switching 35w and 55w ballasts?
Discussion in 'Lighting' started by colinb17, Jul 20, 2010.
  1. Jul 20, 2010 at 1:03 PM
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    i have an extra set of 55w hid ballasts laying around...my question is, can i swap out the 35w ballast i have in one set of my lights for the 55w?
    to my understanding, the bulb only determines the color, and you can hook up either 35w or 55w to it and it will work?
    or am i wrong and the bulbs are speciffically made for one wattage or the other?
  2. Jul 20, 2010 at 2:20 PM
    colinb17
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
  3. Jul 20, 2010 at 2:28 PM
    Tacorunner87
    Tacorunner87 Well-Known Member
    Chino Hills Ca
    To much to list!
    When I ordered new bulbs it actually said 35w on it. Im thinking thinking you will blow the bulb if you hook up a 55w ballast to it.
  4. Jul 20, 2010 at 2:38 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    you should have matching ballasts to bulbs. the thing that determines the color is the kelvin of the bulb. the higher you go on the kelvin scale the bluer the color and the lower you go the yellower the color. 5000k is a mirror white.
  5. Jul 21, 2010 at 10:12 AM
    colinb17
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    cool guys, i gues i'll save the 55w ballasts for when i remount the lights i took them off of. i know how the coloring works, i was just curious about the power ratings. does anyone know what is phtsically different in the bulb that allows it to handle 55watts vs 35?
  6. Jul 21, 2010 at 10:15 AM
    IamTacO
    IamTacO red balls got me!
    adam
    QC az
    01 Prerunner SR5 TRD-Offroad
    4x2 Prerunner. Hankook Dynapro ATM rf10 265-65-16, e-locker FTW! Morimoto d2s bi-xenon HID projectors, Philips 85122+ 4300K, Cobra 75 w/ 3' firefly, Kenwood KDC-MP342U w/ SIRIUS, Line-x bed liner, 4' coretrax(black)
    i ran 35w bulbs with 55w ballasts with no issues. in fact, my last set up used a kit that came with 55w bulbs as well. not only did the bulbs(55w) give me a crappy cut off, they cracked my headlight lense. by ditching them and going back to 35w bulbs, the cut was perfect the lenses were fine(i had swapped lenses)
  7. Jul 21, 2010 at 10:21 AM
    colinb17
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    you said cutoff, so are you running a projector? did it crack the actuall projector lense? or was it stock housing? doesn't matter as much as i'm not using these in the headlights, just curious. what HID setup (company) were you running?
  8. Jul 21, 2010 at 3:04 PM
    IamTacO
    adam
    QC az
    yes i had retrofitted projectors in my subaru. the overwattage/crappy bulb, cracked and damaged the headlight lense, not the projector. the kit was the 55w apexcone setup d2s setup. i'm guessing you are looking to do a pnp kit in your headlights? figured i try to convince you not too. you will blind others due to the wrong reflector setup. they can not correctly focus the light. but its your ride, do what you want. good luck, i'm out
  9. Jul 21, 2010 at 6:09 PM
    colinb17
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    well, i actually already have hids in the heads, fogs, and 3 sets of off road lights (I always go first on night time trail runs :) ). but i just got an all pro bumper and had to loose one of the sets of off road lights, so i was considdering swapping out the 35w ballasts in the fogs with the 55w from the off road lights not in use at the moment. not really worried about overheating as the fog housing has about the same volume as the off road light (it's a slim OR light), and i didn't have any issues with those.
  10. Jul 21, 2010 at 6:11 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    yea you can swap them no problem. your color will shift a bit but as long as they're decent quality bulbs youll have no problem. lifespan will be decreased, but who has their bulbs for 10000hrs anyway
  11. Jul 21, 2010 at 6:36 PM
    colinb17
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    ^^^ thanks Matt
    also, perks of a lifetime warranty if a bulb or ballast ever goes
