Switching from 245/75/16 to 265/70/16?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BeefedTacos, Jul 28, 2019.
  1. Jul 28, 2019 at 8:33 PM
    BeefedTacos
    BeefedTacos [OP] Well-Known Member
    Brian
    North Carolina
    2015 tacoma dcsb SR5 4x4
    None so far
    Bone stock tacoma.
    (Dumb Question)
    Was wondering if switching from the 245 to 265 change my speedometer or any noticible change? Will my truck sit higher?
    thanks fellas
  2. Jul 28, 2019 at 8:36 PM
    tcjacado
    tcjacado Well-Known Member
    Maybe a 1/4 to 1/2 inch taller and no it will not affect the speedometer as most of the trucks come with that size from the factory.
  3. Jul 28, 2019 at 8:39 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
  4. Jul 28, 2019 at 8:40 PM
    ripcalifornia
    ripcalifornia Trok
    Cal (Kyle)
    HB CA
    2014 AC
    patches
    the 265/70r16 are also a stock tire size. You'll barely notice a difference
    BassAckwards likes this.
  5. Jul 29, 2019 at 8:32 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    both of those tires are effectively the same diameter. You will likely loose a smidge in the MPG department due to a wider tire, but that will mostly be effected by weight of said tire.
  6. Jul 29, 2019 at 8:40 AM
    vickster83
    vickster83 Active Member
    Scott
    MS
    2011 5 lug DC
    if you can perceive a speedometer change resulting from a difference of 1/10” in tire diameter, then you’re one perceptive SOB!
  7. Jul 29, 2019 at 8:56 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I went from the 245 to a 265/70-16 to a 265/75-16 to a 265/70-17 and did not notice any realistic change in mpg's. As for speedo, the last two slightly oversized tires actually corrected the speedo to be accurate, instead of reading a bit high.
