switch to Fully Synthetic?
Discussion in '4 Cylinder' started by Ry1984, Apr 11, 2009.
  1. Apr 11, 2009 at 4:44 PM
    Ry1984
    Ry1984 [OP] Well-Known Member
    From Texas, Now Miami FL
    01' ExtCab SR5 2.7 4x4
    K&N FIPK, Billy 5100 all around, 881's in the front, Toytec AAL
    when I bought my truck it had 128,000mi and I didnt know what oil the previous owner used, so I threw Castrol GTX High Mileage in her and have been using since with K&n oil filter. I have heard nothing but good things about Mobil 1 Full Synthetic and I want to try it, but the saying goes just go with what youve been using. Is this change worth it? or not? I currently have 140k. The reason being I really want to make the switch is from when I put Mobil 1 in my gear case and the difference it made was remarkable.
  2. Apr 11, 2009 at 8:47 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Personally, I would change to full synthetic if you are planning on putting on a bunch of miles. It will run cleaner overall and clean out any crud left over from dino oil. The downside to this is that if any of that crud is keeping old gaskets from leaking, then you could start to develop leaks. If the vehicle has been well maintained, this may not be a problem. This comes from my own experiences from using synthetic oil. It's all I use now.
  3. Apr 11, 2009 at 9:32 PM
    Ry1984
    hey thank you for the advice, i think im gonna try it!
  4. Apr 11, 2009 at 9:46 PM
    afd23a
    The Dynamo of Dixie
    No problem. I hope it goes well for you. IMO, it's good for the long run if you plan putting some miles on it. Better protection, fewer oil changes, possibly better mpg. Other people might have different opinions and these are just based on my experiences.
  5. Apr 11, 2009 at 11:31 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    You may want to get a oil flush first or change the oil after then first 1000 miles or so. The synthetic tends to "clean house" and you will get a lot of carbon deposits washed away. Amsoil makes one.
  6. Apr 12, 2009 at 5:09 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It's not necessary to do that.
    Synthetics do clean better but it's not gonna disolve everything in a matter of 1000 miles. I've never flushed anything and never noticed any difference in the first oil change using synthetics to last oil changes.
  7. Apr 12, 2009 at 5:47 AM
    Ry1984
    ok good to know. and how often should I change my oil with fully synthetic? should it be more ofter due to the high mileage of my truck?
  8. Apr 12, 2009 at 6:51 AM
    Brunes
    Brunes abides.
    Rotorhead
    I change mine every 5K with a filter....works fine.
  9. Apr 12, 2009 at 7:16 AM
    Janster
    Jandy
    Lancaster, PA
    In terms of synthetics & when to change them, is a heated debate really.
    There's the theory that synthetics can stay in your engine longer because they don't break down. Technically, that's true - however - there are other factors involved that play into the equation whether or not you should leave it in longer than recommended intervals. Lots of guys here get their oil analyzed..... and that'll tell you whether or not the oil can be run for longer intervals.
    For me personally, I've never had an oil analysis. I change mine (oil & filter) every 5K miles (as recommended by my owners manual) using Mobile 1. At that point, the oil is really dark/dirty and it's just *peace of mind*. I don't mind paying the extra money on the synthetics.
    For your engine with that many miles, it might be a good idea to change it regularly.
  10. Apr 12, 2009 at 8:53 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    im using amsoil extended life,every 20,000 miles or once a year.buddy did oil test with amsoil with 54000 miles on it.then took brand new quart of penzoil (regular oil) from walmart to get sampled.amsoil with 54000 beat brand new penzoil in the tests.go figure.oh yeah that used oil came out of a s10 blazer 4.3 motor.good luck.
  11. Apr 12, 2009 at 9:59 AM
    Ry1984
    thanks for all the great info guys, very much appreciated :)
  12. Apr 12, 2009 at 12:09 PM
    Brunes
    Brunes abides.
    Rotorhead
    Actual Results?? I'm interested to see how much worse that new oil faired than used oil...
