Switch wiring for Eaton E locker
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rat_Bastard, Oct 7, 2020.
  1. Oct 7, 2020 at 7:41 PM
    Rat_Bastard
    Rat_Bastard [OP] Well-Known Member
    Brian
    Tucson AZ
    2016 OR
    Looking for some general wiring help relating to substituting the Eaton factory power switch with a new switch that fits in my overhead console. I'm basically wire matching and don't want my locker to activate as I switch on high beams.
    I numbered them below to reference which (I believe) should pair /splice together. I added description as per each switches diagram.
    Eaton switch
    1) BLUE : 12v DC ignition
    2) YELLOW: switch relay signal
    3) BLACK: ground
    Relpacement Switch
    1) RED: 12v DC ignition
    2) GREEN: RELAY
    3) BLACK: Ground
    4) BLUE: "connect to dash light to supply 12V (optional)
  2. Oct 7, 2020 at 8:53 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    For usual / most common wiring that’s correct. But no one can give you the actual answer without knowing the Eaton pinout and More importantly how the relay coil is wired to the switch.
    But if the light on the Eaton switch lights up when in the on position, then it’s 95% safe to assume you got it right with your numbering. (I’m assuming the Eaton switch has a light otherwise there would be no need for the ground and power, but since it has both it could use either to energize the relay coil, and that’s what you really need to know here).
    Rat_Bastard[OP] likes this.
  3. Oct 7, 2020 at 9:15 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Best I could find from Eaton
    Doobfucious and Rat_Bastard[OP] like this.
  4. Oct 7, 2020 at 9:23 PM
    Rat_Bastard
    Brian
    Tucson AZ
    2016 OR
    Thanks. This matches the manual that I have but still confused with the extra wire the replacement switch has.
  5. Oct 7, 2020 at 9:25 PM
    Rat_Bastard
    Brian
    Tucson AZ
    2016 OR
    I'm not sure if the Eaton switch lights up but the replacement switch does.
  6. Oct 7, 2020 at 9:45 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Eaton switch lights when in the on position. Hence the ground. It puts 12V on the coil of the relay to switch the locker on. It's right in the diagram posted above.
    TnShooter and Rat_Bastard[OP] like this.
  7. Oct 7, 2020 at 9:48 PM
    ShimStack
    Ben
    NC
    Illuminates the switch with a second source so it can come on with dash lights and be dimmed if you so choose.
  8. Oct 7, 2020 at 10:45 PM
    caribe makaira
    Caribbean, Puerto Rico
    STrooper and Rat_Bastard[OP] like this.
  9. Oct 7, 2020 at 10:54 PM
    Rat_Bastard
    Brian
    Tucson AZ
    2016 OR
    Nice! Thank you for this. Where's a good source to access the dash light?
  10. Oct 7, 2020 at 11:01 PM
    caribe makaira
    #12 Overhead connector R44 (SR/SR5)
    Edit...slot 12 (+)
  11. Oct 8, 2020 at 12:09 AM
    Rat_Bastard
    Brian
    Tucson AZ
    2016 OR
    Excuse my lack of basic wiring.
    Do I just splice and solder into #13?
  12. Oct 8, 2020 at 12:12 AM
    caribe makaira
    Since the wires are small gauge, get these and T-tap it.
    STrooper likes this.
  13. Oct 8, 2020 at 12:13 AM
    Rat_Bastard
    Brian
    Tucson AZ
    2016 OR
    Perfecto! Thanks so much!
  14. Oct 8, 2020 at 12:16 AM
    caribe makaira
    @Puppypunter was in the works to make a harness to the overhead console...but I'm sure you're not going to wait for it...
  15. Oct 8, 2020 at 12:24 AM
    caribe makaira
  16. Oct 8, 2020 at 12:53 AM
    Rat_Bastard
    Brian
    Tucson AZ
    2016 OR
    I already have their harness but using it for the camera. I wonder if I can splice into this harness?
  17. Oct 8, 2020 at 12:56 AM
    caribe makaira
    To tap the dash illumination on the head Unit then run it to the overhead console...yikes!:eek:
  18. Oct 8, 2020 at 1:01 AM
    Rat_Bastard
    Brian
    Tucson AZ
    2016 OR
    yeah. that's my brain half asleep. I think I will try your original idea with the T connector. I've used these before although I hear some people say it's not ideal. BY the way, I have a TRD offroad so not sure if the diagram you provided will work. It says (SR/SR5)
  19. Oct 8, 2020 at 1:08 AM
    caribe makaira
    And it's slot #12...Me brain is also con sueño.
  20. Oct 8, 2020 at 1:31 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    I can confirm our trucks run illumination to the dash switches through the tan wire. If it's a little too tight to splice or t-tap you could gently push the new wire into the tan wire slot following the wire in. A good electrical taping job will hold it in place. I know some people don't like to cut wires or add taps.
    Here is a video wiring in the extra wire you refer to in case you want to see what I'm talking about. It's for a ditch light switch, but the concept is the same.
    skip forward to 1:05 in the video so you can avoid me talking as to why I'm doing this. Good luck, let us know how it goes.
    https://youtu.be/U1UFbys9Pvo
    Rat_Bastard[OP] and STrooper like this.
