Switched to synthetic oil, now 'bouncy' idle, 2011 V6
Discussion in 'Technical Chat' started by mechanica, Dec 22, 2016.
  1. Dec 24, 2016 at 1:25 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Not that i like what happened but u know what i mean. Sorry dude, hope there wasnt any real damage
  2. Dec 24, 2016 at 1:27 PM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    Happens more often than ya think. One of the first things I did to my truck was install a Fumoto valve "just in case". Good luck with the truck OP...
  3. Dec 24, 2016 at 1:27 PM
    HAVVOKK
    HAVVOKK Well-Known Member
    2014 DGAF Long Bed
    Fucking look it up
    Holy shit good call man yea don't run that truck again till you get the right fluids in there drain everything again and redo both processes
  4. Dec 24, 2016 at 1:33 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Ouch.
    You don't need Stealership ATF. Get some Valvoline MaxLife ATF at wallyworld - $18 for a gallon (it's WS compatible). Pick up some new syn oil while you're there.
    Also get an IR gun. ATF level is checked based on ATF temp and the drain tube in the trany pan. There is no ATF dip stick.
  5. Dec 24, 2016 at 1:51 PM
    Chuy
    Lakeside, CA
    Silver Taco
    06Tacooo likes this.
  6. Dec 24, 2016 at 2:17 PM
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    On a side note:
    Use that excess ATF to make penetrating oil, 50:50 with acetone.
    Even better than Kano Kroil.
    1Shifter likes this.
  7. Dec 24, 2016 at 3:49 PM
    dlopan
    dlopan Well-Known Member
    Dave
    Albuquerque, NM
    2015 Pyrite Mica 4wd DCSB TRDSport
    Camper shell, CB radio. R-pod 179
    I hate to be the nay sayer in the group but Amsoil is NOT synthetic.
    Only true made in the US is Redline.
  8. Dec 24, 2016 at 4:30 PM
    Chuy
    Lakeside, CA
    Silver Taco
    Alright, what's the punchline?
    Synthetics are chemically engineered oils, and Amsoil is a chemically engineered motor oil.
  9. Dec 26, 2016 at 2:14 PM
    mechanica
    mechanica [OP] Member
    Phoenix, AZ
    2011 DCSB PreRunner SR5
    Everything is humming and purring again like it should. Added 3.25 quarts of Toyota ATF, did the AT Temp level check and the pan drained about 1/8 quart. Fresh oil too after draining my oil double-up and adding 5.5 quarts. Thanks again to yota243 for figuring out what I messed up, and the rest of the TW folks who chimed in.
    yota243[QUOTED] likes this.
  10. Dec 26, 2016 at 2:35 PM
    yota243
    E.J.
    north Alabama
    Glad to hear it. These are tough trucks and over built trannys, some of which even left the factory with low fluid from what it seems. The extra oil was prolly worse on the truck than the low tanny cuz it holds like 17 qts or somethin total, may have added a little extra stress on some internals, and it may only make it to 400k miles now haha
    mechanica[QUOTED][OP] likes this.
  11. Dec 26, 2016 at 5:57 PM
    Chuy
    Lakeside, CA
    Silver Taco
    We like happy endings.
  12. Jan 7, 2017 at 3:55 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    I had the same experience, ended up being just a coincidence, and a dirty MAF sensor.
    By the way, thanks Chuy!
    I go over my truck once in a while with an IR gun looking for hot spots. In 5 min. you can obtain a wealth of information. Beats a break down on the road somewhere. After a while you get to know what's normal for brakes, bearings, etc. Now I know what's normal for the tranny!
  13. Jan 7, 2017 at 5:53 AM
    mechanica
    Phoenix, AZ
    In doing research to try and figure out what was wrong, I added cleaning the MAF sensor and throttle body to my near term maintenance plan. This forum is helpful for hearing the experiences of other drivers and not just theory in a maintenance manual.
  14. Jan 7, 2017 at 6:06 AM
    EasyLivin
    EasyLivin Well-Known Member
    Jeff
    Euless, TX
    2014 White TRD OffRoad Double Cab
    Focal PS165AC / Focal PS165V / Alpine PDR V75 / Kenwood Excelon KFC-XW1000F / Leer 100XR shell / Bilstein 5100 lift
    I concur. Did you check the air filter? Did you change the plugs? I would guess vacuum leak as well from what you are saying but misfires could create a similar scenario.
