Switch the + and - shift on 3rd gen transmission?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smithj702, Apr 25, 2016.
  1. Apr 25, 2016 at 7:46 PM
    smithj702
    smithj702 [OP] Member
    Hey guys im new to the forum, I have a quick question. I have a 2016 automatic trd offroad, I was wondering when I put it in manual shift mode, is it possible for me to switch the + and - shift. Example unstead of pushing forward on the shifter to shift up it would be to shift down, and pulling the shifter toward you would shift up instead of shift down. Ive seen the same automatic shift pattern with the bmw without the paddle shifters on the steering wheel. Any help would be appreciated, thanks.
  2. Apr 26, 2016 at 4:16 AM
    aggie77
    aggie77 Well-Known Member
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    Lund Nerf Bars Auto tailgate unlock
    The Sport mode, "S", on these transmissions function only as a gear limiter. When you move the lever from D to S it will initially set the highest gear to 4. If you come to a stop then start moving again, it will shift from 1-2-3-4 and no higher. If you move the lever forward then the limit becomes 5; once again at it is 6. Pull back and it moves the limit down a gear. It is not a paddle shifter.
    smithj702[OP] likes this.
  3. Apr 26, 2016 at 4:23 AM
    smithj702
    Thanks for the info... Buttt thats not what im trying to get at....
  4. Apr 26, 2016 at 4:24 AM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
  5. Apr 26, 2016 at 5:22 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    it's not a BMW
    is it possible yes get your 3d printer out and some
    big hammers and reengineer the entire system sure
    will it ever happen NO
  6. Apr 26, 2016 at 5:35 AM
    aggie77
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    Sorry, I misread your post. Swapping the direction of the shifter might be possible by modifying the wiring associated with the shifter but not something I would attempt.
  7. Apr 26, 2016 at 5:47 AM
    Frito
    Frito Well-Known Member
    Sounds like a tall order....
  8. Apr 26, 2016 at 7:09 AM
    aggie77
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    If you are brave enough to attempt this, it would appear that swapping the two wires in position 1 and 3 of connector T23 may do the trick. See page 3 of EAI-2GR.pdf and look for the SFTD nad SFTU connections (ShiFT Down / ShiFT Up). That connector is in the console, according to InpaneL-P4.pdf . If someone does try this please post the result.
  9. Apr 26, 2016 at 9:13 AM
    smithj702
    Thanks for the info!!! I will look into it further and keep everyone posted.
