Switch-Pros Users
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Joethebugman, Feb 11, 2017.
  1. Mar 12, 2019 at 12:19 PM
    #241
    jp_flynavy
    jp_flynavy IG: @TrailLimoOverland
    2015 Tacoma DCLB
    Thanks! I saw you were out of the game so I jumped on the opportunity.
  2. Mar 12, 2019 at 12:22 PM
    #242
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    yeah man. :thumbsup: I just keep kicking myself in the ass for not sticking with it or getting a patent. I've seen several remakes. no biggie. I just know what I had to do to make that design work.. and I have to assume others just reverse engineer my parts.
  3. Mar 12, 2019 at 12:27 PM
    #243
    jp_flynavy
    2015 Tacoma DCLB
    I know the pain, I had to build the part from scratch. I have several prototypes that didn't quite work out laying on my desk. Trial and error.
    XPOTRPR[QUOTED] likes this.
  4. Mar 12, 2019 at 12:38 PM
    #244
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Reverse engineer?
    It's a square pocket with radius corners and a lip.o_O
    s7726 and MunchTIME like this.
  5. Mar 12, 2019 at 12:43 PM
    #245
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    I don't think you realize how involved/expensive the process of getting a patent is... I'm not sure it's financially worth it in this case and it would be hard to argue what you've done is not an obvious solution.
    Gunshot-6A likes this.
  6. Mar 12, 2019 at 12:58 PM
    #246
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Lol. Easy to say now that its all been done.
    This is exactly why I didn't pursue it.
  7. Mar 12, 2019 at 12:59 PM
    #247
    MESO
    State of Jefferson
    Easy to say, easy to draw, easy to print. I did mine from a picture on google lol
    But ya I don’t think it was worth patenting. That gets quite expensive.
    2ayne likes this.
  8. Mar 12, 2019 at 1:09 PM
    #248
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :thumbsup:
    I guess you're just superior :notsure:
    I had to come up with an idea, then how to capture it, with no hardware, and with no picture. Form fit to the center console. I didn't have shit to go off of.
    Like I said tho. No biggie. Moved onto bigger and better things.
    MESO[QUOTED] likes this.
  9. Mar 12, 2019 at 1:14 PM
    #249
    MESO
    State of Jefferson
    Not superior just a little handy with DIY stuff. I’m honestly suprised switchpros doesn’t offer this as an optional part with how versatile the 8100/9100 is
  10. Mar 12, 2019 at 2:56 PM
    #250
    DSIM
    DSIM Well-Known Member
    Daniel
    Raleigh, NC
    2017 MGM Tacoma TRD Off-Road
    Just saw the link to your bezel on ebay. Have you not had issues with PLA? PLA tends to warp in high heat (Truck Cab in Summer).
    Just curious.
  11. Mar 12, 2019 at 3:10 PM
    #251
    jp_flynavy
    2015 Tacoma DCLB
    Hi, I did think about that when using the PLA. Part of the reason I went with PLA is because the controller is essentially part of the structure when paired in a interference fit design. My own bezel is PLA and I have not seen any deformation or warp from heat. Not saying it can’t happen, but it withheld Texas summer.
    If this becomes and issue, I will switch to ABS. In the mean time PLA is delivering results and product that I want.
    Great question btw.
    DSIM[QUOTED] likes this.
  12. Mar 18, 2019 at 1:50 PM
    #252
    Corey00d
    Corey00d Member
    2019 TDR Offroad
    Has anyone wired an ARB single compressor directly to a Switch-Pros or is everyone connecting the ARB harness to the Switch-Pros unit? I do not have air lockers and do not plan to in the future. Just trying to avoid a bird's nest of unused wiring in my truck.
  13. Oct 25, 2019 at 11:05 AM
    #253
    Taco_mex
    Taco_mex Active Member
    Alberto
    Tacoma 2018 sand
    none
    hello, one quick question, light for panel always are on right? only can dimm but can't turn off in day driving, correct?
  14. Oct 25, 2019 at 11:07 AM
    #254
    Shellshock
    Iowa
    yes. You can adjust the brightness though for both
  15. Oct 25, 2019 at 11:15 AM
    #255
    Taco_mex
    Alberto
    Tacoma 2018 sand
    none
    thanks then there is no reason for plug withe wire right, I thought that with this wire plug panel turn off in day driving
  16. Oct 25, 2019 at 11:21 AM
    #256
    Shellshock
    Iowa
    it doesn’t turn it off. It adjusts the brightness between your day and night setting so you don’t blind yourself with the panel
  17. Oct 25, 2019 at 11:54 AM
    #257
    Taco_mex
    Alberto
    Tacoma 2018 sand
    none
    thanks friend, where u plug the withe wire? I´m trying in low beam fuse, but this way the led on the power module remains on when the key are off
  18. Oct 25, 2019 at 11:57 AM
    #258
    Shellshock
    Iowa
    this is how mine is wired
    PErsing and wessyder like this.
  19. Oct 25, 2019 at 12:23 PM
    #259
    Taco_mex
    Alberto
    Tacoma 2018 sand
    none
    thanks a lot can please tell me for what purpose you use the pink wire?
  20. Oct 25, 2019 at 12:30 PM
    #260
    Shellshock
    Iowa
    trigger wire. I’ve got it setup so ditch lights (sometimes my 30” bar too) come on and off with my high beams.
