Switch from 265 -70 -17 tooooo?
Discussion in 'Wheels & Tires' started by Tenax, Sep 24, 2012.
  1. Sep 24, 2012 at 4:48 AM
    Tenax
    Tenax [OP] Well-Known Member
    Terry
    Alberta
    03 prerunner trd
    17 inch wheels
    Got a 2003 pre-runner extra cab with spidertrax spacers front and back, 265 70 17 nitto terra grapplers on 2005-2011 taco rims. The tires are only about 70% tread and rub the flaps and wheel well turning while backing and probably a bit at full lock. So I'm thinking if I went to changes tires and kept same size, the rubbing with 100% tread will be too much?
    Assuming so, what tire size option (s) should I consider that will give the same or even slightly better clearance than current without losing the look I'm getting now?
    Ps-I may consider a bit of a lift down the road at some point but don't see it until shocks/struts need replacing (taco has 67k miles on it, no off road) so I think that project is years away:)
  2. Sep 24, 2012 at 3:24 PM
    Tenax
    Terry
    Alberta
    03 prerunner trd
    17 inch wheels
    Bump
  3. Sep 25, 2012 at 11:22 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    most guys take off the mud flaps. i've never been a fan of them, but i can understand the need to keep them on. your only option is to downsize in tire size. 265/65/17 was the stock size on the 2nd tacomas with 17" wheels.
    you can also take the adapters off which will probably help clear the mud flaps, but you might rub the frame at full lock(very minor).
  4. Sep 25, 2012 at 12:00 PM
    Tenax
    Terry
    Alberta
    03 prerunner trd
    17 inch wheels
    thank you and that's good to know. that's kind of where my head was going and i felt that the change in tire size was minimal and wouldn't effect the appearance too much. i didn't know that was the stock size for those:)
