switch blank with wire harness behind it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by !TacoTaco!, Nov 5, 2013.
  1. Nov 5, 2013 at 9:12 AM
    !TacoTaco!
    !TacoTaco! [OP] TACO LOVER!
    Felix
    PSL, FL
    09 Prerunner TRD SR5 Sport
    Removed coal filter, Also installed AFE air filter. Roof rack with custom diamond plate air diverter.
    I have a 2009 prerunner and I was installing an onboard aircompressor . when I went to install the switch, I pulled a blank from the left side of steering wheel and it was connected to a harness, anyone know what that button may have been used for?
  2. Nov 5, 2013 at 9:16 AM
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    It would be used for a rear differential switch if you had one equiped
  3. Nov 5, 2013 at 10:28 AM
    !TacoTaco!
    Felix
    PSL, FL
    Awesome, thank you. I will choose another blank to install my compressor switch in order to have that one if I ever want to install that.Thanks again.:D
  4. Nov 5, 2013 at 10:33 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    FYI....
    Just because the wiring is there, doesn't mean your ECM (or other parts) are equipped to 'bolt in' whatever the harnass is for.
  5. Nov 5, 2013 at 1:34 PM
    !TacoTaco!
    Felix
    PSL, FL
    Yeah, I just hope it has power and ground going to it to make my job easier. Hopefully it works with the ignition switch too. Will have to wait to test it until tomorrow.
    Thanks!
