Swisha Loop 2018
Discussion in 'Ontario, Canada' started by tacoma16, Sep 24, 2017.
  1. Mar 19, 2018 at 4:13 PM
    #301
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Down.
    llamasmurf and Norilsk[QUOTED] like this.
  2. Mar 19, 2018 at 4:13 PM
    #302
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I believe so...from my research
    Therby likes this.
  3. Mar 19, 2018 at 4:25 PM
    #303
    Thyces
    Ontario
    2009 DCLB TRD Sport
    That was my conclusion also, based on all the video and info I've run across. Would I be wrong to assume Ardbeg has shorter but more technical trails?
  4. Mar 19, 2018 at 4:26 PM
    #304
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
  5. Mar 19, 2018 at 4:30 PM
    #305
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    not to sure...they may have fixed it, bit cant say for sure...
    Kemosabe likes this.
  6. Mar 19, 2018 at 4:32 PM
    #306
    Joe23
    possibly find if there is a bypass to said washout since most of us won't be able to do it.
    And its not a matter of just removing bumper for that part as HC you usually cut portions of your bed side so even if bumper is off you'll hit those first.
  7. Mar 19, 2018 at 4:33 PM
    #307
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    yep..may have to do a bit of trail building and the use of traction boards...
    llamasmurf, Thyces and Joe23[QUOTED] like this.
  8. Mar 19, 2018 at 4:34 PM
    #308
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Shovels do wonders in the right hands.
  9. Mar 19, 2018 at 4:53 PM
    #309
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    I can tell it is not fixed lol municipality funds are too low to fix a washout that big, so they'll wait on woodsman to get a contract there and they'll maybe fix it, or make a bypass. Maybe there is already a bypass, i'll know it the 3rd week end of May
  10. Mar 19, 2018 at 4:57 PM
    #310
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    keep us posted!
    Kemosabe[QUOTED] likes this.
  11. Mar 19, 2018 at 5:11 PM
    #311
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    No by pas that I know of. That was a long narrow stretch before and after that washout. Also it has gotten much worse since we were there. Here is a video from last summer. I have confirmation that this is in fact the same spot.
    https://youtu.be/AedeLdBCcPk
  12. Mar 19, 2018 at 5:24 PM
    #312
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Should be a good time!
    llamasmurf and Joe23 like this.
  13. Mar 19, 2018 at 5:28 PM
    #313
    Kemosabe
    Louis
    FYI guys that guy with the LandCruiser lives in Ottawa
  14. Mar 19, 2018 at 5:36 PM
    #314
    Therby
    Therby Well-Known Member
    Kitchener
    Jeep JL
    Should be doable, i guess this is the standard. If you or your truck cant do this based on the video, rethink it possibly. Unless his report says its been fixed or bypass
    tacoma16[QUOTED][OP] likes this.
  15. Mar 19, 2018 at 5:40 PM
    #315
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I don't know.... I honestly think 3 guys that can actually work can make that passable for a stock truck in about 3-4 hours.
    Joe23, tacoma16[OP] and Norilsk like this.
  16. Mar 19, 2018 at 5:42 PM
    #316
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    There is nothing impossible if there is a bottle of whisky/vodka. Just saying, might as well reconstruct the whole area. :rofl:
  17. Mar 19, 2018 at 5:43 PM
    #317
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Bailey Bridge!
    Norilsk[QUOTED] likes this.
  18. Mar 19, 2018 at 5:58 PM
    #318
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    this is true. Based on the video and the blackflies, being outside for that long may not be doable. See how it goes. worst case winch work, and some hand work will do wonders.
    Thyces[QUOTED] and Joe23 like this.
  19. Mar 19, 2018 at 5:59 PM
    #319
    Joe23
    trail building.
    stack some recovery boards and rocks to keep the back end up.
    Thyces likes this.
  20. Mar 19, 2018 at 6:06 PM
    #320
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I didn't take bugs into account....
