Switch Panel GB
Discussion in 'Automotive Group Buys' started by Iggy, Nov 18, 2014.
  1. Nov 25, 2014 at 1:11 PM
    #161
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    otrattw.net
  2. Nov 25, 2014 at 1:14 PM
    #162
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    They go big on handling/shipping fees
  3. Nov 25, 2014 at 1:33 PM
    #163
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    6 bucks to ship 4 switches isn't exactly what I would call "going big" on shipping. Same cost as a small flat rate box from usps....
  4. Nov 25, 2014 at 1:45 PM
    #164
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    I am sadthat I missed this.
  5. Nov 25, 2014 at 1:46 PM
    #165
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    When I ordered 1 switch only it came out to a total about 22 with tax
  6. Nov 25, 2014 at 6:00 PM
    #166
    transplant
    transplant resident know-nothing
    theo
    Crestline, Ca
    89 sr5, 99 OR, 11sport, 14 offroad
    ditto. i try to check in here once a week. guess i missed that one.
  7. Dec 1, 2014 at 11:16 AM
    #167
    Iggy
    Iggy [OP] Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Update, Everything has been ordered and shipped. I should get the handles today, the switch holders Weds and the hopefully the panels today or tomorrow.
    Thanks!
  8. Dec 1, 2014 at 1:52 PM
    #168
    Nightstr
    Nightstr Well-Known Member
    Felipe
    Sacramento CA
    05 prerunner sr5
    BLHM BLWM 3" TOUGH COUNTRY LIFT TRD SEAT COVERS THULE RACK M/T KM2 265/65/16
  9. Dec 1, 2014 at 2:50 PM
    #169
    mrbedgood
    mrbedgood Isaiah 6:8
    North Carolina
    '11 MGM DCSB TRD Off Road 4x4
    Total Chaos +2" Long Travel Kit; King/TC 2.5 LT C/O w/ 16"x600; TC/CVJ Extended Axles; TC Spindle Gussets; King 2.5 RR shocks; All-Pro Expendition Leaf Pack; Pelfreybilt Sliders; Anti-Dark LED Hood Light mod; LED map and dome light mod; Bed lights; TRD Cold Air Intake; KB Voodoo Tailgate cap system; HomerTaco Thin Lip "Raptor" grille; sPod SE System w/ LCD Touchscreen; Baja Design OnX6 40"; Baja Design S2; Rigid Industries LED Rock Lights; Front Runner Slimline II Roof Rack; A.R.E. Z Series Camper Shell Projector BHLM Headlights (with custom wiring); Method Racing NVs 17"x 8.5; and Nitto Terra Grappers 265/60/17
  10. Dec 1, 2014 at 7:05 PM
    #170
    ThomasMore66
    Dallas/Fort Worth & Durango
    I bet if you hook folks up with some lights you could still get one.
  11. Dec 1, 2014 at 7:25 PM
    #171
    tacomacrazy
    tacomacrazy ExPo Truck
    Bryant
    Coral Gables, FL
    07 DC 4x4 TRD Offroad
    HIDs 10k & 3k, AFE Intake, LEDs Red Map & dome, Pioneer 4300 Walker Evan 2.5 coilover 2.0 rear with all pro expo leaf pack. SnugTop Campershell Famous Fab rear bumper/ tire carrier. Dual Battery System Upgrade 250a Alternator
    There's a cyber sale on switches out there Ill try and find the thread.
    Under deals and coupons
  12. Dec 1, 2014 at 11:34 PM
    #172
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
  13. Dec 2, 2014 at 3:49 PM
    #173
    Iggy
    Northern CA
    Check out the build
    Panels are in!!
    So there was a slight mixup. My panel, was originally designed as a 1/8" panel, but it was cut using 1/16" material, so these are actually 3 times thicker! 1/8" would have been enough to take out the play in the switch holder, but these work just as well.
    Since they are so thick, they take out the slight play I had before. They fit solid! I'm glad I got one for myself along with you guys!
    Here's how the final ones fit.
    I'm going to deburr them tonight and some need some sanding on the corners. The rest of the parts should arrive tomorrow and I'll start to package everything up.
    Thanks again guys!
  14. Dec 2, 2014 at 3:51 PM
    #174
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    :woot: very nice OP!
  15. Dec 2, 2014 at 3:52 PM
    #175
    Nightstr
    Felipe
    Sacramento CA
    05 prerunner sr5
    ^do you want to sale the one you curently have? I'll even take it without switches.
  16. Dec 2, 2014 at 5:04 PM
    #176
    mrbedgood
    North Carolina
    What guage of wire did you use to do your connections?
  17. Dec 2, 2014 at 5:35 PM
    #177
    Iggy
    Northern CA
    Check out the build
    I'm using 18g but they are only activating relays. I have 14g for the main power.
  18. Dec 2, 2014 at 5:55 PM
    #178
    Tretiak30
    Tretiak30 Well-Known Member
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Just received an email saying you shipped mine. I thought you haven't gotten everything together yet?
  19. Dec 2, 2014 at 6:08 PM
    #179
    Iggy
    Northern CA
    Check out the build
    That was quick! Yes, I just printed all the shipping labels through PayPal. It's my first time doing all this so I guess it just updated everything as shipped.
    I'm expecting the panels tomorrow, so if the post office has my flat rate boxes I'll get everything packaged up.
    I'll update this thread when I ship the panels, and keep an eye on the tracking number once I do.
    We're almost there guys! Give me a few more days, but I promise I will not hold onto these a second longer that i have to.
    Thanks!
  20. Dec 3, 2014 at 10:46 AM
    #180
    keahi808
    keahi808 Well-Known Member
    Shane
    Roseville, Ca
    08 DCLB 4x4 Magnuson S/C
    Suspension 5" rcd lift 4" alcan leaf pack LR Ucas Toytec coils #620 Tires 33" cooper stt Rims 18x10 moto metals mo962 Others Oil catch can mod Homertaco satoshi grille Angeleyes headlight 6500k hid w/demon eye mod Prinsu Studio Roof rack w/ 40" Heretic •Performance Magnuson Supercharger AFE Stage 2si ucon ems urd 2.8 stealth pulley urd cam gears urd performance thermostat urd 76mm adapter 5.7L throttle body
    im in for the next GB :D
