Switched power underhood
Discussion in '3rd Gen. Tacomas (2016-2023)' started by momtacoma, Apr 1, 2020.
  1. Dec 30, 2020 at 9:28 AM
    momtacoma
    momtacoma [OP] Active Member
    Michael
    2018 Tacoma Off Road
    Four Seasons Rear Bumper
    yes
  2. Dec 30, 2020 at 9:31 AM
    caribe makaira
    Caribbean, Puerto Rico
    Just checking...:D
  3. Dec 30, 2020 at 9:37 AM
    momtacoma
    Michael
    The power from the battery, runs through a relay to the fuse block. the ING only fuses turn off and on via the pink wire which is tapped into the fuse as described above. I only used the fuse tap give me power only when I I had the Tacamo's ING on. BTW I looked at the manual for the painless, the pink wire runs through a 3 amp fuse. I have 3 fuses that are IGN only and I have 4 fuses that are constant.
    I plan on adding additional lights and I will use this setup to run the lights. That way I keep all the add on stuff on separate circuits. the Axillary fuse block is already wired to accept lights when I add them.
  4. Dec 30, 2020 at 9:37 AM
    Camel89
    Camel89 Well-Known Member
    Houston, TX
    2016 TRD OR 4x4
    I would just like to say that your posts on electrical knowledge all over the forum have been extremely helpful. Just wanted to give you a shout out because I have used your advice from other threads and have been extremely pleased with the outcome.
    :cheers:
    rotus likes this.
  5. Dec 30, 2020 at 9:39 AM
    momtacoma
    Michael
    ditto. I would not have been able to complete my AC/Heated seats without his help!
  6. Dec 30, 2020 at 9:41 AM
    caribe makaira
    :drunk:
    elaudtr and Skydvrr like this.
  7. Dec 30, 2020 at 9:42 AM
    caribe makaira
    :woot:
  8. Dec 30, 2020 at 9:46 AM
    rolot2
    rolot2 Well-Known Member
    Rolando
    Denver, CO
    2015 TRD OR DCSB
    Front: Extended Travel 2.5” King coilovers with/adjusters (Set at 3” lift) Rear: 2.0” King shocks with adjusters Icon RXT (Option 2) Pack Toyota TRD Cat-back exhaust AnytimeBackup Camera Anytime Front/Rear Camera RCI Sliders KB Voodoo Bed Rack Center Console Ram Mount
    Understood. Maybe I'll just run a wire to the ACC fuse inside the truck and do an add a a fuse...
  9. Dec 30, 2020 at 11:16 AM
    rolot2
    Rolando
    Denver, CO
    2015 TRD OR DCSB
    I will be getting an spod in the future so no need for this right now. I think the add a fuse to the inside of the cab will suffice until then. I do appreciate the info though
  10. Apr 14, 2021 at 4:43 PM
    mrCanoehead
    mrCanoehead Well-Known Member
    Ottawa
    2018 DCSB Sport manual 3.5 l
    Is there really no source of switched power in the main fuse box of a gen 3? That little fuse box is underneath my powertray now, I think I will have to spend an hour removing/reinstalling to get access.
  11. Jun 5, 2021 at 2:14 PM
    000doodie000
    000doodie000 Well-Known Member
    J
    2015 Taco TRD Off-Road
    Many and always modding Wheels Suspension lift Armor Electrical gadgets etc...
    What does the INV power when ignition is on and what does the Battery charge relay actually do? I am curious because I am looking to provide ignition to a dual battery setup which will allow solar to flow back and charge my primary battery when the ignition is off. 0436DB0C-7A8F-4F2F-A4CC-9843049642F7.jpg
    I was considering a setup with a jumpstart option but that is another relay and switch. I may do it eventually but one step at a time seems a better method. Anyway, if you can help me out with what the battery charge relay does and what the INV does it would help me decide which to use.
    Thanks
  12. Jun 5, 2021 at 2:30 PM
    caribe makaira
    INV = Inverter
    Battery Charger for Towing Trailer. Provides power to charge a battery inside a towed trialer/camper.
  13. Jun 5, 2021 at 3:53 PM
    caribe makaira
    It's called thread jack, you should've posted in the 2nd Gen Forum.
  14. Jun 5, 2021 at 4:17 PM
    000doodie000
    J
    In the images in the profiles (Rolando) looked like folks in the thread also had 2nd Gen (model to model in a Gen also seems to be slightly differnet) I was not trying to be rude, seemed like I was looking for the same thing. (ignition power to run a relay) I was just explaining the situation. Sorry to offend. That was not my intent. I will look and see if I can find a similar thread in 2nd gen section.
  15. Jun 5, 2021 at 4:38 PM
    #35
    caribe makaira
    Just yanking your chain, no need to be so serious...
  16. Jun 5, 2021 at 4:40 PM
    #36
    000doodie000
    J
    Some folks are pretty serious about it. So I do my best to be polite in the forums. :) No biggie. Either way I removed my post.
  17. Jun 5, 2021 at 4:41 PM
    #37
    caribe makaira
    cmonjack likes this.
