Switch panel wiring.
Discussion in 'Technical Chat' started by Scoobarooo, Oct 25, 2016.
  1. Oct 25, 2016 at 8:10 PM
    Scoobarooo
    Scoobarooo [OP] Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    I got a switch panel in and I just put the switches in it finally. I need to wire the thing now. I have a few question about them.
    1. These are 4 pin switches and they are lighted. The lights suck so I won't be using the light. Do I still have to use the ground even if I'm not using the light or will the switch not work at all unless I ground it?
    2. Where's the best place to put a fuse panel? I have a lot of things to run.
  2. Nov 2, 2016 at 6:42 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    Generally those work just fine without connecting the ground wire. The ground wire is usually for indicator light(s).
