Switch wiring help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by vanfireman, Jan 14, 2019.
  1. Jan 14, 2019 at 12:52 PM
    vanfireman
    vanfireman [OP] Well-Known Member
    Cape Cod, MA
    2016 Silver Tacoma TRD Sport double Cab 6Spd MT
    Mud Flaps x4 Extang Solid Fold 2.0 Tonneau S/S Tube Steps Air Horn (AironBoard push button switch) LED Bed Lighting (wired to Cargo lamp) Center Console organizer (Vehicle OCD) Center Console lid Molle pouch Tailgate TACOMA letter inserts (in Black Carbon Fiber) LED light upgrades (Headlight, HiBeam, Fog, Map, Dome, Vanity, Reverse, License Plate) Caliraised MOLLE Rack (right side) (2) Rear Rough Country LED spot/floods (AironBoard Switch) - these also come on with reverse gear Anytime Front, Cargo Bed, & Backup Camera Auxiliary fuse box Meso Customs 7-hole lower switch panel Meso Customs Extended fuse cover No-slip Bed Mat Pop-n-Lock Kit (KTJO) TRD “Faux” Grille with LED running lights Electronic “police style” air horn [Coming soon] Dash Vinyl Kit
    I know some of this has been addressed in other threads, but I have searched and searched without finding anything to help.
    I installed a "Wolo Bad Boy" air horn in my 16 Sport Double Cab. It was fairly straight forward, had on wire coming from Relay to a generic switch (which was just pos/neg). (Instructions below)
    I purchased an Air On Board switch, and it is wired a bit different than CH 4x4 or Mic Tuning switches (Diagram below:)
    233387d1483754566-aob-switch-wiring-ques_be26658fc04e6b87c6f607491fd69c64d32d9816.jpg
    I've wired it, with the Red to an "add a fuse" (on the Windshield Washer, as I wanted something powered only with ignition). The Blue is Illumination, and I have it tapped to the Illumination Positive of the Cargo Lamp switch.
    The Switch lights up, but doesnt activate the air horn. What am I missing? Do I go to another source for the Red?? is it better to tie the ground to an illumination negative (like on the cargo lamp)??
    Thank you all!!!!
  2. Jan 14, 2019 at 12:54 PM
    vanfireman
    Cape Cod, MA
    Could red and blue be joined and tied to a 12V positive, like the cig lighter? Or should I just cap the red and not use it ?
  3. Jan 14, 2019 at 12:58 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    If I were you I would completely get rid of the illuminated switch. It only complicates things
  4. Jan 14, 2019 at 1:15 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Where is your relay grounded?
    Boghog1 likes this.
  5. Jan 14, 2019 at 1:15 PM
    Anchovy
    TRD Ferguson
    Prong 36 (or is it 86?) has to go to a ground. Don’t jump 30 and 36 together
  6. Jan 14, 2019 at 1:28 PM
    Boomer3731
    Boomer3731 Well-Known Member
    2017 DCSB TRD Sport
    85 on the relay needs to go to ground. 86 is where green from the switch should go. 30 should be fused to the battery.
    Anchovy and daddy_o like this.
  7. Jan 14, 2019 at 1:44 PM
    daddy_o
    Bossier City, La
    It should be. Lighted switches confuse so many people because of the ground. All the ground is doing is allowing the light on the switch to function.
  8. Jan 14, 2019 at 1:46 PM
    Boomer3731
    2017 DCSB TRD Sport
  9. Jan 14, 2019 at 2:17 PM
    vanfireman
    Cape Cod, MA
    @Boomer3731 thabk you! And thank you all! I did the relay according to the Indtructuons and apparently that was it!! Thank you again!
  10. Jan 14, 2019 at 2:19 PM
    Boomer3731
    2017 DCSB TRD Sport
    No problem. Glad you got it worked out.