  18. Jun 5, 2021 at 4:44 PM
    #38
    000doodie000
    J
    Yea I saw that, different type of fuse/relay so the earlier part noting the type of connection may not work in my case. So I figured I would dig around a bit to see what might work in its place, I do like that its in my main box (on the 2nd gen). It is super easy to get to and I don't have to remove my PowerTray. I will still stick a test light on it to be sure its only on with ignition but I suspect its the same.
  19. Jun 3, 2022 at 8:02 PM
    #39
    girMobi
    girMobi Well-Known Member
    2020 TRD OFF
    RCI, Martin, Vort and Irken tech
    which add a fuse kit did you use? I grabbed the nilight add a fuse kit and while it seemed to seat properly it was awfully floppy. i stopped there since i didn't want to learn what a fritzy INJ circuit behaves like.
  20. Jun 4, 2022 at 7:48 AM
    #40
    MR.WaynesWorld
    MR.WaynesWorld Well-Known Member
    Wayne
    North East Pa
    2021 Black Tacoma Limited
    **** 2021 Mods **** Sokietech No Drill Hood Struts (Replaced) Color Matched Mirror Caps Color Match Door Handles SUPAREE LED Side Mirror Turn Signal Lights AVS Dark Smoked Hood Bugflector (Removed) Meso Black Interior Door Handles AVS Window Vents AUTOGINE Super Bright 6000K White LED Vanity Mirror Lights 3D Rear Tacoma Letters Matte Black OEM Blacked Out Emblems OEM Black Trim around Fog Lights Full BedRug AMP Research Bed Extender LoMax Tonneau Cover (Replaced) RBP 77-Spike Wheels 18X9 (Replaced) Nitto Terra Grappler G2 tires 285/60 (Replaced) Blacked out Toyota emblem on steering wheel Night Shade Front Grill (Replaced) Dark Tint Front TSS Emblem (Replaced MBRP Dual Exhaust KTJO Door Pod lighting Window Tint, 5% in the back 30% up front MESO Chrome Delete center console MESO Chrome Delete Vent Rings **** 2022 Mods **** Cali Raised Steel Front Skid Plate (Replaced) Ice Blue Map and Dome LED bulbs Rek-Gen XL Mud Flaps - Black on Black All interior trim painted Matte Black with Flat Clear Coat Aqua Blue Foot Lights - Front and Rear MESO Switch Panel Custom Layout MESO 3 Switch Overhead console panel MESO Chrome Delete Climate Control Rings UpTop Bravo Roof Rack Extreme LED 38 inch LED Light Bar in Roof Rack Diode Dynamics LED Strip Grill Lights Meso Ultimate Tail Lights (Replaced) Rock Lights - 8 Cyclone V2's (Replaced) UpTop Roof Rack Grab Handles UpTop Scene Pods with Baja Design Rock Lights Diode Dynamics Elite Series Fog Lights CaliRaised Stealth Bumper 30 inch Infinite Offroad LED Light Bar X2 Zeak 10,000 Winch KTJO Driver's Side Grab Handle LambTek Winch Switch Boomers "faux" TRD Pro Shift Knob Tacoma Lifestyle Smoke Third Brake Light Blacked out Instrument Panel Lens Diff Drop Dobinson's Suspension, Front Coil Overs, UCA's, Rear Shocks and Leaf Packs DB Customz Grill, Color Match with RGBW LED Letter Lighting **** 2023 Mods **** PowerTrays Tray with Busemann Fuse Relay Pioneer DMH-WC6600NEX Maestro RR2 SiriusXM SXV300 Tuner BoxWare Anti Glare HU Screen Protector Varity of cables and adapters Focal ACX 690 Front Speakers (Replaced) Focal ACX 165 Rear Speakers (Replaced) Diode Dynamics Stage Series Rock Lights - 3 in each wheel well Diode Dynamics Flush Mount Brackets Revolver X4s Tonneau Cover UpTop Roof Rack Grab Handles V2 Raceline Compass 17X9 wheels Toyo Tires Open Country A/T III 275/70R17 Tacoma Beast Infinity Tail Lights Taco Clout Wide Angle Convex Mirrors - Heated + Turn Signals + BSM KTJO Powered Folding Mirrors **** 2024 Mods **** Lighting Trendz Glow LED lights in Grill Lettering Cali Raised Cat Shields The Sub Box Shop Sub Amp box Rockford Fosgate 10 inch 4 ohm Dual VC Sub Kicker 3.5 inch speakers in dash (Replaced) Auto Harness House harness adapters for speaker wires Alpine PXE-C80-88 8 Channel Amp. Polk Audio DB 6502 Front Doors Polk Audio DB 6502 Tweeters in Dash Polk Audio DB 652 Rear Doors Hidden LED's in Bed Charvonia Design Bed Rail Tie Down Anchors Charvonia Design Bed Tie Down Anchors Charvonia Design Bed Floor Tie Down Anchors Charvonia Design Billet Battery Tie Down Redline Hood Struts TRD Pro Hood KITT Scanner LED in Hood Scoop Cali Raised Aluminum Skid Plate
    That is the same fuse block I used for my stuff. I used an empty switched fuse in the cab for my source of the switched power, add a fuse. I power my wheel rock lights, door rock lights, rack side lights and grill LED strips with Constant Power. Hidden front LED bar, roof rack LED bar with switched power. All of them are fused with 3-amp fuses.
