Switched to Amsoil... and now this...WTF
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MAtrdguy, Dec 23, 2010.
  1. Dec 23, 2010 at 8:55 AM
    MAtrdguy
    MAtrdguy [OP] Well-Known Member
    Pete
    Western Ma ( on the lake) / Danvers N Shore
    06 Taco DC LB
    None YET
    Take a look at these pics...I switched to amsoil oil and was just checking my oil level ( after 6k miles) and found this shit !!
    I DONT off road at all....99% hwy miles....
    Any Ideas ?? i will change it when I get home to M1 but THIS is making me VERY nervous..
    Thinking bout getting oil analysis done...anyone know who is a reputable company that does this ?
    Any thoughts ??
    BTW, I also just changed my front Diff fluid too and it looked kinda reddish...( dealer changed it)
    is there any way tranny fluid could get into the engine or the front diff ?
  2. Dec 23, 2010 at 8:57 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    It's moisture and quite common for this motor. It has nothing to do with the Amsoil. It does it with Mobil 1 and dyno oils. The main factor, however, is short trips. The more short trips (engine not up to operating temp), the more this will happen.
  3. Dec 23, 2010 at 8:58 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    :cool:
  4. Dec 23, 2010 at 8:58 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  5. Dec 23, 2010 at 9:02 AM
    outlaw7
    outlaw7 Well-Known Member
    Brandon
    PacNorWest
    2010 trd sport
    x2. my truck is not my dd so when i do get to run it i make sure that its run at operating temps for at least 15-20 mins. i also change my oil at 6 month intervals to try to prevent moisture buildup regardless of the miles the oil has. i have been running amsoil 0-30 since day one.
  6. Dec 23, 2010 at 9:05 AM
    tonyplanet
    tonyplanet Well-Known Member
    Glendora, CA
    09 Tacoma 4x4 TRD Off-Road
    enough to get me there
    X2 on the moisture. But I don't think that is normal. Drain your oil, and if it looks like what it does on your oil filler neck, then something is wrong.
  7. Dec 23, 2010 at 9:10 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    moisture yes....amsoil has nothingt o do with it as stated....
  8. Dec 23, 2010 at 9:24 AM
    viperstd
    viperstd Tacoma convert
    Maryland
    09 4x4 TRD SR5 DC LB
    AllPro Front and Rear trail armor & full skid plates, Demello Hybrid Rock Crushers, Old Man Emu suspension, Warn 8000# winch, PIAA SMR fogs, perforated + heated leather seats, in-dash DVD/NAV/Sound, RE subs
    agreed with all above. My amsoil does this, as does my mobile1 with this motor. Short trips in cold weather cause the buildup. I have a 3mile commute and my truck never warms up in winter and the filler neck looks like someone poured frothed peanutbutter or vaseline down there... :(
    I will actually try to take a longer route to work sometimes just to get everything really up to temp once in a while when it gets cold out.
  9. Dec 23, 2010 at 9:37 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    This is very common on vehicles driven for short distances during cooler temps. Multiplied even more so by the length of the filler neck.
  10. Dec 23, 2010 at 9:43 AM
    MAtrdguy
    Pete
    06 Taco DC LB
    None YET
    I drive 300 miles round trip daily @ 70-80 mph ALL intersate/ freeway....this isnt from short trips....
    I dont think its the oil...Amsoil is reputable I'll switch back to M1 tonight and see what happens.
    I used a trd filter I bought on fleabay ( yes it was new)
    in all the time I had my Tundra and even this Taco I have NEVER seen oil that bad. !!
    is it possible to get any other fluids into the oil from something that is cracked or whatever??
  11. Dec 23, 2010 at 9:44 AM
    CraigTRD
    CraigTRD Canadian in the South
    Craig
    London, Ontario, Canada
    Tacoma
    6" FabTech Lift, Custom rear leaf packs, RedLine gas hood props :D, Hockey Stick Canadian Flag Mod. 2012 Front
    It's normal. Nothing is wrong.
    /end thread
  12. Dec 23, 2010 at 9:47 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Don't waste your money but switching the oils (unless it's time for a change). It's not from any cracks in the block. IT'S NORMAL.
  13. Dec 23, 2010 at 9:57 AM
    JKD
    JKD Well-Known Member
    It's engine mayonnaise. Oil + water (condensation).
    It does no harm and goes away if the oil heats up to normal op temperature. A long highway trip usually does it, but the Tacoma has that long plastic oil neck that might keep that end of it cool enough to prevent driving off the water from that small amount of oil.
    Nothing to worry about.
    ETA: You might try wrapping the oil neck with something insulating to keep the heat in and see if that helps. Changing oil is not going to do anything for it and will be an unnecessary expense.
  14. Dec 23, 2010 at 10:35 AM
    tegdog
    tegdog Taco Lover
    Indiana
    09 Tacoma Dbl TRD Sport
    ventvisors,seatcovers, bug shield,TRD CAI,TRD CAT BACK,blacked out emblems,bed extender, TSB leaf pack,Pro Dry filter, Grill craft upper, lower, & triangles, Hella 500 Black magics
    Mine looks just like that, if the oil you drain out looks milky you got issues. I bet the only oil in your motor that looks like that is in the oil fill neck, like others have said its normal don't worry about it.
  15. Dec 23, 2010 at 10:50 AM
    rwcfrank
    rwcfrank Well-Known Member
    08 SR5 Prerunner
    Dodge and Chrysler products v6 engines have a mile of posts regarding this, apparently they get it real bad from short trips.
  16. Dec 23, 2010 at 11:20 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    My mother-in-law has a 4.7L V8 Grand Cherokee and it does the same thing (with Mobile 1).
  17. Dec 23, 2010 at 11:44 AM
    avatacoma
    avatacoma Member
    jim
    south west pa
    4X4 Long bed SR5
    Extang Cover,Bug shild
    Check your other vehicle,(S), they will also have it.
    Common up north, my Honda Civic had it and my dodge Durango had it also.
  18. Dec 23, 2010 at 11:51 AM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    Normal.
  19. Dec 23, 2010 at 12:00 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Just curious reading this thread since I use Mobil1, I've never noticed this, and I believe everyone that it is normal, but can it be harmful (not even so much harmful) should I do like viperstd and just let it get warmed up to try and avoid it?
    In short, although normal, should I try to avoid this? (note: I have not ever seen this problem on my truck, just curious)
  20. Dec 23, 2010 at 12:43 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Lives: Pyeongtaek, South Korea/Home: Leesburg, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    when i was in germany, i had this all the time and i only made short quick trips. used mobil 1. its the plastic filler neck that causes this. doesnt matter the type of oil
