Switching from CB to GMRS/FRS
Discussion in 'Off-Roading & Trails' started by JJ04TACO, Jun 25, 2019.
  1. Jun 25, 2019 at 10:35 PM
    JJ04TACO
    JJ04TACO [OP] Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Well, I've had a CB for a few years now and quite honestly never even seriously used it. Been to Moab twice and no one (in my group) used CB, but instead used the little handheld GMRS/FRS radios.
    So...before I switch as opposed to ditch cab mounted radios all together. What is the consensus with something like the Midland MXT400 40 Watt GMRS radio? Or would you stick with the cheaper handheld ones?
  2. Jul 9, 2019 at 2:40 PM
    clc clc
    clc clc Well-Known Member
    PA
    2012 4x4 reg cab tacoma/2020 subaru crosstrek
    Bump. Im no help but i do have one of these.
    Im just starting to learn how all this stuff works so if you could explain how it all works together that would be great.
  3. Jul 9, 2019 at 3:18 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I've always used a handheld FRS/GMRS radio. Mine are midlands.
    I don't usually go in large groups, so I have a spare that someone else can always use. That's always been enough.
    Comms are always about going with what the group(s) you run with mostly have. Ham is cool I guess, but a little "techy" for my taste.
    Handhelds (of any type) are great for when you have to exit the vehicle and spot someone, etc... Rather than yell at them, just use the radio. Doesn't work all the time, but you can put that in the "pro" column.
    I've just learned, actually, I've been operating on GMRS channels without a license. :anonymous: Channels 1-7 and 15-42 are GMRS are require FCC licensing. The other channels are lower power FRS...
    Guess I should switch mine before I get thrown in the pokey, lol
    galito likes this.
  4. Jul 10, 2019 at 8:45 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    How is the voice/sound quality of the handhelds? Are they loud enough to be heard in the cab while driving?
    I like that larger handheld in the photo...
    I’d like the cab mounted midland because of the power that it has. It’s pricy though.
  5. Jul 10, 2019 at 8:46 AM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    B-tech. More punch, less $. Gmrs
  6. Jul 10, 2019 at 8:47 AM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
  7. Jul 10, 2019 at 8:48 AM
    m603holden
    Marteeen
    New England
  8. Jul 10, 2019 at 8:51 AM
    Shellshock
    Iowa
    Most people are going to HAM (VHF/UHF). Theres honestly not really any good reason to run CB or GMRS / FRS these days (aside from FRS / CB don't require a license). You can get a handheld for < $50 and you'll have much better voice quality, range and battery life.
    0xDEADBEEF and uploadadventure like this.
  9. Jul 10, 2019 at 11:41 AM
    jbrandt
    Justin
    Honestly, unless you typically separate from your group, the power of a handheld GMRS/FRS is more than enough. I was using my midlands in Yellowstone with my friend and his family, we would get separated due to bison/bear related traffic jams and still could easily communicate. Never had an issue while wheeling. As far as battery life, I had my handhelds running for 3 days straight on a motorcycle/camping trip (basecamp and running bikes for day trips) and the battery meter barely moved (didn't have to charge them at all). That said, on one wheeling trip, my friend's daughter was reading my son (over the radio) joke books, and the battery died within an hour, lol...
    Just run with whatever your "normal" group runs with. Given that I don't have trouble with power or range of my FRS/GMRS handleds, I doubt you'll have an issue with any UHF handheld. Lots of people have one of each, maybe a cab mounted CB (because those are so cheap), then a UHF and FRS/GMRS handheld. Just pull out whatever the group that day is using.
  10. Jul 10, 2019 at 3:03 PM
    clc clc
    PA
    I think it should be loud enough. I dont understand how to program it so i havent done much with it but i have been able to pick up the NOAA channel.
  11. Jul 10, 2019 at 3:10 PM
    m603holden
    Marteeen
    New England
    Won't be able to buy ham gear that can transmit outside of ham bands much longer. Finally passed a bill saying they're now illigal to sell. At first it was only to import.
    The new ones will most likely only be under the BTECH brand and be FCC certified for the ham bands only. Meaning you'll need a license to operate them legally.
    The Btech gmrs handhelds can also have a mag mount antenna attached to it which a big Improvement be ause a handheld inside a vehicle is hindered by all the sheet metal, and this method is cheaper.
  12. Jul 11, 2019 at 8:53 AM
    jbrandt
    Justin
    you have a link for that?
  13. Jul 11, 2019 at 9:06 AM
    m603holden
    Marteeen
    New England
    For which part?
  14. Jul 11, 2019 at 10:50 AM
    jbrandt
    Justin
    The new bill being passed restricting sales.
  15. Jul 11, 2019 at 6:31 PM
    m603holden
    Marteeen
    New England
    It's common knowledge that they're phasing out the old baofengs for the new ones because they can transmit on bands not permitted by the FCC. They'll fix that and the new ones will only be able to TX on ham bands. Which means people won't be able to tune them to the GMrS bands and talk to people on the bubble pack walkie talkies anymore.
    The more recent article is buried in my social media feed somewhere. I'll try to find it if I can.
    jbrandt likes this.
  16. Apr 18, 2020 at 7:40 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Reviving my old thread here. Due to being at home for weeks on end, I’ve been researching all the gadgets and other crap I want to no end.
    I think I’ll do the Btech 50X1. I picked up one of their GMRS V1 handheld radios for Moab last October and loved it.
    I’d like a high power cab mounted unit. Probably don’t NEED it but you can’t argue with the cool factor.
    A few weeks ago my kids 6 and 4 discovered their cheap Minon walkie talkies and had a blast, but soon lost one at a park. Turns out they were FRS channel 8 so I could use mine.
    So I found a screaming deal on some Midland T71VP3. $49 at Staples no less. Yes the office supply store. They’re usually $79. Now we have 3 to play with.
    fatfurious2 likes this.
  17. May 9, 2020 at 6:45 AM
    laddertoyou
    laddertoyou Active Member
    VA
    17 DCSB TRD Sport
    Hello. I have A midland MXT 115. Where are the best locations for antenna or 3rd party mounting bracket?
  18. May 9, 2020 at 7:41 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    For my CB, I used a CBI antenna mount. It bolts to the finder up by the A pillar. Some people use a mag antenna on the roof. The roof offers a really good ground plane. Personally I’d look at the CBI mount or similar. Midland has some really good antennas available too.
  19. May 18, 2020 at 7:42 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Well my boss just unloaded 6 midland gmrs radios on me so i guess im gonna be using gmrs now haha
    JJ04TACO[OP] and 2013XSPX like this.
  20. Nov 21, 2021 at 8:11 PM
    Jojee117
    Jojee117 Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    I'm looking into getting some FRS radios right now and came across both of the ones you mentioned. If you had to choose between the BTech 50X1 and the Midland GMRS V1 which would you go with? Does one seem to be more powerful than the other, or have a better battery life? It seems like the Baofeng has more features, but the Midland is easier to use and less bulky to keep in the cab. I can't see in the descriptions or pictures how the midlands charge. Do they have to be plugged into their station, or can you just plug one in at a time with a USB cable? Sorry for the barrage of questions but I'm new to the comms stuff, and a lot of these radios seem to be very similar.
