Switchback bulbs blowing fuse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jcs911, Dec 10, 2014.
  1. Dec 10, 2014 at 9:50 AM
    Jcs911
    Jcs911 [OP] Member
    Johnston RI
    2013 tacoma TRD sport
    I'm trying to install DRL/Turn signal switchbacks on 2013 Tacoma TRD Sport,every time bulb is installed fuses blow ...replace fuse and install regular 4157 bulb everything is good,any help appreciated
    Thank You......
    Also have heard that sometimes they will blink rapidly because of LED .?...
  2. Dec 10, 2014 at 9:58 AM
    Aw9d
    Aw9d That one guy
    Almost all of the plug in switch back bulbs don't work without additional wiring or modifications. Our truck uses the CK style base where the bulbs use the standard base.
    The rapid blinking will happen, google 'hyperflashing". Depending on where you are located it may be illegal. In Az it is not and I have love the insanely fast hyperflasing turn signals. You can fix hyper flashing easy as well if it isn't your thing.
