Switched power underhood
Discussion in '3rd Gen. Tacomas (2016-2023)' started by momtacoma, Apr 1, 2020.
  1. Apr 1, 2020 at 1:27 PM
    momtacoma
    momtacoma [OP] Active Member
    Michael
    2018 Tacoma Off Road
    Four Seasons Rear Bumper
    I believe I have read everything thread about constant and switched power and installing an accessory fuse block and relays.
    I am one of those guys that needs part of my panel to be hot only in acc/ign mod. taking the advice of others I went through my main fuse panel and came up with the following.
    The fuses with the dots are not hot when the ignition is off. The only ones that are on in acc or ign are the INJ and the EFI No. 3 and EFI no. 4.
    I have read that the EFI is not a good place to tape because it may cycle back on when the ign is on. I haven't seen anything really about the INJ fuse, expect that it has been tapped with an add a fuse to run raptor lights.
    I am putting together an acc fuse panel and my first project electrical project was adding Katzkin Degreez. Initially, I was going to wire everything up in the cab, but I changed my mind and decided, after researching on TW, that an accessory fuse block would be a cleaner way to run accessories. so that is what I am doing.
    I only need the power to run the relay. So, long story short, I want to keep all the wiring in the engine bay. So is the INJ really the only option I have and is there a down side to using an add a fuse at INJ.
    I am open to other ideas to get acc/ing power to the relay i am using. BTW, I am using the Painless Performance Cirkit Boss Aux Fuse block
  2. Apr 1, 2020 at 1:45 PM
    caribe makaira
    Caribbean, Puerto Rico
    There are two IGN sources inside the aux relay box next to the main relay & fuse box.
    cmonjack, Indyraz, jmneill and 2 others like this.
  3. Apr 1, 2020 at 1:51 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    When I read the title of the thread, I was hoping OP installed V8 or something... :(
  4. Apr 1, 2020 at 1:56 PM
    momtacoma
    Michael
    So do I just splice off either one of those number 2 relay posts? I considered running a splice off of a relay, but I could not find much on it. That helps
    thanks a lot Caribe!
  5. Apr 1, 2020 at 2:07 PM
    caribe makaira
    Get these type of fuse taps and carefully straighten the end with slot.
  6. Apr 1, 2020 at 2:48 PM
    momtacoma
    Michael
    Thanks!
  7. Apr 1, 2020 at 2:57 PM
    caribe makaira
    :thumbsup:
    Heat shrink cover any exposed metal...
    Indyraz and Junkhead like this.
  8. Apr 1, 2020 at 2:58 PM
    momtacoma
    Michael
    Will do.
  9. Apr 1, 2020 at 6:41 PM
    robie_0n3
    robie_0n3 Well-Known Member
    David
    Scott AFB, IL
    2018 Tacoma TRD Off Road
    FWIW, I used an add-a-fuse on the INJ fuse, so that the Switch-Pros will turn on when the truck is on. Works for what you're trying to do too.
  10. Apr 1, 2020 at 6:55 PM
    caribe makaira
    So change the source...
    robie_0n3[QUOTED] likes this.
  11. Apr 1, 2020 at 7:39 PM
    robie_0n3
    David
    Scott AFB, IL
    I'll probably give that a try sometime in the next few days.
  12. Apr 4, 2020 at 2:24 PM
    momtacoma
    Michael
    Got it wired up just like you showed. Pic below. I used a Painless Fuse block. trying to figure out a way to waterproof the terminal strip, but not that worried about that. Also, I don;t have all the wires connected yet.
    Thanks for your help!
  13. Dec 29, 2020 at 8:46 PM
    rolot2
    rolot2 Well-Known Member
    Rolando
    Denver, CO
    2015 TRD OR DCSB
    Front: Extended Travel 2.5” King coilovers with/adjusters (Set at 3” lift) Rear: 2.0” King shocks with adjusters Icon RXT (Option 2) Pack Toyota TRD Cat-back exhaust AnytimeBackup Camera Anytime Front/Rear Camera RCI Sliders KB Voodoo Bed Rack Center Console Ram Mount
    Have any pics on the truck? Thanks!
  14. Dec 30, 2020 at 6:54 AM
    caribe makaira
    :hattip:
  15. Dec 30, 2020 at 8:17 AM
    momtacoma
    Michael
    Sorry I was posting my reply in the worng place.
    I used the tap suggested by Caribe and the ran the hot wire, which is pink into the fuse box by drilling a small hole in the lid and used a rubber grommet to weather protect it. I then added the fuse tap to the pink wire and added it to the fuse prong. I had to do a little filing to get it to fit over the prong.
    Yes, the tap sits flush under the fuse. These pics should help more.
    Pic 1 shows the axillary fuse panel and the pink wire to the tacoma's fuse box.
    Pic 2 show the tap and how I have it oriented. BTW it is pointed toward the passenger side of the engine bay.
    Pic 3 shows the tap under the fuse and how it sits under the fuse.
    Pic 4 shows how I tapped into the tacoma's fuse box.
    christsay and rolot2[QUOTED] like this.
  16. Dec 30, 2020 at 9:11 AM
    rolot2
    Rolando
    Denver, CO
    2015 TRD OR DCSB
    Thank you much! I appreciate it! About how much current would you say that fuse block draws? Any issues?
  17. Dec 30, 2020 at 9:21 AM
    caribe makaira
    The tap is for IGN activation of the relay that supplies the juice...
  18. Dec 30, 2020 at 9:22 AM
    momtacoma
    Michael
    I don't recall. but here is the fuse block I used: https://www.painlessperformance.com/wc/p.php?s=fuse7. (Painless 7 circuit)you can see the fuses that came with it, for amperage draw. the hot wire (the pink one) draws nominal power. The Painless website has the manual you can download: https://www.painlessperformance.com/Manuals/70207.pdf
    I haven't had a single issue. I mulled over this project for a long time worried about tapping into the fuse, but everything is completely reversible if I decide to undo it.
  19. Dec 30, 2020 at 9:25 AM
    caribe makaira
    You DO have a relay for the juice to the block, correct? (hope so:bananadead:)
    Skydvrr likes this.
  20. Dec 30, 2020 at 9:26 AM
    rolot2
    Rolando
    Denver, CO
    2015 TRD OR DCSB
    Thank you. I’m thinking of using to power some led grill lights directly. Maybe I ought to think more carefully about that...
