Switch Power Wire Alternative Location
Discussion in 'Lighting' started by Voyager, Jan 6, 2015.
  1. Jan 6, 2015 at 7:47 AM
    Voyager
    Voyager [OP] Well-Known Member
    Bob
    Virginia
    04 Tacoma DC 4X4 TRD V6
    OME Suspension kit Magnaflow SS catback, ARE cap, Yakima kayak & bike racks, Deck Lid, Westin Safari Light Bar.
    Just picked up a set of PIAA 520 fog lights from a friend. Understand I’m supposed to tap into a power source near the ignition harness to ensure the lights only come on when the truck’s low beam driving lights are on.
    I don’t want to do that.
    Where can I hook up the PIAA “switch powerline” to have the fog lights come on whenever I want?
    Electricity is not my friend….so looking for as simple as possible.
  2. Jan 6, 2015 at 8:39 AM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
  3. Jan 6, 2015 at 8:43 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    this simplest solution is to draw it direct from the positive terminal on the battery. make sure you put a low amperage fuse there since it's a low gauge wire and it's only purpose is to power the solenoid and the indicator lamp in the switch (if there is one)
  4. Jan 7, 2015 at 6:48 AM
    Voyager
    Bob
    Virginia
    Fergyz – I have what looks to be the original wiring harness. Took the lights off a used adventure bike that I recently picked up and intend to install them on my truck. On the BMW,the“power switch” wire was spliced into the bike’s dashboard wiring loom to meet the legal requirement of only operating while running lights are on. I want to be able to turn them on whenever I want – so I need to find a positive power source the runs all the time.
  5. Jan 7, 2015 at 6:49 AM
    Voyager
    Bob
    Virginia
    Bjmoose – thought about sending the “power switch” wire to the positive battery terminal, but did not think about adding a fuse. Guess I should just man-up and find the power source for the head lights under the dash as per the instructions.
  6. Jan 7, 2015 at 7:20 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
  7. Jan 7, 2015 at 8:51 AM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    since the wire for powering the switch/relay is low current (less than half an amp), you can easilypower that by using an add-a-circuit and connecting it to one of the fuses in the fuse box. one that is only on when the ignition is on. the radio fuse should be one.
  8. Jan 7, 2015 at 9:36 AM
    Voyager
    Bob
    Virginia
    guys - really appreciate the info. will look at both solutions. thanks!
