Switch to synthetic for my 1st gen?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Flamingskull, Aug 7, 2020.
  1. Aug 17, 2020 at 7:42 PM
    #41
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    many vehicles new from factories have synth oil originally
    i caution against switching oils seldom is merit a basis for change..............usually marketing
    at 100k miles U only had extended oil changes to gain
    there are at least 4 diff basic ' Synth ' oils............ many more blends
    there are few staright base or straight weight oils available
    pick ONE & stick to it !
  2. Aug 18, 2020 at 9:10 AM
    #42
    Buck Rogers
    Buck Rogers Well-Known Member
    LA (Lower Arkansas)
    96 Taco, 07 FJ gone but not forgotten, 19 Taco
    ROAD DOG the truck I was referencing is a 96 model and I'm pretty sure it did not come from the factory with synthetic oil in it.
    1997tacomav6 likes this.
  3. Aug 18, 2020 at 10:58 AM
    #43
    austi012
    austi012 Active Member
    Thaddeus
    1997 Tacoma
    If you live in the cold cold North, you should use synthetic if you plan on starting the car when it's below zero.
    I've run synthetic in everything I've owned and the only car that leaked was a Volvo 850 -- and that leaked because the PO let the PCV system plug and it huffed out all its seals. It had nothing to do with the type of oil.
  4. Aug 18, 2020 at 6:45 PM
    #44
    ROAD DOG
    FEW
    by the mileage alone i didnt think it came with synth
    point attempted is there are many wives tales ..........rule o thumbs
    that hold little merit
    Ur truth in reality synth created a leak..............that i dont dispute
    thousands have said the same
    thats Ur reality
    save for the fact most multi weight oils have a great deal of ' synthetic polymers '...................
    blended into high grade base oils
    resulting in the spread 20w -50............0w-20 etc
    in effect only has been recent oils are ' full synths' ( if U get around the marketing on the bottles )
    so in effect 95% of everybody has been running ' synths ' in 1 form or the other ( of which there are 4 basic types )
    U can still buy straight weight oil & yes i used to mix my own
    been a while .................worked great in consideration of hard use.......heat & long mileage
    never lost an engine
    i dont recommend switching ( mixing polymers creat crap )
    i dont recommend synths after an engine has passed its optimum
    break in is slightly diff on Dino vs synth
    only thing truly getting broke in are the rings ( keepin compression )
    bottom end bearings shouldnt be touching the crank anyways
    save for HD (1200 ft lb springs valves ) most engines have reduced valve spring pressure
    computer ramps on race cams are far more forgiving
    next time U buy new chk in at 5000 miles
    keep Ur idling to min to non existing
    good luck
