Switchbacks with Drl's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tony jewell, Jun 1, 2015.
  1. Jun 1, 2015 at 6:09 PM
    tony jewell
    tony jewell [OP] Well-Known Member
    Tony
    The 1st State
    2015 TRD Off-Road Double Cab
    Additions: Bright Ass Led Fog & Headlights, LED Switchbacks, 20% Tint on Front Windows, Led's Inside & Out, Toyota OEM Bed Mat, ImMrYo Mirror Bracket, Gentex Mirror W/Compass & Temp, Husky Front & Rear Floor Mats, Navigation Entune Radio Upgrade, Salex Glove Box Organizer, Antennax Shorty 15" Antenna, Pop & Lock PL8521 Tailgate Lock, Bar Caddy and Grid-It Center Console Organizers, MattGecko Waterproof Under Bed LED Lighting Kit, Anti Dark LED Hood Lights, Flipkey, Cool Start Remote Starter, Access Lorado Tonneau Cover... MODS: Fogs on Any Time, Dome & Map Lights on at same time, Dipped All Badges, Turned off Seat Belt Chime..... In The Future: Blistiens 5100's, OME Coils, Tire & Wheels.....
    I just installed switchbacks in my 2015 TRD. I cut the green wire with the red running through it and when I turn my light switch to drl nothing happens, is this normal? I would like to be able to turn the white switchback light on when I turn my switch to drl, is that even possible?
  2. Jun 1, 2015 at 6:13 PM
    DrFunker
    DrFunker Well-Known Member
    Couple questions:
    Are they Jumpers?
    You have a DRL switch? (Thought they were on all the time.) If so, did you install it?
    Do you mean that you switch the parking lights to "on"?
  3. Jun 1, 2015 at 6:17 PM
    tony jewell
    Tony
    The 1st State
    I have a separated drl spot on my light switch. My Drl's do not come on unless it's on that position. They are jumpers and I did his mod and now the Drl's come on when I start the truck. I would like to be able to turn them on and off with that switch but come on as white and not yellow
  4. Jun 1, 2015 at 6:21 PM
    DrFunker
    Hmmm....ok.
    I have the same switchbacks in mine that I have control of too. I added a switch so I could shut them on/off but it was from the lines that ran off the DRL module. Does that make sense?
    Jumper did have to give me a little walk through when I was ready to put the switchbacks in.
  5. Jun 1, 2015 at 6:28 PM
    DrFunker
    Do they stay on as yellow?
  6. Jun 2, 2015 at 4:02 AM
    tony jewell
    Tony
    The 1st State
    I will contact Chris to see if I can add a switch to turn them off. They did not come on at all in the first 2 settings on the switch
  7. Jun 2, 2015 at 4:28 AM
    DrFunker
    I am still kinda confused, sorry.
    Are you talking about the light stalk that is on the left side of the steering wheel. Is that where you are trying to control the lights from?
    Yes, I think Chris will be able to help you with no problem.
    Good luck.
  8. Jun 2, 2015 at 4:32 AM
    tony jewell
    Tony
    The 1st State
    Yes sir that's what i'm talking about. I have read on here that by just cutting the green wire with the red stripe that when you turn to drl the switchbacks would light up white. I did that and nothing happens
  9. Jun 2, 2015 at 5:26 AM
    DrFunker
    Okay.
    I did not know that was possible. Please excuse my ignorance.
    I had thought that DRLs were always on unless the headlights were switched on.
    Good luck with it. Chris will point you in the right direction.
