Switched to synthetic oil, now 'bouncy' idle, 2011 V6
Discussion in 'Technical Chat' started by mechanica, Dec 22, 2016.
  1. Dec 22, 2016 at 8:29 PM
    mechanica
    mechanica [OP] Member
    Phoenix, AZ
    2011 DCSB PreRunner SR5
    2011 V6 with 70,000 miles.
    Took it to the shop or dealer for an oil change every 5k miles with conventional oil, but decided to start changing my own oil. I followed the sticky thread here, which was a great help. I put in 5.5 quarts of Mobil1 5W-30 and a Wix 51438XP oil filter. Fresh drain gasket, oil levels look good.
    Symptoms: first few minutes, the idle wasn't rough, but very bouncy. Best way to describe it is smooth for about 3-5 seconds, then a couple bouncy moments, then smooth, then bouncy again. No visible change in RPM, resting around 500. The engine also raced a couple times at low speeds between gears driving around the neighborhood, but that has since subsided. On a restart after dropping off the old oil for recycling, the engine didn't catch the first time I tried to start it, but fired up like normal right away on the second try. Didn't have this problem again. No noticeable differences cruising at 45 and 75mph, but the bouncy idle comes back again at stoplights. I drove around for about an hour including some errands, and oil level looked good.
    Is there a 'break in period' switching to synthetic from conventional? Am I missing something else? I didn't touch anything else while working on it. It was 60 degrees here today, so no weather factors. Will have to wait until tomorrow for another cold start.
    Thanks.
  2. Dec 23, 2016 at 11:09 AM
    mechanica
    Phoenix, AZ
    Still a little rough idling this morning after a cold start, but operation is smooth. Any thoughts?
  3. Dec 23, 2016 at 11:17 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    A oil change to synthetic will not cause any of the issues you listed. A wire accidentally pulled from something will. Are you getting any codes?
    Did you fill up right around the same time you changed the oil?
    1Shifter likes this.
  4. Dec 23, 2016 at 11:21 AM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    When I switched to synthetic my truck seemed to idle just a little faster opposed to dino oil. Switching from dino to synthetic should not cause the problems you describe. I don't claim to be an expert so maybe someone else will chime in. I would suggest posting this on Bob is the Oil Guy website. If it's oil related someone there will be able to help, they take oil and oil related issues to an extreme level.
    https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=cfrm
  5. Dec 23, 2016 at 2:05 PM
    mechanica
    Phoenix, AZ
    Not showing any lights on the dash, and I don't have a diagnostic reader. Previous fill up was about 60 miles before the oil change, and said symptoms were not present. I'm in agreement in thinking an oil change wouldn't cause what I'm experiencing.
  6. Dec 23, 2016 at 2:07 PM
    mechanica
    Phoenix, AZ
    Thanks. I'll go poke around.
    1Shifter[QUOTED] likes this.
  7. Dec 23, 2016 at 2:10 PM
    Aviator6
    Aviator6 Member
    Tom
    Charleston, WV
    2017 Tacoma TRD ORDC
    Sounds like a vacuum leak. Check if you might have disturbed a line. Or, like previous post, you accidentally disconnected a sensor. NO way that changing to syn oil will affect your idle like that.
    Cypherian likes this.
  8. Dec 23, 2016 at 2:21 PM
    anonemoose
    anonemoose Well-Known Member
    Bill
    Big Pine, Calif
    2015 White TRD Sport V6 DCSB
    Ride-Rites, Everything Weather-Tech Makes Added some 12 volt outlets with relays
    I switched to synthetic on my 2015 at the first oil change (only 2000 miles @ 6 months) and did not see anything weird BUT. I had issues with my olden Toyota at an oil change. The crank case breather did not like the synthetic and it turned out it was a clean out of that whole system, valve and tube - now that was on a carb 22r engine but you might want to look at the smog valves and clean them especially at low rpm. I have always changed the oil before a smog test as I found the dissolved crap always messed up our cars.
  9. Dec 23, 2016 at 3:23 PM
    mechanica
    Phoenix, AZ
    Checked everything I could see in the engine bay, top and bottom. May end up taking it in to the shop, but will give it a few days in hopes things settle down.
  10. Dec 23, 2016 at 3:34 PM
    1Shifter
    Jeff
    09 PreRunner
    Good luck OP, let us know how you make out
  11. Dec 23, 2016 at 3:36 PM
    Clearwater Bill
    Billy
    Largo Florida
    Coincidence, not oil.
    Unless, as someone mentioned, a wire was compromised in the process.
    The PS idle speed adjust comes to mind. Even if in place, it may need cleaning.
    Also, when was the last time the throttle body was cleaned? Air leaking around the butterfly at idle due to dirt build up can cause erratic running. Can't hurt to try, but be sure to use TB cleaner, not carb cleaner.
  12. Dec 24, 2016 at 3:02 AM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    X2 on the vacuum leak.
  13. Dec 24, 2016 at 3:11 AM
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    I've been told the 1st oil change after switching to synthetic is short mileage. I don't remember the number.
    I read online Mobil1 and others aren't true synthetic. They are oil companies.
    When a previous mechanic, in Seattle area, used synthetic, it was AMSOIL.
    Ken in NC
  14. Dec 24, 2016 at 4:06 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    I'll bet since this is your first diy oil change you are just being paranoid. It's all in your head man.
  15. Dec 24, 2016 at 4:37 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    x3 on vacuum leak.
  16. Dec 24, 2016 at 4:54 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Make sure the oil cap gasket is clean and the cap is tight.
    Make sure the dipstick is firmly seated in the tube.
  17. Dec 24, 2016 at 4:59 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    There isnt a chance u drained the tranny pan, and then put 5.5 qt of new oil on top of the 5.5 qts of old oil is there? Wouldnt be the first time and 11 qt of oil would prolly make some wierd stuff happen, also tranny being 3 qt low might explain some stuff too
    2Toyotas likes this.
  18. Dec 24, 2016 at 5:05 AM
    Cypherian
    Cypherian Well-Known Member
    Mid Atlantic Region
    This sounds like a plan get some starting fluid and check your lines but before make sure you didn't bump an electrical connector so it is not making good connection. I have a 2011 I bought brand new and run synth in it have been since the second oil change. I can tell you something I learned with the first Toyota I owned a RAV 4 the idle always seemed HIGH when it was cold IE winter time. Checked with other owners and several mechanics all said yep normal but it did not bounce idle.
    Cypher
  19. Dec 24, 2016 at 1:18 PM
    mechanica
    Phoenix, AZ
    This answer is the winner. I am the loser. Truck is quarantined in the garage until I can get more ATF Monday when the dealership parts department opens up. Will drain my oil pan too and start fresh. Merry Christmas everyone! @yota243 wins something.
    HAVVOKK, 1Shifter and yota243[QUOTED] like this.
  20. Dec 24, 2016 at 1:24 PM
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    Wow, what a good thing that you were thinking outside the box.
    yota243[QUOTED] likes this.
