Switch To Synthetic Oil?
Discussion in 'Technical Chat' started by CarlosinFL, May 30, 2010.
  1. May 30, 2010 at 8:09 AM
    CarlosinFL
    CarlosinFL [OP] Mildly-Attractive
    Carlos
    Orlando, FL
    02 PreRunner SR5
    I just got my 2002 4 cyclinder 2WD PreRunner and it has 109k miles and runs amazing however my friends recommended I flush the entire truck and use AmsOil synthetic oil for the engine & transmission.
    I have never owned a Toyota or used synthetic motor / transmission oil so I wanted to ask here and see what you guys recommend? Do you think it's a good or bad idea? Waste of money or worth it in the long run? Is my truck too high mileage for AmsOil synthetic oil?
  2. May 30, 2010 at 8:13 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    the only problem starting syntetics at a high mileage engine is that it might cause oil leaks. so that said after you change all the fluids take time to check everything out to make sure that there are no leaks of any kind. if there are switch back to dyno, it should clog it back up. if you want to keep running synthetic then change out all the gaskets and such
  3. May 30, 2010 at 8:13 AM
    08pretaco
    Oliver
    az
    there are toyota engines that have gone 400k miles on dyno
  4. May 30, 2010 at 8:17 AM
    04LTtacoma
    04LTtacoma Well-Known Member
    Outer Space
    I use max life which is half synthetic and half regular oil. If I was to go full synthetic I would go with Red Line.
  5. May 30, 2010 at 8:18 AM
    08pretaco
    Oliver
    az
    mobile 1 seems to be probably the most popular synthetic from the forum from all the threads and polls
  6. May 30, 2010 at 8:24 AM
    CarlosinFL
    Carlos
    Orlando, FL
    02 PreRunner SR5
    I was told that AmsOil is by far the best synthetic oil available. I am sure they're all fine but Mobile 1 is perhaps popular because of the price and availability. I don't see how it can be a better synthetic oil from AmsOil.
    As for the leaks, I am guessing that if I switch and have no leaks, it should be fine...
  7. May 30, 2010 at 8:33 AM
    04LTtacoma
    Outer Space
    Red line is the best oil. I will tell you about this story when I was young and dumb. Haha. I was working at a Subaru dealership as a lube tech. Occasionally I would get to change the oil on a WRX STI. This really nice limited STI came in to have an oil change done. As I was changing the oil I forgot to tighten the drain plug on the bottom. BTW I have like 10 oil changes in line and my service writer is telling me to hurry the heck up cuz we have customers waiting so you were always pressured to get things done in time. So I get done changing the oil on this STI. The customer goes to the cashiers office and pays then leave. He comes back later that day with no drain plug. Haha. His car had no problems, it was working fine for the most part. He was really pissed though and I would be too if it was my 30k dollar ride. Anyways the oil I put in was Red line. Most people told me it was the red line that kept his vehicle from blowing up. Haha. I had changed the oil again on his car. Made sure that I tightened that DP tight. From there on he never came back. My boss had a small chat with me later that day telling me how lucky I was that STI motor didn't blow up. Would have been about 6k to repair or replace should I say....
  8. May 30, 2010 at 8:37 AM
    CarlosinFL
    Carlos
    Orlando, FL
    02 PreRunner SR5
    That story can be told with "insert your favorite oil here". Not saying Redline isn't good but it's Pepsi or Coke discussion.
  9. May 30, 2010 at 8:57 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Thats a myth. Switching to synthetic wont hurt a thing.
  10. May 30, 2010 at 10:19 AM
    CarlosinFL
    Carlos
    Orlando, FL
    02 PreRunner SR5
    I think back in the 80's 90's this was typical of most synthetic oils however with technology and formula changes this is no longer typical unless you have severe seal issues on the motor.
  11. May 30, 2010 at 10:34 AM
    dhurley
    dhurley Well-Known Member
    Doug
    Colorado Springs, CO
    04 Double Cab TRD SR5 V6
    TRD, Snugtop Super-Sport, bedliner, receiver hitch, alarm mod, deck plate mod, AFE Pro-Dry S, Saddleman camo seat covers, TW decal, grey wire mod w/switch, DRL, LED cupholder mod, Dynomax Super Turbo, aux back-up lights, Devil Horns by Andres, "blue plug" mod for 2LO, shorty antenna, Pro Comp fog & driving lights, receiver shackle, 15% tint front windows, stainless nerf bars, Ultra Gauge, diff breather mod
    ^The websites for Amsoil, Mobil and Valvoline all say the same thing, MYTH.
    MaxLife is 30%synthetic & 70% dino.
  12. May 30, 2010 at 10:52 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Wow! I havn't seen a "Should I switch to synthetic oil thread" for a while now, but yes you should switch to syn. No reason you shouldn't.
  13. May 30, 2010 at 12:42 PM
    Barnone
    Barnone Guest
    Agreed!
    Why spend the extra money?
    These are not race engines.
  14. May 30, 2010 at 12:56 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    Because oil is the life blood of the engine, why not put the best of the best in your engine? Why drive when knowing that you could have something better to put in?
    Plus you can go longer on the change intervals, which can make up some of that price difference.
    Dino is good oil to use, and I understand these are not race engines. But synthetic oil is so much better all around.
  15. May 30, 2010 at 1:20 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    Personally, I would use synthetic if I spent 40k or more on my ride or if I abused the engine on a regular basis, that's just my threshhold and my logic. Dinosaur oil is good oil and it works fine for the average everyday vehicle owner. If you abuse your engine regularly, a switch to synth may be justified. But I see no need to spend twice as much for oil that may or may not make my engine last longer... besides, the 2.7 in my 2006 is bound to outlast the chassis anyway. As long as I keep up with the maintenance intervals, I sleep great at night. That is how I see it.
  16. May 30, 2010 at 2:04 PM
    DarrellH3
    DarrellH3 Active Member
    Darrell
    Huntsville, Alabama
    09 PreRunner TRD Sport LB
    Switching from dyno to synthetic after that many miles you are just asking for oil leak trouble. I have been there/done that. Some say that the oil leaks will stop after switching back but it didn't for me. I use synthetic but would never change after more than 15 or 20K miles.
  17. May 30, 2010 at 4:53 PM
    Barnone
    Barnone Guest
    Follow the manufacturer's maintenance schedule and use the recommended fluids and your vehicle will be fine.
  18. May 30, 2010 at 5:10 PM
    BakoTruck
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Yes it will be fine, but better is better.
  19. May 30, 2010 at 5:16 PM
    Firsttaco
    Firsttaco Well-Known Member
    alberta
    2009 Tacoma TRD Sport
    Bilstein 5100 all around, front set at 0 with OME 887. Light racing UCA. Dakar full pack in back. aluminum running boards. Scangauge II. Painted flat black rims. Raider canopy.
    I just switched to Amsoil for my truck. Did a little research on some synthetic oils out there and it seemed the best. I have heard that people say that its harder to find then Mobil 1 and its more expencive, but thats not the case. I found out that you can become a dealer of Amsoil for 30$ Canadian a year and you then can buy anything Amsoil sells and you get whole sale prices. And when you order its shipped directly to your door, or if you are near the wharehouse you can just go and pick it up. So if any one wants just click the link and choose what you want. I just saved 6.50$ a litter when I bought a case. Its totally worth it.
    http://www.oildepot.ca/wholesale-accounts/wholesale-accounts.html
  20. May 30, 2010 at 5:54 PM
    Barnone
    Barnone Guest
    Did I see your Taco in the Indy 500 today?:D
    Madison Avenue wins again.
