Switch Pros 8100 w/completely wired fuse panel - Portland Oregon - SOLD
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Spixelz, May 9, 2019.
Thread Status:
Not open for further replies.
  1. May 9, 2019 at 6:46 PM
    Spixelz
    Spixelz [OP] Well-Known Member
    Jesse
    Forest Grove, Oregon
    2015 White 6spd DCSB OR
    Icon Stage 4 w/Dakar Leafs
    This fuse panel was in a 2015 Tacoma. It was removed and stored. Doing some spring cleaning!
    Fuse panel is a power trays panel for manual 2nd gen Tacomas, will fit automatic trucks too. Might fit 3rd gen, I'm not sure of the mounting.
    Switch pros 8100, fully wired and terminated. All you have to do with this setup is plug and plug. The hard work is done. Switch Stickers included.
    Blue sea fuse block is setup to run devices with less draw and are internally switch.
    Asking $550. Will ship at buyers expense. Local pickup preferred.
    captn.fat.beard and lo2hi like this.
  2. May 10, 2019 at 10:37 AM
    MunchTIME
    MunchTIME Well-Known Member
    SD, CA
    slick set up, planning to do something similar on my 3rd gen. If this was from an AT i think it will also fit 3rd gens too?
    Did you wire the power terminal right to the battery so you always had power to the switch pro? Or is there a sense signal to the SP so it comes on with ignition/acc?
Thread Status:
