Switch search - Can't seem to find the ONE
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TC_Mic, Jul 6, 2018.
  1. Jul 6, 2018 at 8:34 AM
    TC_Mic
    TC_Mic [OP] Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    Any help in finding the right switch would be appreciated.
    I am looking for a On - Off - On switch that looks as OEM as possible and must fit the small OEM switch hole. So far my search has not provided me a good option.
    I know I can use an adruino or possibly a timer relay (maybe) to achieve the desired results but would much rather have a simple switch solution and want to stay with the OEM look and small switch size.
    Thanks in advance!!
    Edit: For those trying to help me, I am looking to be able to turn lights on, off, and auto with a single switch. Hence the search for a DPDT. I have been able to find the small push switch that fits the OEM hole, just none with more than on-off or momentary function.
  2. Jul 6, 2018 at 8:36 AM
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
  3. Jul 6, 2018 at 8:37 AM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    Mictuning switches,
    Or over the river switches etc may have something for you. They are the only ones i know that make switches for the stock locations.
  4. Jul 6, 2018 at 8:40 AM
    CaliRaisedLed
    CaliRaisedLed Well-Known Member Vendor
    Jake
    Texas (DFW)
    We have them in stock we carry the “small” style OEM switch along with the bigger one.
    https://caliraisedled.com/collections/2016-toyota-tacoma?page=2
    snowtank likes this.
  5. Jul 6, 2018 at 9:02 AM
    TC_Mic
    snowtank[QUOTED] likes this.
  6. Jul 6, 2018 at 9:03 AM
    TC_Mic
    Tried to find what I wanted on both sites and do not see the size and type combination I am looking for.
    Thanks for the assistance.
  7. Jul 6, 2018 at 9:06 AM
    TC_Mic
  8. Jul 6, 2018 at 10:38 AM
    TC_Mic
    Correction, I am in need of a SPDT, though a DPDT would also fulfill my needs/wants.
  9. Jul 6, 2018 at 11:55 AM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    Tag for later
  10. Jul 6, 2018 at 12:11 PM
    synaps3
    synaps3 Wag more bark less
    Dave
    Los Alamos, NM
    2017 White SR5 4x4 DCLB
    SOS armor, ARE MX walk-in, Fox coils, Dakar leafs, etc
    I'm looking for this too, in momentary. I have a "toyota small switch" form factor hole I want to control my winch off of, and I think I'm going to just end up putting a momentary SPDT surface mount switch in a blank. There's nothing out there that is factory-looking and will rock two directions with the middle off. :frusty:
    https://www.amazon.com/dp/B01DD9MA7A is the closest I could find, but it doesn't fit.
  11. Jul 6, 2018 at 12:21 PM
    TC_Mic
    Yup, that is exactly the issue I am finding. The tall switch there are a several options, but I can find nothing but the push on-off for the small switch hole.
    I am actually considering either doing a 2 switch and relay build, or dropping in 2 smaller rockers sideways in the hole. then wire those to the relays. The only other thing I can think of is using an Adruino with a momentary switch to differentiate between pushes to choose a state.
  12. Jul 6, 2018 at 12:32 PM
    TC_Mic
    I have never used Adruino.
    If that winds up being my solution, I will have to learn how to program the thing. That will be a learning experience and may take me a bit to figure out.
  13. Jul 6, 2018 at 1:28 PM
    slowboater
    slowboater Well-Known Member
    I have bought several dpdt's with the correct dimensions for the 'larger' opening on the right side. The problem is that they have systems for keeping the switch in place that are too big to slide into the opening. So, I've bought a bunch of switches with the correct dimensions that don't fit.
    I'm about to drill a hole and just use a toggle.
