Switch for Yota Mafia Rock Light Kit?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ThatTacomaThough, Mar 13, 2020.
  1. Mar 13, 2020 at 8:01 AM
    ThatTacomaThough
    ThatTacomaThough [OP] Well-Known Member
    2017 White Tacoma TRD Off-road
    - SUSPENSION: - 6”BDS Full Suspension Lift w/ Fox Shocks - SPC Adjustable Control Arms RIMS AND TIRES: - Vision Off-Road 412 Rocker Satin Black Rims (20x13) - Hankook All Terrain Tires (35x12.5xR20 ) LIGHTING: - Custom headlights-Painted black and white on inside with products from TheRetrofitSource-Halos, Demon eyes, Custom DRL board (All on controller) - Meso Customs LED Side Markers (In headlight) - Meso Tacoma Puddle Pods - Meso Customs BD5 Brake Light Kit - YotaMafia 6 Piece Rock Light Kit (Turns On When Car Unlocked) - Unique Racing Style Switchback White/Amber LED Smoke Mirror Turn Signal Light - Vision Pro Led Bulbs F2 - VIPMOTOZ LED License Plate Lamp Assembly - Morimoto Type T XB LED Projector Fog Lights - FCKLight Bar RGB V-2 Series - Meso Custom Map & Dome Lights - Custom Made Raptor Lights From Step Bar LED Strips - Rough Country LED Ditch Lights 2” Square CREE (DRL Mode) PERFORMANCE: - S&B Filters 75-5096D Cold Air Intake - MBRP S5338P 3" Cat Back Single Side Aluminum (Cut slanted at 45” angle over axle) Exterior - Prinsu Roof Rack - TacomaBeast 8DX LED Tail Lights - TRD Pro Grill (W/ White Lettering) - GatorTrax Tonneau Cover - N-Fab Black Textured Wheel 2 Wheel Step Bars 3’ Tube AUDIO: - PIONEER TS-SW2502S4 10-Inch, 1.200 Watts Shallow-Mount Subwoofer X 2 - Pioneer GM-D1004 400W 4-Channel GM Digital Series Class FD Amplifier (For Door Speakers) - Kicker 46CSC674 6-3/4" 2-way car speakers (Front Speakers) - Kicker 43CSC6934 CSC693 6x9 3-Way Speaker Pair (Read Speakers) - Genuine Subaru H631SFJ101 Tweeter Kit - Rockford Fosgate R400-4D Prime 400 Watt Full Range Class-D 4-Channel Amplifier (For Pioneer Subs) ACCESSORIES - Black Inlays For Chrome Vent Rings - JDMCAR Center Console Organizer - TuffSkinz Coaster (White Inserts) - Black Tacoma Lettering Tailgate - White “Toyota” Lettering on tailgate by camera - Steering Wheel White Lettering (Over Tacoma Logo on Steering Wheel) - Painted Brake Calipers White - Door Sill White Lettering - Runnin4tacos 3/4” D-Ring Shackle (Buddy White) - Tacovinyl Grille Badge - AJT Key Fob - Remote Start - MICTUNING MIC-FB-202 Blade Block,12-Way Fuse Box Holder - Rockford Fosgate Single In-Line AGU Fuse Holder for 4 AWG or 8 AWG Wire
    I have the yota mafia rock light kit, I love the white lights and how they turn on with my truck. The only issue I have is I wanna drive with them on at night cause it’s legal in my state but my third brake light is too bright and I got a ticket for it because I have Meso customs BD5 all Baja design rock lights in the third brake light.. anyone have any ideas on how to change the yota mafia rock light kit to install a switch or something that will make it so the rock lights Turn on only? I want to keep the functionality of unlocking my truck and having those rock lights turn on and off when I shut my truck but also have them on without the brake lights being on when driving. Sorry if this is long and confusing but need to get it soon!
  2. Mar 13, 2020 at 8:56 AM
    99ranged
    99ranged Well-Known Member
    Northern CA
    '19 TRD OR
    I’m currently installing the same rock lights but with 9 cyclones. I will eventually have them on separate switches like you described. It’s explained how to do this in the rock light instructions on page 16. You can download the instructions from their site if you don’t have them. I’m waiting on my custom MESO switch panel and cargo bed switch to arrive so I can finish up the install.
  3. Mar 13, 2020 at 9:30 AM
    ThatTacomaThough
    So basically the cargo light will act separate than the rock light kit? Meaning they will turn on when you lock and unlock but then when you turn the switch on it’ll just light up your rock lights correct?
  4. Mar 13, 2020 at 11:11 AM
    99ranged
    Northern CA
    '19 TRD OR
    Yea both being on different switches and left on then they both should come on when unlocking the truck. When you want to start driving and not have the cargo light on then you can use the separate cargo switch and set it to off. That’s what I understood from the instructions at least haha. I’ll let you know how it works out for me but if you end up doing it first let me know!
  5. Mar 13, 2020 at 11:25 AM
    caribe makaira
    Caribbean, Puerto Rico
    Any chance you could show us this harness? Pic?
    Seems they do not know how the circuit works...especially when they say there's no hot wire for illumination...
    Skydvrr likes this.
  6. Apr 19, 2020 at 6:23 AM
    Yotatech1
    Yotatech1 New Member
    Without getting into a lot of details. Toyota uses the negative lead to trigger the Cargo light therefore there is not a hot lead that would light an illuminated switch (Led lights when switch is on) Yotamafia uses the same negative lead for their kit. By design most illuminated led switches tie the hot lead of the Led to the switched side assuming that the feed to the switch will be positive which is correct in most cases. If you use a switch with the Led wired that way it can cause a problem with the circuit. Simple solution is to just use a plain standard SPST switch connected to the leads as indicated in the instructions. By the way I think that Yotamafia may be working on a custom switch that will fit the panel and blend in with the factory switch.
  7. Jun 1, 2020 at 12:19 AM
    Atlfan13579
    Atlfan13579 Well-Known Member
    Mammoth Lakes
    2017 White TRD Off Road 4x4
    Trd Pro Rims Trd Exhaust Trd Air filter Trd Skid plate 265-75-16
    Has anyone wired to the domes
