Switching from CB to GMRS/FRS
Discussion in 'Off-Roading & Trails' started by JJ04TACO, Jun 25, 2019.
  1. Nov 21, 2021 at 8:30 PM
    JJ04TACO
    JJ04TACO [OP] Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    The 50X1 is a full featured GMRS that’s repeater ready meaning you can use split tones for TX/RX. It’s also truck mounted and has 50W of power. The GMRS V1 is also BTec. And is the same full featured handheld. I have the v1 and it’s nice but a bit much for the average user. I have a desire to learn this stuff and it’s a bit complicated. But I like it.
    Midlands are far easier to use for the average Joe. Most of us will never use repeaters. If you want a truck mounted, their micro mobile series is a higher wattage setup. Then you can get some handhelds to toss in the glovebox for out of vehicle spotting or coms.
    midland is supposed to release a full 50 watt unit this spring with more features.
  2. Nov 21, 2021 at 8:41 PM
    Jojee117
    Jojee117 Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    I meant the GMRSV1 vs the T71VP3, sorry. I'm just looking for a handheld frs right now, but I do plan on eventually adding a more powerful cab mounted GMRS in the future. I'll probably go with the midland handhelds for the ease of use. How have the midland handhelds held up so far? Do they have decent range and battery life? I wouldn't expect them to be too crazy at 2 watts, but have you ever tried them out at a mile or two?
  3. Nov 22, 2021 at 6:50 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Midlands handhelds are great. No issues. Mine can plug into a usb charger individually eliminating the need to bring the charging base. Super helpful. So I have 3 handhelds. 2 midland 1 Btech.
    I’ll likely do the midland 50 watt when it arrives this spring.
    Jojee117 likes this.
  4. Apr 27, 2025 at 8:03 AM
    GawainXR
    GawainXR Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    I've been trying to decide between the Midland GXT67 and Wouxun UV9-GX
    This would be for a combination of group and solo use,
    I'm kind of inclined to go with the Midland for its aesthetics and more simplistic look but also ask myself is the repeater function really worth the drastic cost difference compared to say the Midland GXT1000 ?
