Switch-Pros Users
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Joethebugman, Feb 11, 2017.
  1. Dec 19, 2017 at 7:45 AM
    #161
    Hextall
    Hextall Well-Known Member
    NH
    17 Inferno OR DCSB
    Would it be possible to use the switchpro for doing the backup camera anytime mod? what about a front camera too?
  2. Dec 19, 2017 at 7:49 AM
    #162
    solscooter
    solscooter Sh!t Outta Luck
    Brian
    Minnesota
    2016 TRD OR DCSB 4x4
    Yeah. Anything that needs a switch basically. You'd have to run a power wire to the switch-pro.
  3. Dec 19, 2017 at 8:32 AM
    #163
    ROCdermody
    ROCdermody Well-Known Member
    '16 Quicksand DCSB TRD OR
    That's fantastic! Any chance you've got more pics, maybe with the roof closed? Still working ok there? Would you do it different if you did it again?
    CMScheid likes this.
  4. Dec 19, 2017 at 9:05 AM
    #164
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    Agreed here with @solscooter... the arb compressor requires a ton of power and so you can use its included relay and just control the switching with the switch pro... i ordered one of these as well to make the wiring to the switch pro easier:
    http://store.switchpros.com/quick-connect-harness-for-arb-compressors/
    SanPedroTacoLover likes this.
  5. Dec 19, 2017 at 9:49 AM
    #165
    Shellshock
    Iowa
    This is how I'm looking to mount mine when I pick one up here in the next couple months. Good to see this is workable!
  6. Dec 19, 2017 at 3:53 PM
    #166
    Istan
    Istan Leave it stock they said
    Stan
    Vegas and Yuma
    03 Xtra Cab 5Speed 4*4
    Yeah, I have that connector. I wanted to wire that to the switch pro on one of the 15 amps. The Compressor will get power directly from the battery and the relay.
    riz_atx[QUOTED] and solscooter like this.
  7. Dec 19, 2017 at 4:07 PM
    #167
    riz_atx
    Sohail
    Spicewood Texas
    You should have no problems doing that. I have mine connected to switch 7 which is 15 amps and it works fine
  8. Dec 24, 2017 at 9:01 PM
    #168
    monkeyevil
    monkeyevil Victory 4x4
    Daryl
    Kalamazoo, MI
    I'll take a quick video tomorrow.
  9. Dec 25, 2017 at 4:55 AM
    #169
    ROCdermody
    That'd be great. And Merry Christmas everyone!
  10. Jan 2, 2018 at 1:43 PM
    #170
    monkeyevil
    Daryl
    Kalamazoo, MI
  11. Jan 2, 2018 at 4:02 PM
    #171
    ROCdermody
  12. Jan 2, 2018 at 6:46 PM
    #172
    trdeez
    trdeez Well-Known Member
    SLC, UT
    16 TRD Off Road
    Are you grounding to the fender or to the battery from your negative bus bar?
  13. Jan 2, 2018 at 6:52 PM
    #173
    Synergy001
    Synergy001 IG: @pnwx.taco
    PDX
    00 ACLB -Daily, 16 DCSB -Adventure Rig
    Bus bar is grounded on the fender
  14. Jan 3, 2018 at 7:10 AM
    #174
    Hextall
    NH
    17 Inferno OR DCSB
    With XPOTRR's mount not being available, can I still mount the switch plate over the left hand cubby hole with teh included hardware? If anyone did this, do you mind taking a picture? Just want to see the fit and look.
    Also, what are the options for mounting plates for that space similar to xpotrr's? I see SDHQ has one, but it's a bit pricey (at least compared to XPOTRR's)?
  15. Jan 3, 2018 at 7:25 AM
    #175
    Synergy001
    PDX
    If you have the concealed version just cut around where the cubby is to make it fit. I have the SDHQ one and that's basically all they did.
  16. Jan 3, 2018 at 11:34 AM
    #176
    dskakie
    dskakie Well-Known Member
    Dan
    Northern CA
    2016 TRD OR DCSB
    I mounted mine with the hardware included and it’s felt fine for like a month now. I have an XPOTRPR mount but just decided to try and go without cutting anything up and I’ve been happy with it this way! Will probably put up the XPOTRPR in the marketplace eventually
  17. Jan 3, 2018 at 12:27 PM
    #177
    Hextall
    NH
    17 Inferno OR DCSB
    Perfect, thanks for those pictures.
  18. Jan 9, 2018 at 11:06 PM
    #178
    Photocycler
    Photocycler Well-Known Member
    Pacific Northwest
    2017 Tacoma TRD OR DHSB MGM
    Curious how those running two Lightbars are doing it? I have one that draws 15amps and another 11.5
  19. Jan 14, 2018 at 4:35 PM
    #179
    Istan
    Stan
    Vegas and Yuma
    Was there a way to use one switch to activate multiple switches?
    Finally finished my permanent install with a power tray.
    Switch 1 left pod
    Switch 2 arb twin
    Switch 3 front bar
    Switch 4 what should I hook up?
    Switch 5 rear bar
    Switch 6 what should I hook up?
    Switch 7 right pod
    Switch 8 what should I hook up?
    On the blue sea:
    1 planning on running one into the cab for constant usb
    2 planning on running one to the bed for a blue sea panel with 12v socket and usb
    3-6 what should I hook up?
  20. Jan 14, 2018 at 10:41 PM
    #180
    aaen
    aaen Well-Known Member
    Northern Alberta
    2016 DCLB 4x4 TRD Sport BBP
    Kings, ARB Summit Bumper, SMittybilt Winch, vagabond Drifter, Prinsu Cabrac, Crusinoffroad slidersand rear bumper
    Anyone having any issues with the plug/wirings on the switch pro itself? I noticed my light bar started to flicker and after checking everything out and switch to different switches, it appears my wire number one on the switch pro is buggered. If I move the wire the light bar flickers and goes out or it stays on. Almost like it isn't getting a decent contact inside the plug. This is where the positive wires from the switchpro come out and go to either a bus or are hardwired to the accessories positive cable.
