Switching 7 pin to a 4 pin
Discussion in 'Towing' started by txduckhunter, Jan 18, 2012.
  1. Jan 18, 2012 at 6:26 PM
    txduckhunter
    txduckhunter [OP] Well-Known Member
    centex
    08 Tacoma DC LB SR5 4x4
    2.5" lift, ARE Shell, Ducks Unlimited Rubber Floor Mats. ROGUE badges,
    Hey all. I have an 08 V6 Dc 4x4 Taco and it came with the 7 pin connection.
    I was planning on just using one of the adapters that plugged in to it but this weekend I backed over a tool box while visiting the family that my brother left behind my truck on the ground and it basically broke off my 7pin.
    I only use a 4 pin anyways to pull my boat and am wondering if I should just replace the 7 and get an adapter or take it off and wire in a 4 pin.
    Could I wire a 4 pin on to the existing wires? Anybody done this?
  2. Jan 18, 2012 at 6:32 PM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    I have a spare one oem 7 pin wuth the lp light .wires to.
  3. Jan 18, 2012 at 6:34 PM
    Tacoma Mike
    Southern Maine
    Fix the 7 pin as before. use an adapter. You never know when you might need it. Can you wire up a 4 pin?? sure.. fix it right.. :)
  4. Jan 18, 2012 at 6:34 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'd keep the 7 pin. You can always dumb down a 7 pin to a 4 pin, you can't turn a 4 pin into a 7 pin if you ever need it in the future.
  5. Jan 18, 2012 at 6:44 PM
    LostRebel
    LostRebel Well-Known Member
    Almost Canada, USA
    Black Access Cab 4x4 TRD Off Road
    Fisher plow, BakFlip and Snugtop cap, Demello Sliders, Scanguage,
    :eek: Your brother left his family where?
    I've not done it, but I don't see why you can't direct wire a 4-pin connector as long as the wires from the 7-pin provide the proper output. There may be more to it though. I have wired a 4-pin onto a Tacoma that was not pre-equipped with a wiring harness and the 4-pin harness contained an isolation unit of some type. A few minutes with a test light might provide the answer.
  6. Jan 18, 2012 at 6:49 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    Don't mess with the truck's trailer harness.
    Just get a 7-pin to 4-flat converter plug.
  7. Jan 18, 2012 at 7:24 PM
    txduckhunter
    centex
    Well it looks like I'm going to just put another 7 pin on. Maybe I can find one of the ones that has a 7 and 4 at a parts store tomorrow. I gotta get it set up to tow the boat Friday when we hit the water!
  8. Jan 18, 2012 at 7:44 PM
    jflan
    Vancouver, WA
    Save your 7-pin. You may want to pull something that has trailer brakes someday.
    Then just get the adapter as I outlined above.
    Pollack #12-705 is a good aftermarket substitute for the plug on the vehicle. You might have to fabricate a bracket.
    I have seen this "combo" plug arrangement but it was an issued Toyota setup on a Tundra, I believe.
