Switch light always on....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by axeman26, Jul 26, 2019.
  1. Jul 28, 2019 at 2:20 PM
    Gus87
    Gus87 Well-Known Member
    Chicagoland
    16 trd sport
    Did that work for you?
  2. Jul 28, 2019 at 3:11 PM
    axeman26
    axeman26 [OP] Well-Known Member
    Will
    Bay Area
    2015 Tacoma 2wd 4cyl 4door
    Fatbob’s aal/front spacer/KO2’s/Curt trailer hitch
    It worked as far as turning the switch light off while not in use. Hopefully that solves the overall problem. I still have the circuit wired directly to the battery thus it will turn on and off without the ignition on.
  3. Jul 28, 2019 at 3:26 PM
    Gus87
    Chicagoland
    16 trd sport
    You be fine as long as you don't leave your light bar on, but that's pretty noticeable.
    axeman26[OP] likes this.
  4. Jul 28, 2019 at 4:19 PM
    axeman26
    Will
    Bay Area
    Thanks for your help guys! I suck at wiring and clearly I always need input when I’m trying to figure things out.
    Gus87 likes this.
