Swisha Loop 2018
Discussion in 'Ontario, Canada' started by tacoma16, Sep 24, 2017.
  1. Apr 27, 2018 at 12:01 PM
    #601
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I’m bringing oil, coolant, diff/tcase, and a bit of tranny fluid.
    Bottle of each maybe. Just in case I rip a line or something.
    llamasmurf likes this.
  2. Apr 27, 2018 at 12:04 PM
    #602
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Given the trans is sealed you wouldn't be able to tell how much you need though.
    Gear oil and coolant are good though. But you need spare hoses then too, if you need coolant you need to stop the leak.
  3. Apr 27, 2018 at 12:06 PM
    #603
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I’m more concerned if a line breaks. I carry a bit of hose and would try to splice shit back together. Good to check hoses before.
    I may for instance change my serpentine belt prior to going. Old one has 200k so good to switch it up.
    For the tranny you have to fill it like the diffs. Pour until a bit comes out. At a certain temp mind you.
    llamasmurf and Joe23[QUOTED] like this.
  4. Apr 27, 2018 at 12:06 PM
    #604
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    They are actually full pants, not chaps.
    They meet the safety requirements for P.P.E 1-1997 Leg protection
  5. Apr 27, 2018 at 2:37 PM
    #605
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Th ones containing 95% :devil:
  6. Apr 27, 2018 at 4:59 PM
    #606
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Uhm, I can fill that requirement...96.7% as I recall without getting out of my chair
    Joe23 and Norilsk[QUOTED] like this.
  7. Apr 27, 2018 at 7:02 PM
    #607
    llamasmurf
    Wes
    Northern Ontario
    So after inspecting my 'perfect nick' chainsaw, I see it has a replacement bar on it that is 2" shorter than spec. Websites seem to say the blade is now obsolete and no longer can be provided by manufacturer. That is why it has this shorter bar.
    Good thing there is a box of the stock 18" ones at work on the shelf I had my hands in today. :cookiemonster:
    Service tech told me to bring it in and he will give it the once over to ensure its brand new again. He is going to rag on me for the 16" bar :facepalm:
    Kemosabe and tacoma16[OP] like this.
  8. Apr 28, 2018 at 8:28 AM
    #608
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    You make me think of this with your chainsaw lol
    llamasmurf[QUOTED] likes this.
  9. Apr 28, 2018 at 12:31 PM
    #609
    llamasmurf
    Wes
    Northern Ontario
    o_O
    :rofl:
    At least he beat the beaver :cookiemonster:
    Kemosabe[QUOTED] likes this.
  10. Apr 28, 2018 at 2:15 PM
    #610
    Therby
    Therby Well-Known Member
    Kitchener
    Jeep JL
    Princess auto special today.
    Everything to wire up the fridge.
    And jumper cables when my battery dies.
    And actually did some offroading/trying to jump in a subdivision being built, the multimatic shocks still impress me.
    Thyces, Kemosabe, Norilsk and 2 others like this.
  11. Apr 28, 2018 at 3:54 PM
    #611
    llamasmurf
    Wes
    Northern Ontario
    Looks like the fridge fits pretty good :thumbsup:
    I modified a bunch of 5/8 carriage bolts so I can have Male, or Female rail mounting options. I have 12 of the T-nuts that go in the rail. Sometimes you want beefier like 5/8 carriage bolt to mount something to.
    tacoma16[OP] and Therby[QUOTED] like this.
  12. Apr 29, 2018 at 4:37 PM
    #612
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    tacoma16[OP] and llamasmurf like this.
  13. Apr 29, 2018 at 4:49 PM
    #613
    Joe23
    i see a bottle jack in the picture under the seat on its side
    UP THAT SHIT NOW before it leaks.
    Just ask Peter he stored his on its side and it leaked. Same one you have from the looks of it too
    llamasmurf and Therby[QUOTED] like this.
  14. Apr 29, 2018 at 4:50 PM
    #614
    Joe23
    how well do they hold?
    thats actually a really good idea. I was just using weld nuts on end of a bolt but a carriage bolt would probably work better.
  15. Apr 29, 2018 at 4:55 PM
    #615
    llamasmurf
    Wes
    Northern Ontario
    I have had my axe and shovel mounted with them since I put them in, they hold perfect. :cookiemonster:
    I made my 1st ones on a bench grinder, it was not easy to do.
    This time I used an angle grinder + vise and it was super easy.
    Having access to all this stuff now has enabled me to actually do shit I have had on my list for so long. All the tools just waiting to be used instead of me having to buy them lol.
    tacoma16[OP] likes this.
  16. Apr 30, 2018 at 9:39 AM
    #616
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Tested out my fridge set up to make sure it can cool consistently. Worked over night kept itself between 3.5° and 6°. Cooled itself from 22° to 3.5° in 3 hours. Not bad for a $40 investment.
  17. Apr 30, 2018 at 10:27 AM
    #617
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Curious to see how it does when it’s hot outside.
  18. Apr 30, 2018 at 10:47 AM
    #618
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Me too. I'm planning on wrapping the outside of the cooler with a layer of 1 1/2 rigid foam. Sealed with Tuck tape. I'm thinking of running it outside in the sun tomorrow. It'll be 24° out. Should be a good test.
  19. Apr 30, 2018 at 2:18 PM
    #619
    Therby
    Kitchener
    Jeep JL
    Got some more points today @Norilsk .
  20. Apr 30, 2018 at 4:49 PM
    #620
    llamasmurf
    Wes
    Northern Ontario
    You get more points for the yank hitch always being installed :fistbump:
    :thumbsup:
