Switch to kill trailer lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sidponcho, Aug 7, 2016.
  1. Aug 7, 2016 at 4:45 PM
    Sidponcho
    Sidponcho [OP] Well-Known Member
    Dan
    I'm constantly putting my boat in/out of the water. The trailer lights will sometimes blow a bulb if I don't unplug the trailer wiring before backing in. Has anyone installed a switch to kill the power to the trailer connector?
  2. Aug 7, 2016 at 5:27 PM
    caribe makaira
    Caribbean, Puerto Rico
    You have an exposed wire in the trailer harness...or cheap light housings that drown.
    Aussiek2000 likes this.
  3. Aug 7, 2016 at 5:49 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Replace your trailer lights with LEDs on eBay for about $32 and forget about it. I have never unplugged mine since I replace them.
    o0oSHADOWo0o likes this.
  4. Aug 7, 2016 at 5:54 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Pull the plug for the trailer and the trailer lights are magically off.
  5. Aug 7, 2016 at 6:13 PM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Get some sealed waterproof lights. I had one that leaked but that is the only time I had a problem.
  6. Aug 8, 2016 at 12:53 PM
    Sidponcho
    Dan
    Had LED lights, eventually they leaked, filled with water and the PC board shorted out. Had the "waterproof" non-LED lights and they leaked too. Chinese crap
  7. Aug 8, 2016 at 1:00 PM
    Pigpen
    Dan
    Northwest Montana
    Just unplug the harness.
  8. Aug 8, 2016 at 2:39 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    +2 Duh!
  9. Aug 8, 2016 at 3:33 PM
    Sidponcho
    Dan
    D.H. :D
  10. Aug 8, 2016 at 4:37 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Hot bulbs cold water bad thing.
