Switch Pros controller issue
Discussion in 'Lighting' started by Pax11B, Oct 18, 2017.
  1. Oct 18, 2017 at 1:23 AM
    Pax11B
    Pax11B [OP] Well-Known Member
    2017 Quicksand Tacoma TRD OR AC
    https://www.tacomaworld.com/threads/pax11b-quicksand-build.491885/
    I've had my SwitchPro controller for a while now and while taking a road trip I noticed a flicker every now and then. The buttons would go from dim to full bright almost like a strobe light.
    Has anyone experienced this? I've tried reaching out to switchpros but no response for over a week. I've tried everything I can think of and now just have it unplugged.
  2. Oct 20, 2017 at 3:04 PM
    Pax11B
    No one? Can't seem to reach customer service and I'm not sure if they are a vendor on here.
  3. Oct 20, 2017 at 8:33 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    If it was flashing completely on/off I would look into a ground or main power connection issue.
    But from your description of "flickering from dim/bright" this leads me to believe either;
    A)The Illumination wire is hooked up wrong/and or loose.
    or
    B)Something is going haywire in the control head
    I would start with A. According to SP diagram, pin 3(yellow) is the light input circuit. This makes the Switchpro panel go from "bright"(day) to "dim"(dark) when the lights turn on. Where do you have it tagged to in the truck? Have you double checked the connection?
  4. Oct 23, 2017 at 11:25 AM
    switch-pros
    switch-pros New Member
    16 taco
    Our records indicate that you wrote to us on 10/7/17 and we replied, same day, with suggested things to troubleshoot. You wrote to us again on 10/18/17 and two different techs replied to you on 10/19/17, with more suggested troubleshooting tips, and a request for manufacturing information and installer information to help us determine if there is a production or installation issue. We did not receive a reply to those emails. In such cases, we assume that the issue has been rectified and no further assistance is required. Our apologies if it appears that we have dropped the ball, but we require additional information for us to continue support. It is our sincere desire to rectify your issue. If it is ongoing, please try phoning us, as this would be the most expeditious way to resolve the issue.
  5. Oct 23, 2017 at 11:27 AM
    MESO
    State of Jefferson
    Let's hear what the techs suggested.. in case anyone else runs into this issue?
  6. Oct 23, 2017 at 11:32 AM
    switch-pros
    16 taco
    Good thought! Symptoms like this are almost always caused by some type of disruption on the Blue Ignition wire, or a change in the length of the communication cable (which runs between the power module harness and the switch panel pig tail). A bad ground, on the black wire with red ring terminal, can also cause flickering or sporadic behavior. Both were suggested to the member, above, but we have not heard back for us to know if the issue has been resolved.
    MESO[QUOTED] likes this.
  7. Oct 23, 2017 at 7:08 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    OP got some splainin to do
  8. Oct 24, 2017 at 10:02 PM
    Pax11B
    Sorry for the late reply. Had some emergency issues to fix. Turns out your emails were in my spam folder. I will check tomorrow about my wiring. I suspect it may be a bad ground, but will let yall know tomorrow
    @switch-pros
    @mesojdm
    switch-pros likes this.
