Swisha Loop 2018
Discussion in 'Ontario, Canada' started by tacoma16, Sep 24, 2017.
  1. Mar 21, 2018 at 9:25 AM
    #361
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Could always get ARB elements fridge. Good to be outside.
    That said the one I got from you I'm still not sure if it can be out or not. I haven't found anything saying no and Ronny Dahl had the same one on the outside for a little
    Therby likes this.
  2. Mar 21, 2018 at 10:19 AM
    #362
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    You can have it outside, but don't call the ARB warranty department after lol
    It's not water resistant, so I would imagine any water on the motor will blow it
    Joe23[QUOTED] and Therby like this.
  3. Mar 21, 2018 at 10:20 AM
    #363
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Alright now I have to build a cardboard one, in the correct dimensions as the large ARB 50 Quart.....to make sure it fits. It is going to fit correctly BEFORE I buy anything :cookiemonster:
    If I have to remove the rear seats to make it fit that is fine, just have to figure it out.
    External Dimensions: H508mm x W380mm x D705mm
    Therby likes this.
  4. Mar 21, 2018 at 11:50 AM
    #364
    Norilsk
    Eugene
    Well my 37 qt didn't fit in so that front passengers can sit comfortable and recline to a full potential of the seats, so you are asking too much from the 50qt size :goingcrazy:
    Unless you like to sit at 90 degree straight all the time
  5. Mar 21, 2018 at 11:57 AM
    #365
    llamasmurf
    Wes
    Northern Ontario
    Did you fully modify the back and remove the seats?
    The dimensions on the 37 and 50 quart are only different in height, not width
  6. Mar 21, 2018 at 12:02 PM
    #366
    Norilsk
    Eugene
    I did not, but you need 1-2" from each side for motor to cool, it will fit, but not be too comfortable I test fitted it without removing the back panel, just by putting it on the seats.
  7. Mar 21, 2018 at 12:14 PM
    #367
    llamasmurf
    Wes
    Northern Ontario
    Yes I will remove every single thing in the back of the truck if needed to fit it, you under-estimate my need for this item to be in the truck :cookiemonster:
    Therby and Norilsk[QUOTED] like this.
  8. Mar 21, 2018 at 5:01 PM
    #368
    llamasmurf
    Wes
    Northern Ontario
    Decent camp stove was on sale still at cnd tire, so I picked it up.
    The list is getting pretty short now!@
    :evil:
    tacoma16[OP], Therby and Norilsk like this.
  9. Mar 21, 2018 at 5:52 PM
    #369
    Joe23
    besides truck mods dont think there's really much else I need.
    llamasmurf[QUOTED] likes this.
  10. Mar 21, 2018 at 6:07 PM
    #370
    Therby
    Therby Well-Known Member
    Kitchener
    Jeep JL
    Seen that one i think. I just bought a coleman 3 burner stove, off kijiji for $5. Old but works well, made in the USA still. Not sure if yours would be anymore?
    Always better and more stuff! My list has a little of everything. Some truck stuff, get CB hooked up properly, skids. Possible level kit. Awning for rack, tent. Luggableloo, trasharoo
    Jerry can holders for the bed, weld up something to secure them.
    Sounds like we have more time, is this August date the set one?
  11. Mar 21, 2018 at 6:07 PM
    #371
    llamasmurf
    Wes
    Northern Ontario
    I am brainstorming a mod for my water and gas jerry cans. Going to get my co worker who can weld to help me.
    Therby likes this.
  12. Mar 21, 2018 at 6:17 PM
    #372
    Joe23
    I dont think its certain yet but possibly the date.
    Nemo Helio https://www.mec.ca/en/product/5053-815/Helio-Pressure-Shower
    Eugene an I both have one. Works good plus just a 20L water can like the ones from crappy tire should be fine thats what I'll be using. And bringing my water purifier just in case.
    Jerry cans I'll probably just ratchet strap them down. Would be nice to have a proper carrier but anything like that will just add more weight and I'm starting to consider lightening the load. Might go more minimalist for my kitchen too.
