Switch Wiring Help
Discussion in 'Technical Chat' started by Frogsauce, Jun 19, 2013.
  1. Jun 19, 2013 at 6:48 PM
    Frogsauce
    Frogsauce [OP] Well-Known Member
    Chesapeake Bay
    16 TRD Offroad
    I'm no electrician, and I recently almost broke some stuff trying to wire up a switch in the truck.
    I am wiring up a switch. I stopped before I tried it and want to double check with you guys on here.
    Below is the diagram for the switch:
    (It's a OTRATTW.com SPDT ON/OFF/ON switch.)
    The problem I am having with this one is how to wire up the switch lights:
    Can I ground #7 + #9 together somewhere to the frame?
    And can I tie #10 + #3 together (upper light with upper outgoing) and tie #8 + #1 together (lower light and lower outgoing)?
  2. Jun 19, 2013 at 7:11 PM
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    '12 TRD Sport DCSB 4X4
    Click My Sig Homie
    I take it you aren't using a relay? What are you wiring?
  3. Jun 19, 2013 at 7:21 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    you can tie your grounds in together but the power source for switch light are independent
  4. Jun 19, 2013 at 7:23 PM
    DR007
    DR007 Well-Known Member
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    MagnaFlow exhaust, K&N cold air intake, MB TKO wheels with 265/75/r16 Hankook Dynapro ATM, Blue Center shift LED color change, Map Lights with Dome, LED Map and Dome lights, Cluster Light Change, DTRL, Parking Light as Blinker, Blue A/C Control lights, Blue Clock, Bed Lights, Debadged tailgate, painted all exterior plastic trim, 6LZ Lightbars in grille, OTRATTW switches, Fog Light in Reverse light Mod, LED Blinkers all around, Projector Fog Lights, 15" blitzpro light bar, added hidden cig lighter port, custom plate front bumper, OME complete lift with 885 front coils, Ultraguage, CB radio 3' whips, 12v bed lighter port, Center Console Lights, AllProOffroad Sliders, 50" roof led light bar, 2 BlitzPro 6LZ Reverse Lights
    Probably should add a relay. Would help you lights or whatever you're powering and your switch last longer.
  5. Jun 19, 2013 at 7:25 PM
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
  6. Jun 19, 2013 at 7:26 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    i will assume this is for a winch set up?
    if not for most switch it would be power from battery to a RELAY
    gound to relay
    out from relay to light,compressor or what ever u want powered and a wire from # 3 switch on your first diagram in post to relay....
    hope that helps
  7. Jun 19, 2013 at 7:27 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    unsure what he is using it for but alot of leds these days dont draw much power...
    but i always use a relay........
    just my .02
  8. Jun 19, 2013 at 7:27 PM
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    Alright, I will look into adding a relay. I need to get a meter and find out what amps its pulling.
  9. Jun 19, 2013 at 7:28 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
  10. Jun 20, 2013 at 3:47 AM
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
  11. Jun 20, 2013 at 6:47 AM
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    Alright, got relays on the power for the camera. That looks like cheap insurance for switches and accessories.
    Still not sure where to run power from for the switch lights (#8 and #10 on the diagram). Will any power source due? They are very low amp LEDs.
  12. Jun 20, 2013 at 6:59 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Pretty much any power source will work for the LEDs on the switches.
    How you wire the LED's is completely dependent on how you want them to function and how you have things currently wired. You want to make sure the LED is switched so it only comes on when the switch is in that position. If you can upload your current wiring diagram for what you have connected, we can tell you where to take switch power from so it'll work out.
  13. Jun 20, 2013 at 6:50 PM
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    Alright! I got it working correctly. I feel smarter now :eek:
    I tied the top light in with #2, so it comes on only when the camera has power.
    I tied the bottom light in with #3, so it is always lit up when the ignition is turned.
    I will update my diagram tomorrow when I have daylight and see if you guys thing it will work out.
  14. Jun 21, 2013 at 5:08 AM
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