  13. Apr 12, 2009 at 4:56 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    brunes ill see if i can get that info.not to sure though,been 3yrs ago.later
  14. Apr 14, 2009 at 4:33 PM
    VTDave
    VTDave Well-Known Member
    Vermont, USA
    05 Access Cab 4x4 Base 5sp Man, 16 DCSB 4x4 Sport 6sp Man
    Since you already get good results with Castrol GTX, why not move up to Castrol Syntec? It's marketed as a "fully synthetic" oil but is really a group 3 oil. I run it myself. The price is right. It flows like a synthetic, but seems not to leak as much as Mobil 1 in high mileage engines. In this respect, it behaves like a conventional oil, which is a good thing for the narrow purpose of non-leakage.
    Don't get me wrong. Mobil 1 is an excellent product. Amsoil is great. Royal Purple is great.
    Syntec runs a little cheaper, does almost the same thing, and it won't leak quite as easily. This might lend some peace of might to someone pondering the switchover to synthetic.
  15. Apr 14, 2009 at 5:01 PM
    Ry1984
    Honestly because Ive just heard more great things about Mobil 1. but since you have mentioned it Im gonna look into it. thanks for the advice, Ill let you know what I end up going with and then the results.
  16. Jul 10, 2009 at 4:48 AM
    coma09
    coma09 Senior Member. Hey, what's That supposed to mean?
    BC Canada
    2013 taco access cab 4x4
    Putco led map light bulbs, bed mat, Xiang trifecta tonneau, blackout front emblem, paint tow hoop, led bed light strip, scan gauge II, debadge, buff paint, oem fog light kit, 1000w inverter, Viair 300P compressor, Contura V dash switches, chop last L bend from exhaust, remove charcoal air filter, extinguisher, mag light, Ss side steps, kayak rack, tailgate security, bed mat security
    Re frequency of oil changes:
    Synthetic doesn't extend your oil change dates.
    Synthetic is manufactured using regular oil, and additives.
    Needs higher temperatures to break down.
    Has better cold-start viscosity.
    Many folks say their engine never burns oil. All engines burn oil. The level on the dipstick might never change, but it's due to carbon, and by-products of combustion going into the oil. This is why it looks dirty, and why you change it. Synthetic oil doesn't change this, you still get dirty oil at the same rate.
    So the debate is ... should one use synthetic @ the regular intervals, or use the extra $ to change with non-synth more often.
    Heavy-use vehicles in hot climates ... synth would be better. Cold climates ... synth would be better at startup.
    If you can afford it - synth is better, so long as the oil change intervals are adhered to. Me ... I change mine more often ... every 5000km, instead of 8000, and use non-synth.
  17. Jul 10, 2009 at 3:11 PM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    "So why'd you hit me?" "Cuz you were thinking with yer dipstick.... Jimmy."
    Sorry totally pointless but I couldn't resist.
  18. Jul 14, 2009 at 7:55 AM
    jrsmokestacks
    jrsmokestacks Well-Known Member
    Northern, IL
    Long Bed
    Stock work truck
    Carquest fully synthetic 5w-20 with their premium filter. Change my oil every 5,000 miles. No problems yet @ 48,5xx miles. 6 qts. and filter is only $35
  19. Jul 14, 2009 at 11:45 AM
    4cyltacoma
    4cyltacoma Well-Known Member
    Reagan
    Fresno, Ca
    06 Tacoma SR5 4Cyl 4x4
    AFE CAI, Black Housed Headlights, In Channel Window Visor, Bug Deflector, Black Side Step Tubes, Blacked out emblems
    synthetic all the way.. royal purple in the engine gear lube and differenials..
  20. Jul 14, 2009 at 12:15 PM
    TacoTycoon
    TacoTycoon Well-Known Member
    Justin
    Hayes, VA
    07 TRD Sport 4WD Indigo Ink
    Bilstein 5100 Coilovers, Diff Drop Kit, TSB AAL, 285/70/17 BFG A/T Tires, 17X8 Helo HE835 Wheels, Rear Bilstein 5100s, Dual Flowmaster 50 series, TRD CAI, TRD Front Seat Covers, Rear Suspension TSB, 35% Tint, Redline Hood Struts, MagLite Mod
    If you really want to learn about oils check bitog.com. The new craze over there is PP since it has been getting excellent UOAs...
