Switch back question.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 240less, May 2, 2017.
  1. May 2, 2017 at 11:45 AM
    240less
    240less [OP] Well-Known Member
    Keith
    1998 Tacoma 4x4
    Ive been doing a bunch of research but most of the write ups are for later model first gens. I have a 98, which has 1156 bulbs instead of 3156 bulbs like the later 01+ tacos. So my question is, what kind of sockets can i get that will fit in the factory housings and take either an 1157 or 3157 switchback led?
    thanks
    Keith
  2. May 2, 2017 at 9:12 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
  3. May 4, 2017 at 11:45 AM
    240less
    Keith
    1998 Tacoma 4x4
    thanks for the info, i read all the links on how to wire and what to possible trouble shoot should i have issues. i searched DEPO clear turn signals online and found them with an 1156 bulbs. http://www.ebay.com/itm/DEPO-USA-98...ash=item3f79f57d74:g:bxwAAOSwxH1T9Szf&vxp=mtr
    im just wondering if they come with sockets like yours did. may i ask where you ordered yours?
  4. May 4, 2017 at 12:35 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    Amazon. but the socket will determine what you can put in. you may have to switch the 1156 to an 1157 by methods in the other posts.
    being I have an '04 the 3157 is technically a two function light. so my connector and socket were ready to go. but the 1156 is single only so you'll more than likely have to re-wire it and use an 1157 socket to put into the housings
  5. May 4, 2017 at 12:39 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    I did exactly what you are trying to do. I got 1157 sockets (https://www.superbrightleds.com/moreinfo/empty-bases-sockets/ba15-bayonet-base-sockets-wired/1147/) and put them in my turn signal housings. I had to shave down the opening in the housing to get the 1157 socket to fit, but it was minor. Then I tapped the new 3rd wire into the parking light circuit above the wheel well. Now I can turn the parking lights on and get the turn signals to turn on white. When I activate the turn signal, it turns amber.
    240less[OP] likes this.
  6. May 5, 2017 at 8:38 AM
    240less
    Keith
    1998 Tacoma 4x4
    than you
