switched cluster to led now having issues???
Discussion in '1st Gen. Tacomas (1995-2004)' started by FirstGen Jer, Nov 13, 2015.
  1. Nov 13, 2015 at 12:54 PM
    FirstGen Jer
    FirstGen Jer [OP] Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Did the cluster led swap last night and now my ebrake light and my turn signal lights are not working? Did I forget something?
  2. Nov 13, 2015 at 1:06 PM
    Indy
    Indy Master of all I survey.
    Probably.
  3. Nov 13, 2015 at 1:11 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    OK, do the signals work on the outside? If so then you need to reverse those bulbs.
  4. Nov 13, 2015 at 1:18 PM
    FirstGen Jer
    Jeromey
    No they do not work on the outside, I also noticed the ebrake light and the hazards are not working either?
  5. Nov 13, 2015 at 1:19 PM
    FirstGen Jer
    Jeromey
    All I changed on the cluster where the 4 194 green bulbs
  6. Nov 13, 2015 at 2:36 PM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    You need to make sure you plugged them back in
  7. Nov 13, 2015 at 2:40 PM
    FirstGen Jer
    Jeromey
    Do you know which plug is for the blinkers?
  8. Nov 13, 2015 at 2:40 PM
    LSC15
    Logan
    2008 TRD D-Cab
    Not off the top of my head
  9. Nov 13, 2015 at 2:52 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    What you really need to do now, take it back apart, put the old bulbs back in, make sure everything works. Then change out each bulb separately, one by one, making sure each works before moving on to the next bulb. AND make sure that the plugs to the back of the circuit board are plugged in fully.
  10. Nov 13, 2015 at 2:52 PM
    LSC15
    Logan
    2008 TRD D-Cab
    I'm sure he just forgot to reconnect a plug it didn't get one in all the way
  11. Nov 13, 2015 at 5:04 PM
    FirstGen Jer
    Jeromey
    Thanks guys, ya I am going to open it all back up again as suggested^^^. And re test everything.
  12. Nov 13, 2015 at 9:13 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I'm guessing he forgot the Hazard button connector.
    Fallguy6666 and FirstGen Jer[OP] like this.
  13. Nov 13, 2015 at 11:06 PM
    FirstGen Jer
    Jeromey
    That's what I was guessing too...will find out tomorrow when I tear back into the dash
  14. Nov 13, 2015 at 11:10 PM
    FirstGen Jer
    Jeromey
    Out of the whole process of taking the dash apart the only thing I found semi difficult was disconnecting the heater vent connections, I had to pull super hard to disconnect and reconnect them is that the norm?
  15. Nov 14, 2015 at 4:31 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    I only had 1 on the upper left of the dash that gave me a pure headache. It had a tiny screw on the top of the vent I just could not get to. I just yanked it out. I don't think I ever got that vent put back in all the way. But it still works.
  16. Nov 14, 2015 at 6:57 AM
    LSC15
    Logan
    2008 TRD D-Cab
    Did you disconnect your hazards?
  17. Nov 15, 2015 at 4:04 AM
    Fallguy6666
    Fallguy6666 Well-Known Member
    I did the same thing....I forgot to plug my hazard light plug back in.
    FirstGen Jer[OP] likes this.
  18. Nov 16, 2015 at 7:10 AM
    FirstGen Jer
    Jeromey
    Ya I did disconnect the hazards. I thought I had reconnected them but maybe I did not make the connection completely. In this while process I noticed my no clutch start button light was going out. So I ordered a new light for it so i am waiting to tear it all back open till my led comes in the mail, so I don't have to open it all up again.
  19. Nov 16, 2015 at 7:14 AM
    FirstGen Jer
    Jeromey
    Hmmm?:notsure:... that's is the vent I was referring to also. Although when I got it apart I saw no screw? From what I saw it was just a snap fitting. But it's hard to tell because of it location if it is sealed up all the way when you replace it.
  20. Nov 16, 2015 at 7:44 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    Yep. Has that little indentation around the passage to go on snug, yet who can get their hands in there to make sure it got on.
