Switch wiring help!
Discussion in 'Lighting' started by knine00, Jul 28, 2012.
  1. Jul 28, 2012 at 5:19 AM
    knine00
    knine00 [OP] Well-Known Member
    Hudsonville, Mi
    12 PreRunner DC TRD Sport
    Stock for now
    I am wiring up 4 switches today. Each switch needs ignition power. Can I run ona add a circuit for all 4 switch ignition terminals? Or do I need to run an add a circuit for each switch? Any help is greatly appreciated!
    Thanks
  2. Jul 28, 2012 at 7:37 AM
    knine00
    Hudsonville, Mi
    Stock for now
    Anyone?
  3. Jul 28, 2012 at 7:39 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    If you run your ignition power to a relay and then to the 4 switches you will be fine. The relay will only use a small current from the ignition source.
  4. Jul 28, 2012 at 7:49 AM
    knine00
    Hudsonville, Mi
    Stock for now
    This is how all of the switch are wired. So your say if I route my ignition wire from my switch to its own relay before I plug it into the fuse block I can do all 4 switches together? Otherwise each switch needs its own ignition wire?
  5. Jul 28, 2012 at 8:27 AM
    knine00
    Hudsonville, Mi
    Stock for now
    No one?
  6. Jul 28, 2012 at 8:35 AM
    Large
    Large Red
    tricky question, depends on what you are going to be running amperage wise on those 4 switches.
  7. Jul 28, 2012 at 8:53 AM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    The purpose of a relay is to use a small current to switch a higher current device. It does this by creating a magnetic field that closes the switch in the relay. So as long as the combined current draw of the switch/indicator/relay combination do not exceed rating of the fused circuit, you should be able to run all of the switches off the same fuse.
    To determine whether the switch's current draw, you will need to know how much current is required to trigger each of the relays and what also what each of the indicator requires.
  8. Jul 28, 2012 at 9:26 AM
    knine00
    Hudsonville, Mi
    Stock for now
    Lol wow I got to look up some numbers because I didn't calculate these!
  9. Jul 28, 2012 at 10:17 AM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Calculate what?
  10. Jul 28, 2012 at 10:18 AM
    knine00
    Hudsonville, Mi
    Stock for now
    Current draw and amps
  11. Jul 28, 2012 at 10:25 AM
    YotaMan2007
    YotaMan2007 Well-Known Member
    Brian
    where my boots and ruck lay
    07 Tacoma 2wd
    K&N Drop-in airfilter, secondary airfilter removed, Satoshi Mod, Kenwood Stereo System, Gibson catback system , Painted Steelies, Offroad Lights, Fatbob's spacer lift
    i added two switches for my hella's and they use thier own ignition wire, but the ground i tied together.
  12. Jul 28, 2012 at 10:40 AM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    You are ONLY running the RELAY thru the switch--Not the LIGHTS.
    Your other switches--what will they be running?
    The diagram appears to be a GOOD install.
  13. Jul 28, 2012 at 10:42 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    You will be fine. The relay coils are not going to draw more than fractions of an amp each, add that with the indicator lights and you should be fine with a 5 amp add-a-fuse on a 15 or 30 amp block.
  14. Jul 28, 2012 at 10:43 AM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Why two switches? one for each? Be sure to run through a RELAY.
  15. Jul 28, 2012 at 10:44 AM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    His diagram indicates his intention to use a relay. I think the important thing to mention is that the switches need to be wired in PARALLEL and not series, or they'll be useless. :D
  16. Jul 28, 2012 at 11:45 AM
    knine00
    Hudsonville, Mi
    Stock for now
    Each component is going to have a relay. I am just trying to see if I can wire each switch together and then to my ignition. Here is pics.
    Blue sea fuse block with CB and relays
    My switches.
  17. Jul 28, 2012 at 12:05 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Yes. You can do that as long as the total current draw when all switches are on doesn't exceed the rated capacity of the fuse.
  18. Jul 28, 2012 at 12:07 PM
    knine00
    Hudsonville, Mi
    Stock for now
    So the switch current draw or the component current draw?
  19. Jul 28, 2012 at 12:23 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Switch.
    Maybe this will help? Sorry for the crappy drawing. All the lines represent power. I left off the grounds plus some of the other relay stuff that's shown in the other drawing.
  20. Jul 28, 2012 at 12:39 PM
    knine00
    Hudsonville, Mi
    Stock for now
    Ok I gotta look up the contura v current draw.
