switched power near trailer hitch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rellik01, May 30, 2011.
  1. May 30, 2011 at 1:26 PM
    Rellik01
    Rellik01 [OP] Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    Where can I find switched power near or at trailer hitch, I have seven pin connection. This is for a lighting project and would rather not tap into tailights.
    Thanks
  2. May 30, 2011 at 1:41 PM
    Rellik01
    Craig
    Windermere, Florida
    I should have been more specific. Which color wire on the 7 pin receptacle is 12V power and is it switched. If not any suggestions for switched power?
    Thanks again
  3. May 30, 2011 at 2:03 PM
    medic2230
    Murph
    Bama! Roll Tide
    How about run a wire from the power point under the hood to a switch inside. Run other and to the back of the truck to a connection of whatever kind you need and then it is done how you want it.
  4. May 30, 2011 at 2:31 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If it's factory wiring it has 12 volt power at the 7 pin it's used to charge camper batteries.
  5. May 30, 2011 at 3:58 PM
    Jerry Bear
    Jerry Bear Well-Known Member
    Jerry
    Mesquite, Texas
    2010 Access Cab
    tint, topper, receiver hitch, trailer wiring, topper lighting, cruise control, intermittent wipers, backup camera, auto-dim mirror
    On a 2010, the black wire on the 7 pin trailer socket is switched 12 VDC..
  6. May 31, 2011 at 2:17 AM
    Rellik01
    Craig
    Windermere, Florida
    Would rather just tap into hitch plug. Is there also unswiched hot power back thre?
    As always thanks for the quick replies.
    Craig
  7. May 31, 2011 at 2:23 AM
    tanzak88
    tanzak88 Well-Known Member
    I was looking for the same info when wiring in some canopy lights. I finally, after trying to figure out the 7-pin wiring schematics, ran my power from my battery.
  8. May 31, 2011 at 2:24 AM
    Rellik01
    Craig
    Windermere, Florida
    Does anyone have wiring diagram for the 7 pin plug?
    Thanks
    Craig
  9. May 31, 2011 at 5:09 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Lists all connections, colors, and plug types:
    http://www.etrailer.com/faq-wiring.aspx
    I don't know if the factory trailer connection is switched or not. If not, put a relay on the 12v power lead with a control wire run to the cab. Use a switch, run it to a switched line in the fuse block, or both.
  10. Jun 1, 2011 at 8:12 PM
    Jerry Bear
    Jerry
    Mesquite, Texas
    2010 Access Cab
    There is not an unswitched 12 Volt source at the back of the truck.