    Instead of having two different pots, cast iron pan, coleman stove and what not might just go with the cup from my canteen, pot from my solo stove and the stove itself (twig stove) and maybe a small MSR single person stove. Like the ones that just go on top of the isobutane cans.
    Would drastically reduce weight. Also probably won't bring my tent as well.
    Then again majority of my gear outside the coleman stove is relatively light weight backpacking stuff. So not sure how much I can really save that way.
    If anyhting I might do strictly fridge and not cooler as well as cooler adds lots of weight in ice packs too. So thinking just fridge, would just mean limited alcohol but meh.
    Really not sure yet. Hell I'm not even certain I can make the trip
    Therby[QUOTED] likes this.
  13. Mar 21, 2018 at 6:24 PM
    #373
    llamasmurf
    Wes
    Northern Ontario
    Yep I hear ya about weight, but I want a jerry can setup anyway so this is the time to get it done right.
    I am taking every single thing into consideration right now for weight savings.
  14. Mar 21, 2018 at 6:29 PM
    #374
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I still have to finish “building” my truck. Or rebuilding...have to redo all my electrical and now lockers and ObA and OBW (kind of)
    Therby likes this.
  15. Mar 21, 2018 at 6:29 PM
    #375
    Joe23
    thing is water and fuel are both going to be a substantial amount of weight.
  16. Mar 21, 2018 at 6:33 PM
    #376
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Yup. Have to make sure that weight isn’t thrown around.
    I’ll personally be carrying 80L of fuel (maybe more as it will be cheaper to haul it in than buy there...) and 40L of water in 2 20L container. Plus I usually carry 10L in 5L containers you get from the store that I keep in my fridge.
    llamasmurf likes this.
  17. Mar 21, 2018 at 6:33 PM
    #377
    llamasmurf
    Wes
    Northern Ontario
    That is why I have to have them secured correctly
    tacoma16[OP] likes this.
  18. Mar 21, 2018 at 6:36 PM
    #378
    Norilsk
    Eugene
    Minimize weight, take only necessary items, we all seen what happens when you are a heavy pig on the trail, tsk tsk @tacoma16
    My list is the following:
    - 75Qt cooler for water, beers and some heat sensetive food for the first 2-3 nights.
    - single burner stove using butane
    - plastic cups, plates and knifes
    - buckwheat, pasta, vegetables
    - MRE/Ramen noodles for being lazy at some point
    - 20L of bottled water, 50% will be frozen prior
    - 60L of gas
    - 20L of water for other things
    - Nemo Helio for quick showers or whatsoever
    - Nemo portable shower tent
    - Single person tent
    - Sleeping bag and whatever I need to sleep
    - Some clothes
    - All the minimum and recommended requirements (fire extinguisher, med kit etc)
    - Bottle of a good Vodka
    You can use the adjustable ratchet bar @llamasmurf sold at Princess Auto, it will keep things in place, that's what I will be using.
    Therby and tacoma16[OP] like this.
  19. Mar 21, 2018 at 6:37 PM
    #379
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I usually have strapped them down. However depending on the gear you are bringing you may need to find another method such as a tray bolted down and the cans strapped within that tray.
    All I know is my old setup was extremely tight. Stuff didn’t move but it was a pain in the dick to get stuff out.
    Weight shouldn’t be a problem now @NorilskSever but for those new to the game....Dem bed sides though...
    All from my cap.
    llamasmurf[QUOTED] and Norilsk like this.
  20. Mar 21, 2018 at 6:43 PM
    #380
    llamasmurf
    Wes
    Northern Ontario
    Yea a simple tray system that is modular so I can add and remove water and gas cans, held in place with ratchet straps for easy in out. This is my idea anyway. We will see how bad it fails.
    These are the water cans I got, 2 of them.
    https://www.amazon.ca/dp/B000GKDFH4/ref=pe_3034960_233709270_TE_item
    Therby and tacoma16[QUOTED][OP] like this.
