Swisha Loop 2018
Discussion in 'Ontario, Canada' started by tacoma16, Sep 24, 2017.
  1. Apr 24, 2018 at 2:56 PM
    #581
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    That’s what I am doing but the fridge will be kept as a freezer and the new pelican cooler will be the fridge. Will constantly have items to be kept cold. In theory atleast. May have to have some ice packs or something in rotation between the fridge and freezer.
    Also what size is your arb? Plus it’s just you right? Different when you have two people and one of them can only eat certain foods
    Joe23[QUOTED], Therby and llamasmurf like this.
  2. Apr 24, 2018 at 5:02 PM
    #582
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    think its a 37qt @Norilsk ?
    But thats true, didn't think how its both you and karoline and wes and his wife.
    I wonder if draws significantly more power being used as a freezer. I was considering doing that as well just to freeze food instead and then whatever meal I would be having that day take it out and put it in the cooler. Helps keep the cooler cold and thaws out at the same time.
    llamasmurf, Norilsk and Therby like this.
  3. Apr 24, 2018 at 6:07 PM
    #583
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Exactly. Right now I will have 95 quarts of food/drink storage.
    I believe it will take more power to get it down to a certain temp. However if it is just maintaining that temperature it should be somewhat the same within reason.
    Other reason was the cooler is movable if needing to move food away from the sleeping area. Also can keep the cooler in the back of the truck (back seats) which can be reached as we are driving. The fridge is in the bed.
    Joe23[QUOTED] likes this.
  4. Apr 24, 2018 at 6:44 PM
    #584
    Joe23
    Mines reverse. Fridge in cab cooler in bed.
  5. Apr 24, 2018 at 7:04 PM
    #585
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    its the ideal way to do it, but based on where my second battery is its just easier to run power to the bed instead of back into the cab....
    Joe23[QUOTED] and llamasmurf like this.
  6. Apr 24, 2018 at 7:04 PM
    #586
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Yea this will be our setup as well
    tacoma16[OP] likes this.
  7. Apr 26, 2018 at 8:03 AM
    #587
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    if you haven't sent me your email please do. I will add you to the google doc with all the information.
    Therby likes this.
  8. Apr 26, 2018 at 10:11 AM
    #588
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    I wasn't able to access the document. It said it was waiting on permission acceptance.
  9. Apr 26, 2018 at 10:21 AM
    #589
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    On my end it is shared with you. I’ll try it again.
  10. Apr 26, 2018 at 10:32 AM
    #590
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    @Thyces shared it again. Make sure you are using the email you shared when trying to access it. Sometimes if you have a different email logged in it won’t work
  11. Apr 26, 2018 at 11:02 AM
    #591
    Thyces
    Ontario
    2009 DCLB TRD Sport
    So I bought this
    Inkbird 2 Stage Heating and Cooling Mode 12Vdc Digital Thermostat Temperature Controller https://www.amazon.ca/dp/B073FDF6VJ/ref=cm_sw_r_cp_apa_i_MHG4AbAZDD9WK
    And some thermal paste to increase the efficiency of this
    https://www.amazon.ca/Coleman-Quart...pID=41IcW2VnI2L&preST=_SX300_QL70_&dpSrc=srch
    By making it thermaly activated at a set temperature point. I opened it up and it has one of these
    TEC1-12706 TEC Thermoelectric Cooler Peltier Module CPU https://www.amazon.ca/dp/B00CDK1SL0/ref=cm_sw_r_cp_apa_i_snH4AbZYZ1YAM
    Which seem to draw 6 amp at max draw. I'll also be re insulating the outside of the cooler to increase efficiency. Online calculator says I can run 6 amp for 16 hours straight off my deep cycle marine battery.
    I'm thinking of running it off the truck during the day while driving and connecting to the secondary overnight.
    tacoma16[OP], Therby and llamasmurf like this.
  12. Apr 26, 2018 at 11:03 AM
    #592
    llamasmurf
    Wes
    Northern Ontario
    oh goodness,
    https://www.gaiagps.com just added Backroad Mapbooks overlays, looks like I am upgrading to premium.
  13. Apr 26, 2018 at 11:05 AM
    #593
    llamasmurf
    Wes
    Northern Ontario
    Until I get a 2nd battery, for the swisha loop my truck will be started twice maybe 3 times each night because I will be running my fridge all the time.
    Nice I have the factory remote start, which you can start and stop the truck. So I dont even need to get outa bed :cookiemonster:
  14. Apr 26, 2018 at 11:06 AM
    #594
    Thyces
    Ontario
    2009 DCLB TRD Sport
    It's not a deep cycle but I have a stock battery you can borrow for the trip if you'd like.
    llamasmurf likes this.
  15. Apr 26, 2018 at 11:15 AM
    #595
    llamasmurf
    Wes
    Northern Ontario
    No its ok, I dont want to use a battery that I dont have installed correctly or wired right.
    I have no budget for it this year, its a large undertaking to do it correctly. I will get by its no problem :cookiemonster:
    Pete needs to stop showing me things I have to buy, stupid jack. I knew I needed it but was just refusing to buy it.
    Thyces[QUOTED] likes this.
  16. Apr 26, 2018 at 11:28 AM
    #596
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Doing inventory, still need to get few more things.
  17. Apr 26, 2018 at 12:30 PM
    #597
    Therby
    Therby Well-Known Member
    Kitchener
    Jeep JL
    Im just going with a larger agm battery, single battery to run the fridge. Will run it for 24 hours no issues with my calculations. No need for a second battery. Dont plan on running anything else ever
    llamasmurf[QUOTED] likes this.
  18. Apr 27, 2018 at 10:15 AM
    #598
    llamasmurf
    Wes
    Northern Ontario
    What this local gent spoke has stuck with me hard, I have slept many a night thinking on it. I watched the ballsack out of Expedition Overland like the rest of you (@Joe23 <3's Clay) so the real evidence was shown that with out a chainsaw or saw's. It stops.
    I have gone well outside my budget this year as to prep for this trip and something like a chainsaw which I wanted anyway is not going to hold me back, so I just fuckin went hard at it.
    $80 used chainsaw in perfect nick, I can get all parts for it at my place of employment. It is a poulan service department.
    I believe in PPE, for everything. I like me the way I am with all my things attached and working. On my motorcycle I wear Kevlar lined double thick jeans with hip, and knee protection built in, and such.
    $320 in PPE to use the chainsaw, sure I could have spent less on the helmet, but I would be have been upset with a POS on my head and regretted it. So I bought the nicest one. Ever.
    *Edit* Yes I have steel toed boots, had them already.
    @Ttaco15 I had it all planned just needed to find the right stuff :cookiemonster:
    *Edit*
    One of the important things I do not have, is a winch. So depending on others for that, I can be relied on for the chainsaw. I felt like I needed to bring more to the table than what I had.
    Therby likes this.
  19. Apr 27, 2018 at 11:55 AM
    #599
    Joe23
    I swear if I ever see that guy I'll murder him. Can't fuckin stand Clay.
    Those are the proper chaps that jam the chain right?
  20. Apr 27, 2018 at 12:00 PM
    #600
    Joe23
    What fluids are you bringing
