Switching into 4-HI while moving?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BRUIN8124, Jan 29, 2013.
When switching into 4WD HI, do you come to a complete stop and shift into neutral?
Poll closed Feb 28, 2013.
  1. While moving
    88.6%
  2. Complete stop/in neutral
    11.4%
  1. Jan 29, 2013 at 7:14 PM
    #61
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Agreed
  2. Jan 29, 2013 at 7:22 PM
    #62
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Read you operators manual and get back to us.
    Or better yet when sitting in drivers seat look up and read visor.
  3. Jan 29, 2013 at 7:28 PM
    #63
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Does not work in neutral/stopped for me.
  4. Jan 29, 2013 at 7:33 PM
    #64
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    My 2012 has failed to go into 4hi from a dead stop. Pisses me off. I flip the switch a couple times and then it does do so, but it pisses me off it doesn't make a positive engagement every time. And I doubt that is unusual. Pisses me off the auto 4wd is standard, should be optional. I get tired of that thing beeping at me and I doubt that is unusual, in fact it's probably usual. The manual lockers and manual xfer case always worked, every time.
  5. Jan 29, 2013 at 7:33 PM
    #65
    BlindingWhiteTac.
    BlindingWhiteTac. Well-Known Member
    Thomas
    Vancouver, WA
    07 LQ4 4L80E
    Just the essentials and no extra fluff.
    If you want to ask the experts consult the owners manual. Yes you can, below 62 mph.
  6. Jan 29, 2013 at 7:35 PM
    #66
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Here it is off the sun visor.
  7. Jan 29, 2013 at 9:12 PM
    #67
    farbio615
    farbio615 Well-Known Member
    Adam
    Ft. Polk
    Big and Blue
    A few
    just wanted to see if it was 4 pages of people saying the same thing
  8. Jan 30, 2013 at 9:31 AM
    #68
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I do not shift on the fly unless it's a emergency.
    because you can't fix stupied
  9. Jan 30, 2013 at 11:09 AM
    #69
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    it needs to be in perfect sync, otherwise you need to move the truck to sync it
    or try again. this is not a flaw, it is a fact of the particular system
    if they designed it to engage always no matter what, go ahead and add $2000 to
    the price of the truck because you'd need a re-engineered tranny and xfer case
    and in fact it does always engage, you just need to be a) moving and b) changing speed and not constant accel
  10. Jan 30, 2013 at 2:46 PM
    #70
    chipnoreo
    chipnoreo Ready for snow!
    Anna
    Alaska
    Ram Eco Diesel
    Getting 30 mpg on the highway
    Was about to post a pic of this myself :D
  11. Jan 30, 2013 at 3:11 PM
    #71
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    umm... you spelled stupid wrong.
  12. Jan 30, 2013 at 3:39 PM
    #72
    Bullfrog
    Bullfrog "I think I know more than I do."
    McLaren
    North Bend
    98 V6 4x Limited Ugly Canadian Green.
    Accessory Box with CB attached. Alpine Type S front and back. LineX. Bedline SKidplates. In progress: Bilstein 5100s with BFG mudterrains 33x10.5 A/C compressor to Onboard Air compressor mod.
    When the weather is bad I have to be in 4hi to get up my driveway (balding tires and gravel; avoiding ripping the gravel up). I have always put in the clutch shifted to 4hi slowly let out and when I get to the top do the same thing
  13. Jan 30, 2013 at 3:54 PM
    #73
    OZ-T
    Peter North
    British Columbia
    stupied is as stupied does
  14. Jan 30, 2013 at 4:40 PM
    #74
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Your co-worker is full of :poking:
  15. Jan 30, 2013 at 5:54 PM
    #75
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    you only need to stop and go to N if
    you are going to 4hi from 4lo
  16. Jan 30, 2013 at 8:16 PM
    #76
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
    4HI in the rain. :smack:
    You all sound like a friend of mine who puts it into 4HI when it sprinkles because it "makes him feel safer"
    The only time I used 4HI on the pavement was when I was in the snow from my sig.
  17. Jan 30, 2013 at 8:30 PM
    #77
    Schwinn
    Schwinn Well-Known Member
    Jamie
    Georgina, ON
    2012 TRD Sport with Trail Teams package
    This times infinity. I used to shake my head at all the 4x4's in the ditch during the first heavy snow as I passed by in my lowered Mustang.
  18. Jan 30, 2013 at 9:05 PM
    #78
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    It's clear that it pisses you off, and that you doubt it's unusual.
    Seriously though it sometimes takes me a couple extra switching back and forth for it to engage also.
    Never tried it while moving yet.
  19. Jan 30, 2013 at 9:09 PM
    #79
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    i usually do it when moving. some times if i’m stopped and i know i may need it or i’m going up a gravel hill that i may spin on i will go a head and put it in. but i don’t put it in neutral. i have done it up to 40 and not had any problems. i think it says in the Manuel you go do it up to 60 or 65mph.
  20. Jan 30, 2013 at 10:12 PM
    #80
    bullaculla
    Da big big island!
    I never had it not shift to 4hi while moving. I think the gears can engage easier when they are moving. I usually have problems too when at a complete stop.
