabe likes this.
  8. Mar 15, 2018 at 5:47 PM
    #248
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    Nahh decided to keep it lol i was going to get a 4' from a International truck's shop but I think they are not tunable... firestick works really good! And I don't think @llamasmurf want a 5' long lol
    llamasmurf and Bocsy44[QUOTED] like this.
  9. Mar 15, 2018 at 6:21 PM
    #249
    llamasmurf
    Wes
    Northern Ontario
    Yea 5' is to long for what I need. I am going to purchase all my stuff tomorrow on Amazon after I sleep on it tonight and see if I need anything else.
    Kemosabe[QUOTED] likes this.
  10. Mar 15, 2018 at 6:51 PM
    #250
    Kemosabe
    Louis
    I'd recommand a very flexy antenna, firestick are good but very bulky... and not that much flexy. Perfect for DD and forestry roads, but when on a tight trail I am always wondering if i'll break it lol I have a spring but still... it bounces a lot lol
  11. Mar 15, 2018 at 7:15 PM
    #251
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Look into Wilson dude. They are the main competitors of firestik but use 3/8 mount instead so you won't be limited to over priced firestik shit. Ive been happy with mine. Can't remember if it's 4' or 3' though but it's been good so far.
  12. Mar 16, 2018 at 1:43 AM
    #252
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I started using a Wilson too. Then I lost the stupid rubber cap for it. Now I use a cheapy.
    llamasmurf and Joe23 like this.
  13. Mar 16, 2018 at 3:36 AM
    #253
    Joe23
    Put electrical tape to hold it in next time
    Mine was like $28 from a place in Whitby.
    tacoma16[QUOTED][OP] likes this.
  14. Mar 16, 2018 at 5:49 AM
    #254
    llamasmurf
    Wes
    Northern Ontario
    So you are saying this stuff is what I should be getting?
    https://www.amazon.ca/MPD-Digital-R...7&sr=8-5&keywords=rg8x+coax+cable+with+pl-259
  15. Mar 16, 2018 at 6:02 AM
    #255
    Therby
    Therby Well-Known Member
    Kitchener
    Jeep JL
    Same, i have a cheap uniden for $50 on Amazon. 18ft regualar coax and a cheap $20 antenna snd have never had an issue, good for about 2km before I couldn’t hear them, not amazing but works good enough on the trail.
  16. Mar 16, 2018 at 6:29 AM
    #256
    llamasmurf
    Wes
    Northern Ontario
    If the firestick breaks ill get a cheaper one to replace it, all ordered.
    Now I can stop feeling like the kid sitting in the corner looking at the wall, I can be the kid screaming at everyone running around in circles.
    :ohsnap:
    So I was talking to my Dad, and he informed me my truck is lacking big time in some basic factory options, as his 78 Bronco had a factory CB.
    :facepalm:
    tacoma16[OP], Therby and Kemosabe like this.
  17. Mar 18, 2018 at 7:10 AM
    #257
    Joe23
    Maybe that's because CB was a thing back then now it's dated and many go with ham instead lol
  18. Mar 19, 2018 at 5:34 AM
    #258
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    People still interested
    1. @tacoma16
    2. @Tridet167
    3. @Joe23 (date permitting)
    4. @NorilskSever
    5. @Ttaco15
    6. @llamasmurf :cookiemonster:
    So far this is the group that we have... @NorilskSever, @Joe23 and myself have discussed the trip during a meet up and have compiled a list of things that may either be needed or things to consider. This trip isn't crazy but it is remote....remoteness can make things get hairy.
    We are at the part now that we are trying to set a date. Throw out suggestions. August also came up as an option as it wouldn't be too hot.
    Introduction
    The Swisha Loop is 800 kilometers route thru the south western portion of the province of Quebec. It is considered to be an intermediate type of route with a loose gravel for experienced drivers in off-road and remote driving. Ensure that your family and friends are aware of your trip.
    The length of the trip will be approximately 5 days, therefore please ensure you have enough food and water for that time, plus 1 more extra day in case of any emergency. This is not a trip for a first-time drivers or campers, so we expect you to know how to pack, store and plan food rations for such trips. You will be solely responsible for your food and water.
    It is mandatory to have absolute minimum vehicle requirements in order to safely participate with the group. At the beginning of our journey we will be double checking all those items in your vehicle. Ensure your vehicle is well maintained. There is always a chance of having flat tire or damaging vehicle, be prepared.
    Make sure you have enough cash in case if there is no credit machine available at the gas stations or local stores. There will be 3 ZEC (Zone d'exploitation contrôlée) check points that will require each person to pay around $5-15 to proceed the route and camp, please have the cash available.
    You are expected to have common sense and leave no trace after you left camping spot.
    Absolute Minimum Vehicle Requirements:
    o 32” AT Tires
    o 60 liters of fuel in fuel containers
    o Basic med kit
    o Fire extinguisher
    o Shackle
    o Recovery strap rated for at least 15,000 lbs.
    o Front and rear tow points
    o CB Radio & GMRS/FRS radio
    o Air Compressor
    o Spare tire, must be full spare with the same size/tread style
    Recommended Vehicle Requirements:
    o 33” AT/MT tires
    o 80 liters of fuel in fuel containers
    o Steel sliders
    o Aluminum or steel skid plates
    o Winch and knowledge how to use it
    o Shovel
    o Traction boards
    o Tire repair kit
    Cooking & Food:
    Each time we stop overnight to camp, we will be setting up designated location for cooking away from the camp. It is essential not to cook near your sleeping area or trucks. Also, ensure your food is well sealed and does not produce any smell that will attract wild animals to a campsite.
    Ensure you have at least 20L of drinkable water and enough dry food. If you plan on brining meat or any heat sensitive food, ensure your cooler can hold cold temperatures for the time being. Best would be to have 2 coolers, one for food another for all your drinks. There could be a ban on having open fire, so think about all possible situations that can happened during camping.
    Camping Gear:
    Each person should bring whatever works best for them while being outdoors, it is up to you, there could be chances of a wet ground or un-even surfaces, be ready for that if you plan on setting up the tent.
    Bring warm clothes, bug sprays and other things that you should already know to take. Weather can be unpredicted, so be ready.
    Details of the actual trip will be given to those that are going via PM. Any questions, please ask @NorilskSever @Joe23 or myself.
    Joe23, Therby and llamasmurf like this.
  19. Mar 19, 2018 at 6:12 AM
    #259
    Joe23
    Given you and Eugene got to hear some of my delightful experiences from Skye with my ibs I'll just say it to remind people.
    Bring plenty of toilet paper and wet wipes.
    Also a good idea to have any sort of diarrhea meds. Never know what could happen and shitting your brains out is not fun.
    Also consider one of those portable toilet type things whether it's a composting toilet or bucket and bags .I haven't looked it up yet but some areas you're not supposed to dig a hole and bury your turd.
    Water purification is a good idea for back up. I've done it before and have the stuff so I'll probably be relying on this more than what I carry
    Therby likes this.
  20. Mar 19, 2018 at 6:22 AM
    #260
    llamasmurf
    Wes
    Northern Ontario
    Yea we just started to finalize our list, and the toilet via a bucket with bag's is I believe the route we will be taking.
    I can not like your post, ibs is not a likeable thing.
    Joe23[QUOTED] likes this.
