Switch panel ball mount installation question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OnHartung'sRoad, Sep 9, 2023.
  1. Sep 9, 2023 at 2:39 PM
    OnHartung'sRoad
    OnHartung'sRoad [OP] -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I would like to install these ball mounts between the switches on the lower canter panel. Tried 3M tape at first but the phone mount is too heavy, and definitely won’t hold a iPad mini. So… has anyone seen behind this panel well enough to say wether or not the mounting screws will clear the wiring behind it?
    If so, I will pull the panel to make sure I clear everything before drilling the holes, but if not I will do something else to mount it and save the time trying to open the panel.
    Thanks!
  2. Sep 9, 2023 at 2:55 PM
    Spadi_5
    Spadi_5 Well-Known Member
    Wisconsin
    2019 DCSB TRD OR
    Not sure what is behind the panel but I was looking at different tablet mounts this morning and ran across a guy who used Gorilla tape to hold his mounts to the dash. He was mounting magnet pads and did not have the Ram Mount extension hanging off of it. That may be worth a shot if you are unable to screw into the panel.
    OnHartung'sRoad[OP] likes this.
  3. Sep 9, 2023 at 9:29 PM
    OnHartung'sRoad
    Thank you for your reply. I know that the 3M tape is great for mounting to slick surfaces that get hot (my rear dash cam camera is mounted on my rear window that gets much too hot to touch), but gorilla tape melts in the heat.
    I think it’s because of the texture of that panel that the 3M tape doesn’t do well, so I decided to go ahead and screw the mounts on because I want to use several electronic items mounted to them and those locations are just wasted space between those switches.
    Spadi_5[QUOTED] likes this.
  4. Sep 9, 2023 at 9:54 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
